[postgis-tickets] [PostGIS] #4541: ST_ConcaveHull returns a "geometrycollection" type instead of the expected "polygon"
trac at osgeo.org
Sat Aug 1 16:49:03 PDT 2020
"polygon"
Reporter: v89461 | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.5.5
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
I was hoping I could blame this on GEOS, but seems with GEOS 3.8, all is
good with 2.4.7
POSTGIS="2.4.7 r17322" PGSQL="100" GEOS="3.8.0-CAPI-1.13.1 " PROJ="Rel.
5.2.0, September 15th, 2018" GDAL="GDAL 2.4.4, released 2020/01/08"
LIBXML="2.7.8" LIBJSON="0.12" LIBPROTOBUF="1.2.1" RASTER
Yields -
POLYGON((578430.72 1226431.49,578423.79 1226455.51,579600.81
1226795.01,580801.84 1227141.44,581978.86 1227480.95,582963.7
1227765.03,583324.01 1227868.96,584501.03 1228208.46,585702.06
1228554.89,586879.08 1228894.4,588056.09 1229233.9,589257.12
1229580.34,590434.14 1229919.84,591611.15 1230259.35,592788.17
1230598.85,593989.2 1230945.29,595166.21 1231284.79,596343.23
1231624.3,597544.26 1231970.73,597616.32 1231991.52,598793.34
1232331.02,599610.04 1232566.6,599706.12 1232594.31,599730.15
1232601.24,598553.13 1232261.73,597352.1 1231915.3,596175.08
1231575.79,595893.76 1231468.63,595869.74 1231461.7,595821.7
1231447.84,595629.54 1231392.41,594452.52 1231052.91,593251.49
1230706.48,592074.47 1230366.97,590897.46 1230027.47,589696.43
1229681.03,588519.41 1229341.53,587342.4 1229002.02,586165.38
1228662.52,585492.81 1228468.51,585132.5 1228364.58,583955.48
1228025.08,582754.45 1227678.65,581577.43 1227339.14,580400.42
1226999.64,580256.3 1226958.06,579079.28 1226618.56,578622.89
1226486.91,578454.74 1226438.41,578430.72 1226431.49))
3.1.0dev no surprise has the same issue
POSTGIS="3.1.0dev 3.1.0alpha2-33-g626556b35" [EXTENSION] PGSQL="130"
GEOS="3.9.0-CAPI-1.14.0" SFCGAL="1.3.8" PROJ="6.2.1" GDAL="GDAL 3.0.2,
released 2019/10/28" LIBXML="2.9.9" LIBJSON="0.12" LIBPROTOBUF="1.2.1"
WAGYU="0.5.0 (Internal)" (core procs from "3.1.0dev
3.1.0alpha2-23-g81b9af77b" need upgrade) RASTER (raster procs from
"3.1.0dev 3.1.0alpha2-23-g81b9af77b" need upgrade) (sfcgal procs from
GEOMETRYCOLLECTION(POINT(578615.96 1226510.94),POINT(578760.08
1226552.51),POINT(578784.1 1226559.44),POINT(578928.23
1226601.01),POINT(578952.25 1226607.94),POINT(578976.27
1226614.87),POINT(578983.2000000001 1226590.84),POINT(579007.22
1226597.77),POINT(579072.35 1226642.58),POINT(579096.37
1226649.51),POINT(579120.39 1226656.44),POINT(579144.41
1226663.37),POINT(579175.36 1226646.27),POINT(579199.38
1226653.2),POINT(579223.41 1226660.1300000001),POINT(579240.5
1226691.08),POINT(579247.43 1226667.06),POINT(579264.52
1226698.01),POINT(579288.54 1226704.94),POINT(579312.56
1226711.87),POINT(579336.58 1226718.8),POINT(579343.51
1226694.77),POINT(579367.53 1226701.7),POINT(579384.62
1226732.6500000001),POINT(579391.55 1226708.6300000001),POINT(579408.64
1226739.58),POINT(579415.5700000001 1226715.56),POINT(579432.66
1226746.51),POINT(579456.68 1226753.44),POINT(579480.7000000001
1226760.37),POINT(579504.73 1226767.3),POINT(579535.67
1226750.2),POINT(579559.7000000001 1226757.1300000001),POINT(579576.79
1226788.08),POINT(579583.72 1226764.06),POINT(579600.81
1226795.01),POINT(579607.74 1226770.99),POINT(579624.83
1226801.94),POINT(579648.85 1226808.87),POINT(579672.87
