[postgis-tickets] [SCM] PostGIS branch stable-2.4 updated. b97fa93fbcfeae2c05f93c77f635adf055a4065d
Wed Apr 22 10:23:15 PDT 2020
the project "PostGIS".
The branch, stable-2.4 has been updated
       via  b97fa93fbcfeae2c05f93c77f635adf055a4065d (commit)
      from  eca3164120cc7beeafcef8e7eb6ce815dab3b811 (commit)
revisions in full, below.
commit b97fa93fbcfeae2c05f93c77f635adf055a4065d
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Apr 22 19:23:03 2020 +0200
    [drone] Pull build-test docker image from OSGeo server
    And drop old drone config
diff --git a/.drone-1.0.yml b/.drone-1.0.yml
index 22adb6b..185ef5c 100644
--- a/.drone-1.0.yml
+++ b/.drone-1.0.yml
@@ -4,7 +4,7 @@
 # See https://git.osgeo.org/gitea/postgis/postgis-docker
 # todo: add docker images from https://hub.docker.com/r/postgis/postgis-build-env/tags/
-test-image: &test-image docker.kbt.io/postgis/build-test:trisquel2
+test-image: &test-image docker.osgeo.org/postgis/build-test:trisquel2
 kind: pipeline
 steps:
@@ -27,7 +27,7 @@ steps:
       - utils/check_all_upgrades.sh -s
         `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
 kind: pipeline
 steps:
@@ -50,7 +50,7 @@ steps:
 kind: pipeline
 steps:
@@ -73,7 +73,7 @@ steps:
 kind: pipeline
 steps:
@@ -96,7 +96,7 @@ steps:
 kind: pipeline
 steps:
diff --git a/.drone.yml b/.drone.yml
deleted file mode 100644
index 62a16d7..0000000
--- a/.drone.yml
+++ /dev/null
@@ -1,35 +0,0 @@
-# See http://readme.drone.io/0.5/usage/overview
-# See https://git.osgeo.org/gitea/postgis/postgis-docker
-matrix:
-  PGVER:
-    - 9.3
-    - 9.4
-    - 9.5
-    - 9.6
-    - 10
-pipeline:
-  clone:
-    image: plugins/git
-    depth: 20
-    recursive: false
-  build:
-    image: *test-image
-    pull: true
-    commands:
-      - service postgresql start $PGVER
-      - export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
-      - export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
-      - psql --version
-      - ./autogen.sh
-      - ./configure CFLAGS="-O0 -Wall -fno-omit-frame-pointer" --without-interrupt-tests
-      - make
-      # we should maybe wait for postgresql service to startup here...
-      - psql -c "select version()" template1
-      - make check RUNTESTFLAGS=-v
-      - make install
-      - utils/check_all_upgrades.sh
-        `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
Summary of changes:
 .drone-1.0.yml | 10 +++++-----
 .drone.yml     | 35 -----------------------------------
 2 files changed, 5 insertions(+), 40 deletions(-)
 delete mode 100644 .drone.yml
hooks/post-receive
