[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-55-gbb75af6
Sat Apr 18 12:58:15 PDT 2020
the project "PostGIS".
       via  bb75af6f77052fddf0cf0b4b66e920569a770407 (commit)
      from  fed776a1574fb652eb88f9919c2ff171b4e711a8 (commit)
revisions in full, below.
commit bb75af6f77052fddf0cf0b4b66e920569a770407
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Apr 18 15:58:09 2020 -0400
    Mark raster agg functions so they show in agg function section
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index db0ced7..6ecf12d 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -7003,7 +7003,7 @@ SELECT rid, (meta).* FROM bar
 				<para>Enhanced: 2.1.0 Addition of ST_Transform(rast, alignto) variant</para>
 				<para>Availability: 2.0.0  Requires GDAL 1.6.1+</para>
 			</refsection>
 			<refsection>
@@ -7556,7 +7556,7 @@ rid | exclude_nodata | include_nodata
 				<funcsynopsis>
 					<funcprototype>
 						<funcdef>bigint <function>ST_CountAgg</function></funcdef>
-						<paramdef><type>raster </type> <parameter>rast</parameter></paramdef>
+						<paramdef><type>raster set</type> <parameter>rast</parameter></paramdef>
 						<paramdef><type>integer </type> <parameter>nband</parameter></paramdef>
 						<paramdef><type>boolean </type> <parameter>exclude_nodata_value</parameter></paramdef>
 						<paramdef><type>double precision </type> <parameter>sample_percent</parameter></paramdef>
@@ -7564,14 +7564,14 @@ rid | exclude_nodata | include_nodata
 					<funcprototype>
 					</funcprototype>
 					<funcprototype>
 					</funcprototype>
@@ -8132,7 +8132,7 @@ FROM (SELECT band, ST_SummaryStats('o_4_boston','rast', band,true,0.25) As stats
 				<funcsynopsis>
 					<funcprototype>
 						<funcdef>summarystats <function>ST_SummaryStatsAgg</function></funcdef>
@@ -8140,14 +8140,14 @@ FROM (SELECT band, ST_SummaryStats('o_4_boston','rast', band,true,0.25) As stats
 					<funcprototype>
 					</funcprototype>
 					<funcprototype>
 					</funcprototype>
Summary of changes:
 doc/reference_raster.xml | 14 +++++++-------
 1 file changed, 7 insertions(+), 7 deletions(-)
hooks/post-receive