1226815.8),POINT(579696.89 1226822.73),POINT(579703.8200000001
1226798.7),POINT(579720.91 1226829.6500000001),POINT(579727.84
1226805.6300000001),POINT(579744.93 1226836.58),POINT(579751.86
1226812.56),POINT(579768.9500000001 1226843.51),POINT(579792.97
1226850.44),POINT(579816.99 1226857.37),POINT(579841.01
1226864.3),POINT(579865.04 1226871.23),POINT(579895.98
1226854.1300000001),POINT(579920.01 1226861.06),POINT(579937.1
1226892.01),POINT(579961.12 1226898.94),POINT(579985.14
1226905.87),POINT(580009.16 1226912.8),POINT(580033.18
1226919.73),POINT(580057.2000000001 1226926.66),POINT(580064.13
1226902.6300000001),POINT(580105.24 1226940.51),POINT(580129.26
1226947.44),POINT(580153.28 1226954.37),POINT(580177.3
1226961.3),POINT(580201.33 1226968.23),POINT(580225.35
1226975.16),POINT(580249.37 1226982.09),POINT(580321.43
1227002.87),POINT(580345.4500000001 1227009.8),POINT(580369.47
1227016.73),POINT(580393.49 1227023.66),POINT(580417.51
1227030.59),POINT(580489.5700000001 1227051.37),POINT(580513.59
1227058.3),POINT(580537.61 1227065.23),POINT(580561.64
1227072.16),POINT(580585.66 1227079.09),POINT(580609.68
1227086.02),POINT(580616.61 1227061.99),POINT(580640.63
1227068.92),POINT(580705.76 1227113.73),POINT(580729.78
1227120.66),POINT(580753.8 1227127.59),POINT(580777.8200000001
1227134.52),POINT(580808.77 1227117.42),POINT(580832.79
1227124.35),POINT(580849.88 1227155.3),POINT(580873.9
1227162.23),POINT(580921.9500000001 1227176.09),POINT(580945.97
1227183.02),POINT(580969.99 1227189.95),POINT(580976.92
1227165.92),POINT(581000.9400000001 1227172.85),POINT(581024.96
1227179.78),POINT(581048.98 1227186.71),POINT(581090.09
1227224.59),POINT(581114.11 1227231.52),POINT(581138.13
1227238.45),POINT(581169.08 1227221.35),POINT(581193.1
1227228.28),POINT(581217.12 1227235.21),POINT(581234.21
1227266.16),POINT(581306.28 1227286.95),POINT(581330.3
1227293.8800000001),POINT(581337.23 1227269.85),POINT(581361.25
1227276.78),POINT(581385.27 1227283.71),POINT(581409.29
1227290.6400000001),POINT(581433.31 1227297.57),POINT(581474.42
1227335.45),POINT(581498.4400000001 1227342.3800000001),POINT(581529.39
1227325.28),POINT(581553.41 1227332.21),POINT(581577.43
1227339.1400000001),POINT(581601.4500000001 1227346.07),POINT(581649.5
1227359.93),POINT(581690.61 1227397.81),POINT(581697.54
1227373.78),POINT(581721.56 1227380.71),POINT(581745.58
1227387.6400000001),POINT(581769.6 1227394.57),POINT(581793.62
1227401.5),POINT(581817.64 1227408.43),POINT(581858.75
1227446.31),POINT(581889.7000000001 1227429.21),POINT(581913.72
1227436.1400000001),POINT(581937.74 1227443.07),POINT(581961.76
1227450),POINT(581985.78 1227456.93),POINT(582009.81
1227463.86),POINT(582033.83 1227470.79),POINT(582050.92
1227501.74),POINT(582057.85 1227477.71),POINT(582081.87
1227484.6400000001),POINT(582105.89 1227491.57),POINT(582129.91
1227498.5),POINT(582153.93 1227505.43),POINT(582177.9500000001
1227512.36),POINT(582219.06 1227550.24),POINT(582250.01
1227533.1400000001),POINT(582274.03 1227540.07),POINT(582298.05
1227547),POINT(582322.0700000001 1227553.93),POINT(582346.1
1227560.86),POINT(582370.12 1227567.79),POINT(582418.16
1227581.6400000001),POINT(582442.18 1227588.57),POINT(582466.2000000001
1227595.5),POINT(582490.22 1227602.43),POINT(582514.24
