[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-35-gfcc88fa
Sat Aug 1 09:13:33 PDT 2020
the project "PostGIS".
       via  fcc88fa9ce76cc2b93cfd752d770bbb4960b73ba (commit)
      from  7b7e66ae6e8438e125ceda7e413eb141e462b571 (commit)
revisions in full, below.
commit fcc88fa9ce76cc2b93cfd752d770bbb4960b73ba
Author: Raúl Marín <git at rmr.ninja>
Date:   Sat Aug 1 18:11:13 2020 +0200
    Revert "Cunit: Avoid crashing when comparing NULL strings"
    This reverts commit 7b7e66ae6e8438e125ceda7e413eb141e462b571.
    Although it is useful, this raised quite a bit of warnings as
    some of the uses of the macro pass static strings and those
    can't be NULL.
diff --git a/liblwgeom/cunit/cu_tester.h b/liblwgeom/cunit/cu_tester.h
index 3cd0c13..baa5e62 100644
--- a/liblwgeom/cunit/cu_tester.h
+++ b/liblwgeom/cunit/cu_tester.h
@@ -40,21 +40,11 @@ typedef void (*PG_SuiteSetup)(void);
   CU_ASSERT_EQUAL(o,e); \
 } while (0);
-#define ASSERT_STRING_EQUAL(o, e) \
-	do \
-		if ((!(o) && (e)) || (!(e) && (o)) || strcmp((o), (e)) != 0) \
-			fprintf(stderr, \
-				"[%s:%d]\n Expected: %s\n Obtained: %s\n", \
-				__FILE__, \
-				__LINE__, \
-				(e) ? (e) : "NULL", \
-				(o) ? (o) : "NULL"); \
-			CU_FAIL(); \
-		CU_PASS(); \
-	} while (0);
+#define ASSERT_STRING_EQUAL(o,e) do { \
+  if ( strcmp(o,e) != 0 ) \
+    fprintf(stderr, "[%s:%d]\n Expected: %s\n Obtained: %s\n", __FILE__, __LINE__, (e), (o)); \
+  CU_ASSERT_STRING_EQUAL(o,e); \
+} while (0);
 #define ASSERT_VARLENA_EQUAL(v, s) \
 	do \
Summary of changes:
 liblwgeom/cunit/cu_tester.h | 20 +++++---------------
 1 file changed, 5 insertions(+), 15 deletions(-)
hooks/post-receive
