[postgis-tickets] [PostGIS] #4674: lwgeom_cache doesn't live through not inline functions
trac at osgeo.org
Thu Apr 30 08:52:18 PDT 2020
Reporter: Raúl Marín | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Raúl Marín):
I've been looking for it but I don't see any simple way to get the memory
context of a single query.
So let's describe the 2 options:
* Use `flinfo->fn_mcxt`
- Cache is done per function call.
- Calling `Select ST_Transform(g, 3857), ST_Transform(g2, 3857) from
table` will do 2 cache instantiations.
- Calling the previous query 2 times inside a transaction (`BEGIN;
query; query; END;`) will do 2 x 2 cache instantiations.
- Doesn't work across pure SQL functions (unless inlined).
* Use `CurTransactionContext`.
- Cache is done per transaction.
table` will do only 1 instantiation.
query; query; END;`) will create the cache only once (no matter the amount
of times you call the query).
- Works across "everything", as is kept alive until the end of the
transaction.
This second approach can be considered more dangerous in case of a leak in
the cached objects (as things won't necessarily be deleted immediately)
but considering that the boundaries of all the different caches are well
established I don't expect it to be an issue.
There is a possible "issue" related to doing a transaction with a
ST_Transform, then a modification to spatial_ref_sys, and then another
ST_Transform and expect it to be different (but it isn't because it is
cached). After giving it some thought I don't consider this a problem
since the functions are all labelled as IMMUTABLE, so I don't see a
problem with requesting different transactions if you really want this
kind of behaviour.
What do you all think? If I don't hear big cries I'll clean up the patch
(and break it apart from the changes for #4672) and push it. In any case
I'll leave things to be easily reverted (simply change
`CurTransactionContext` to `flinfo->fn_mcxt`).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4674#comment:4>