1227609.36),POINT(582610.3200000001 1227637.07),POINT(582634.34
1227644),POINT(582658.36 1227650.93),POINT(582706.41
1227664.79),POINT(582778.47 1227685.57),POINT(582802.49
1227692.5),POINT(582826.51 1227699.43),POINT(582850.53
1227706.36),POINT(582970.63 1227741),POINT(582994.65
1227747.93),POINT(583042.7000000001 1227761.79),POINT(583162.8
1227796.43),POINT(583330.9400000001 1227844.93),POINT(583523.11
1227900.36),POINT(583547.13 1227907.29),POINT(583636.28
1227959.03),POINT(583660.3 1227965.96),POINT(583684.33
1227972.8900000001),POINT(583691.25 1227948.86),POINT(583715.27
1227955.79),POINT(583739.3 1227962.72),POINT(583763.3200000001
1227969.6500000001),POINT(583828.4500000001 1228014.46),POINT(583852.47
1228021.3900000001),POINT(583883.42 1228004.29),POINT(583907.4400000001
1228011.22),POINT(583931.46 1228018.1500000001),POINT(583948.55
1228049.1),POINT(583972.5700000001 1228056.03),POINT(583996.59
1228062.96),POINT(584020.61 1228069.8900000001),POINT(584044.64
1228076.82),POINT(584051.56 1228052.79),POINT(584075.58
1228059.72),POINT(584099.61 1228066.6500000001),POINT(584123.63
1228073.58),POINT(584140.72 1228104.53),POINT(584164.74
1228111.46),POINT(584188.76 1228118.3900000001),POINT(584212.78
1228125.32),POINT(584243.73 1228108.22),POINT(584260.8200000001
1228139.17),POINT(584267.75 1228115.1500000001),POINT(584284.84
1228146.1),POINT(584308.86 1228153.03),POINT(584332.88
1228159.96),POINT(584356.9 1228166.8900000001),POINT(584380.93
1228173.82),POINT(584404.9500000001 1228180.75),POINT(584411.87
1228156.72),POINT(584435.9 1228163.6500000001),POINT(584452.99
1228194.6),POINT(584459.92 1228170.58),POINT(584477.01
1228201.53),POINT(584501.03 1228208.46),POINT(584525.05
1228215.3900000001),POINT(584549.0700000001 1228222.32),POINT(584573.09
1228229.25),POINT(584597.11 1228236.17),POINT(584604.04
1228212.1500000001),POINT(584621.13 1228243.1),POINT(584645.15
1228250.03),POINT(584669.17 1228256.96),POINT(584693.1900000001
1228263.8900000001),POINT(584717.21 1228270.82),POINT(584741.24
1228277.75),POINT(584765.26 1228284.68),POINT(584796.21
1228267.58),POINT(584813.3 1228298.53),POINT(584837.3200000001
1228305.46),POINT(584861.34 1228312.3900000001),POINT(584885.36
1228319.32),POINT(584909.38 1228326.25),POINT(584933.4
1228333.18),POINT(584981.4400000001 1228347.03),POINT(585005.46
1228353.96),POINT(585029.48 1228360.8900000001),POINT(585053.5
1228367.82),POINT(585077.53 1228374.75),POINT(585101.55
1228381.68),POINT(585125.5700000001 1228388.61),POINT(585173.61
1228402.46),POINT(585197.63 1228409.3900000001),POINT(585221.65
1228416.32),POINT(585245.67 1228423.25),POINT(585269.6900000001
1228430.18),POINT(585293.71 1228437.11),POINT(585341.75
1228450.96),POINT(585365.77 1228457.8900000001),POINT(585389.79
1228464.82),POINT(585413.81 1228471.75),POINT(585437.84
1228478.68),POINT(585461.86 1228485.61),POINT(585485.88
1228492.54),POINT(585557.9400000001 1228513.32),POINT(585581.96
1228520.25),POINT(585605.98 1228527.18),POINT(585630
1228534.11),POINT(585654.02 1228541.04),POINT(585678.04
1228547.97),POINT(585702.06 1228554.8900000001),POINT(585726.08
1228561.82),POINT(585750.1 1228568.75),POINT(585774.13
1228575.68),POINT(585798.15 1228582.61),POINT(585822.17
1228589.54),POINT(585846.1900000001 1228596.47),POINT(585894.23
1228610.32),POINT(585918.25 1228617.25),POINT(585942.27
1228624.18),POINT(585966.29 1228631.11),POINT(585990.31
1228638.04),POINT(586014.33 1228644.97),POINT(586038.35
1228651.9000000001),POINT(586062.37 1228658.82),POINT(586086.39
1228665.75),POINT(586110.41 1228672.68),POINT(586134.4400000001
1228679.61),POINT(586158.46 1228686.54),POINT(586182.48
1228693.47),POINT(586206.5 1228700.4000000001),POINT(586237.4500000001
1228683.3),POINT(586278.56 1228721.18),POINT(586302.58
1228728.11),POINT(586326.6 1228735.04),POINT(586350.62
1228741.97),POINT(586374.64 1228748.9000000001),POINT(586398.66
1228755.83),POINT(586405.59 1228731.8),POINT(586422.68
1228762.75),POINT(586446.7000000001 1228769.68),POINT(586470.73
1228776.61),POINT(586494.75 1228783.54),POINT(586518.77
1228790.47),POINT(586542.79 1228797.4000000001),POINT(586566.81
1228804.33),POINT(586597.76 1228787.23),POINT(586638.87
1228825.11),POINT(586662.89 1228832.04),POINT(586686.91
1228838.97),POINT(586710.93 1228845.9000000001),POINT(586734.9500000001
1228852.83),POINT(586758.97 1228859.76),POINT(586765.9
1228835.73),POINT(586782.99 1228866.68),POINT(586807.01
1228873.61),POINT(586831.04 1228880.54),POINT(586855.06
1228887.47),POINT(586879.08 1228894.4000000001),POINT(586903.1
1228901.33),POINT(586927.12 1228908.26),POINT(586958.0700000001
1228891.16),POINT(586982.09 1228898.09),POINT(586999.18
1228929.04),POINT(587023.2000000001 1228935.97),POINT(587047.22
1228942.9000000001),POINT(587071.24 1228949.83),POINT(587095.26
1228956.76),POINT(587119.28 1228963.69),POINT(587126.21
1228939.66),POINT(587150.23 1228946.59),POINT(587191.35
1228984.47),POINT(587215.37 1228991.4000000001),POINT(587239.39
1228998.33),POINT(587263.41 1229005.26),POINT(587287.43
1229012.19),POINT(587318.38 1228995.09),POINT(587342.4
1229002.02),POINT(587359.49 1229032.97),POINT(587366.42
1229008.95),POINT(587383.51 1229039.9000000001),POINT(587407.53
1229046.83),POINT(587431.55 1229053.76),POINT(587455.5700000001
1229060.69),POINT(587479.59 1229067.62),POINT(587486.52
1229043.59),POINT(587510.54 1229050.52),POINT(587534.56
1229057.45),POINT(587575.68 1229095.33),POINT(587582.61
1229071.31),POINT(587599.7000000001 1229102.26),POINT(587623.72
1229109.19),POINT(587647.74 1229116.12),POINT(587678.6900000001
1229099.02),POINT(587702.71 1229105.95),POINT(587726.73
1229112.8800000001),POINT(587743.8200000001 1229143.83),POINT(587767.84
1229150.76),POINT(587791.86 1229157.69),POINT(587815.88
1229164.62),POINT(587839.9 1229171.55),POINT(587846.83
1229147.52),POINT(587870.85 1229154.45),POINT(587894.87
1229161.3800000001),POINT(587918.9 1229168.31),POINT(587935.99
1229199.26),POINT(587942.92 1229175.24),POINT(587960.01
1229206.19),POINT(587984.03 1229213.12),POINT(588008.05
1229220.05),POINT(588039 1229202.95),POINT(588063.02
1229209.8800000001),POINT(588087.04 1229216.81),POINT(588104.13
1229247.76),POINT(588111.06 1229223.74),POINT(588128.15
1229254.69),POINT(588152.17 1229261.62),POINT(588176.1900000001
1229268.55),POINT(588200.21 1229275.48),POINT(588207.14
1229251.45),POINT(588231.16 1229258.3800000001),POINT(588255.18
1229265.31),POINT(588279.21 1229272.24),POINT(588296.3
1229303.19),POINT(588303.23 1229279.17),POINT(588320.3200000001
1229310.12),POINT(588327.25 1229286.1),POINT(588344.34
1229317.05),POINT(588368.36 1229323.98),POINT(588392.38
1229330.91),POINT(588399.31 1229306.8800000001),POINT(588423.33
1229313.81),POINT(588447.35 1229320.74),POINT(588464.4400000001
1229351.69),POINT(588471.37 1229327.67),POINT(588488.46
1229358.62),POINT(588495.39 1229334.6),POINT(588512.48
1229365.55),POINT(588536.5 1229372.48),POINT(588560.52
1229379.41),POINT(588591.47 1229362.31),POINT(588615.5
1229369.24),POINT(588639.52 1229376.17),POINT(588663.54
1229383.1),POINT(588680.63 1229414.05),POINT(588687.56
1229390.03),POINT(588704.65 1229420.98),POINT(588711.58
1229396.96),POINT(588728.67 1229427.91),POINT(588752.6900000001
1229434.84),POINT(588759.62 1229410.81),POINT(588783.64
1229417.74),POINT(588807.66 1229424.67),POINT(588831.68
1229431.6),POINT(588848.77 1229462.55),POINT(588855.7000000001
1229438.53),POINT(588872.79 1229469.48),POINT(588896.81
1229476.41),POINT(588920.84 1229483.34),POINT(588951.78
1229466.24),POINT(588975.81 1229473.17),POINT(588999.83
1229480.1),POINT(589023.85 1229487.03),POINT(589040.9400000001
1229517.98),POINT(589047.87 1229493.96),POINT(589064.96
1229524.91),POINT(589071.89 1229500.8900000001),POINT(589088.98
1229531.84),POINT(589113 1229538.77),POINT(589119.93
1229514.74),POINT(589143.9500000001 1229521.67),POINT(589167.97
1229528.6),POINT(589191.99 1229535.53),POINT(589209.08
1229566.48),POINT(589216.01 1229542.46),POINT(589233.1
1229573.41),POINT(589240.03 1229549.3900000001),POINT(589257.12
1229580.34),POINT(589281.15 1229587.27),POINT(589312.1
1229570.17),POINT(589336.12 1229577.1),POINT(589360.14
1229584.03),POINT(589384.16 1229590.96),POINT(589401.25
1229621.91),POINT(589408.18 1229597.8900000001),POINT(589425.27
1229628.84),POINT(589432.2000000001 1229604.82),POINT(589449.29
1229635.77),POINT(589456.22 1229611.75),POINT(589473.31
1229642.7),POINT(589480.24 1229618.67),POINT(589504.26
1229625.6),POINT(589528.28 1229632.53),POINT(589552.3
1229639.46),POINT(589569.39 1229670.41),POINT(589576.3200000001
1229646.3900000001),POINT(589593.41 1229677.34),POINT(589600.34
1229653.32),POINT(589617.4400000001 1229684.27),POINT(589624.36
1229660.25),POINT(589641.46 1229691.2),POINT(589672.41
1229674.1),POINT(589696.43 1229681.03),POINT(589720.4500000001
1229687.96),POINT(589744.47 1229694.8900000001),POINT(589768.49
1229701.82),POINT(589785.58 1229732.77),POINT(589792.51
1229708.75),POINT(589809.6 1229739.7),POINT(589816.53
1229715.68),POINT(589833.62 1229746.6300000001),POINT(589840.55
1229722.6),POINT(589864.5700000001 1229729.53),POINT(589888.59
1229736.46),POINT(589912.61 1229743.3900000001),POINT(589936.63
1229750.32),POINT(589953.72 1229781.27),POINT(589960.65
1229757.25),POINT(589977.75 1229788.2),POINT(589984.67
1229764.18),POINT(590001.77 1229795.1300000001),POINT(590032.72
1229778.03),POINT(590056.74 1229784.96),POINT(590080.76
1229791.8900000001),POINT(590104.78 1229798.82),POINT(590128.8
1229805.75),POINT(590145.89 1229836.7),POINT(590152.8200000001
1229812.68),POINT(590169.91 1229843.6300000001),POINT(590176.84
1229819.61),POINT(590193.93 1229850.56),POINT(590200.86
1229826.53),POINT(590224.88 1229833.46),POINT(590248.9
1229840.3900000001),POINT(590272.92 1229847.32),POINT(590290.01
1229878.27),POINT(590296.9400000001 1229854.25),POINT(590338.06
1229892.1300000001),POINT(590362.08 1229899.06),POINT(590393.03
1229881.96),POINT(590417.05 1229888.8900000001),POINT(590441.0700000001
1229895.82),POINT(590465.09 1229902.75),POINT(590482.18
1229933.7),POINT(590489.11 1229909.68),POINT(590506.2000000001
1229940.6300000001),POINT(590530.22 1229947.56),POINT(590554.24
1229954.49),POINT(590561.17 1229930.46),POINT(590585.1900000001
1229937.3900000001),POINT(590609.21 1229944.32),POINT(590626.3
1229975.27),POINT(590650.3200000001 1229982.2),POINT(590674.35
1229989.1300000001),POINT(590698.37 1229996.06),POINT(590722.39
1230002.99),POINT(590753.34 1229985.8900000001),POINT(590777.36
1229992.82),POINT(590801.38 1229999.75),POINT(590818.47
1230030.7),POINT(590842.49 1230037.6300000001),POINT(590866.51
1230044.56),POINT(590890.53 1230051.49),POINT(590914.55
1230058.42),POINT(590921.48 1230034.3900000001),POINT(590986.61
1230079.2),POINT(591034.66 1230093.06),POINT(591058.68
1230099.99),POINT(591082.7000000001 1230106.92),POINT(591106.72
1230113.85),POINT(591178.78 1230134.6300000001),POINT(591202.8
1230141.56),POINT(591226.8200000001 1230148.49),POINT(591250.84
1230155.42),POINT(591274.86 1230162.35),POINT(591346.92
1230183.1300000001),POINT(591394.97 1230196.99),POINT(591418.99
1230203.92),POINT(591443.01 1230210.85),POINT(591467.03
1230217.78),POINT(591473.96 1230193.75),POINT(591563.11
1230245.49),POINT(591587.13 1230252.42),POINT(591611.15
1230259.35),POINT(591635.17 1230266.28),POINT(591755.28
1230300.92),POINT(591779.3 1230307.85),POINT(591803.3200000001
1230314.78),POINT(591827.34 1230321.71),POINT(591834.27
1230297.68),POINT(591858.29 1230304.61),POINT(591923.42
1230349.42),POINT(591947.4400000001 1230356.35),POINT(591971.46
1230363.28),POINT(591995.48 1230370.21),POINT(592026.43
1230353.11),POINT(592139.61 1230411.78),POINT(592163.63
1230418.71),POINT(592187.65 1230425.6400000001),POINT(592194.58
1230401.61),POINT(592218.6 1230408.54),POINT(592283.73
1230453.35),POINT(592307.75 1230460.28),POINT(592331.77
1230467.21),POINT(592355.79 1230474.1400000001),POINT(592386.74
1230457.04),POINT(592499.92 1230515.71),POINT(592523.9400000001
1230522.6400000001),POINT(592547.96 1230529.57),POINT(592554.89
1230505.54),POINT(592578.91 1230512.47),POINT(592602.93
1230519.4000000001),POINT(592668.06 1230564.21),POINT(592692.08
1230571.1400000001),POINT(592716.1 1230578.07),POINT(592747.05
1230560.97),POINT(592771.0700000001 1230567.9000000001),POINT(592819.12
1230581.76),POINT(592860.23 1230619.6400000001),POINT(592884.25
1230626.57),POINT(592908.27 1230633.5),POINT(592915.2000000001
1230609.47),POINT(592939.22 1230616.4000000001),POINT(592963.24
1230623.33),POINT(592987.26 1230630.26),POINT(593028.37
1230668.1400000001),POINT(593052.39 1230675.07),POINT(593076.41
1230682),POINT(593107.36 1230664.9000000001),POINT(593131.38
1230671.83),POINT(593155.41 1230678.76),POINT(593179.43
1230685.69),POINT(593203.4500000001 1230692.62),POINT(593244.56
1230730.5),POINT(593268.58 1230737.43),POINT(593275.51
1230713.4000000001),POINT(593299.53 1230720.33),POINT(593323.55
1230727.26),POINT(593347.5700000001 1230734.19),POINT(593388.68
1230772.07),POINT(593412.7000000001 1230779),POINT(593436.72
1230785.93),POINT(593467.67 1230768.83),POINT(593491.6900000001
1230775.76),POINT(593515.72 1230782.69),POINT(593539.74
1230789.62),POINT(593563.76 1230796.55),POINT(593604.87
1230834.43),POINT(593628.89 1230841.36),POINT(593635.8200000001
1230817.33),POINT(593659.84 1230824.26),POINT(593683.86
1230831.19),POINT(593707.88 1230838.12),POINT(593731.9
1230845.05),POINT(593773.01 1230882.93),POINT(593797.04
1230889.86),POINT(593821.06 1230896.79),POINT(593827.98
1230872.76),POINT(593852.01 1230879.69),POINT(593876.03
1230886.62),POINT(593900.05 1230893.55),POINT(593924.0700000001
1230900.48),POINT(593948.09 1230907.41),POINT(593965.18
1230938.36),POINT(593989.2000000001 1230945.29),POINT(594020.15
1230928.19),POINT(594044.17 1230935.12),POINT(594068.1900000001
1230942.05),POINT(594092.21 1230948.98),POINT(594116.23
1230955.91),POINT(594133.3200000001 1230986.86),POINT(594181.37
1231000.72),POINT(594188.29 1230976.69),POINT(594212.3200000001
1230983.62),POINT(594236.34 1230990.55),POINT(594260.36
1230997.48),POINT(594284.38 1231004.41),POINT(594308.4
1231011.34),POINT(594332.42 1231018.27),POINT(594349.51
1231049.22),POINT(594380.46 1231032.12),POINT(594404.48
1231039.05),POINT(594428.5 1231045.98),POINT(594452.52
1231052.91),POINT(594476.54 1231059.84),POINT(594541.68
1231104.6500000001),POINT(594548.61 1231080.62),POINT(594572.63
1231087.55),POINT(594596.65 1231094.48),POINT(594620.67
1231101.41),POINT(594644.6900000001 1231108.34),POINT(594668.71
1231115.27),POINT(594709.8200000001 1231153.1500000001),POINT(594740.77
1231136.05),POINT(594764.79 1231142.98),POINT(594788.81
1231149.91),POINT(594812.83 1231156.84),POINT(594901.99
1231208.58),POINT(594908.92 1231184.55),POINT(594932.9400000001
1231191.48),POINT(594956.96 1231198.41),POINT(594980.98
1231205.34),POINT(595046.11 1231250.1500000001),POINT(595070.13
1231257.08),POINT(595101.08 1231239.98),POINT(595125.1
1231246.91),POINT(595262.3 1231312.51),POINT(595269.23
1231288.48),POINT(595293.25 1231295.41),POINT(595430.4400000001
1231361.01),POINT(595622.61 1231416.44),POINT(595790.75
1231464.94),POINT(595982.92 1231520.37),POINT(596151.06
1231568.87),POINT(596535.39 1231679.73),POINT(596895.7000000001
1231783.66),POINT(596919.72 1231790.58),POINT(596943.75
1231797.51),POINT(596967.77 1231804.44),POINT(596991.79
1231811.37),POINT(597015.81 1231818.3),POINT(597087.87
1231839.08),POINT(597111.89 1231846.01),POINT(597135.91
1231852.94),POINT(597159.93 1231859.87),POINT(597256.01
1231887.59),POINT(597280.04 1231894.51),POINT(597304.06
1231901.44),POINT(597328.08 1231908.37),POINT(597448.18
1231943.01),POINT(597472.2000000001 1231949.94),POINT(597640.35
1231998.44),POINT(597664.37 1232005.37),POINT(597952.61
1232088.52),POINT(598000.66 1232102.37),POINT(598144.78
1232143.95),POINT(598168.8 1232150.87),POINT(598288.9
1232185.52),POINT(598312.92 1232192.45),POINT(598336.9500000001
1232199.3800000001),POINT(598360.97 1232206.3),POINT(598384.99
1232213.23),POINT(598481.0700000001 1232240.95),POINT(598505.09
1232247.8800000001),POINT(598529.11 1232254.8),POINT(598553.13
1232261.73),POINT(598649.21 1232289.45),POINT(598697.26
1232303.31),POINT(598721.28 1232310.23),POINT(598745.3
1232317.16),POINT(598865.4 1232351.81),POINT(598889.42
1232358.73),POINT(598913.4400000001 1232365.66),POINT(599009.52
1232393.3800000001),POINT(599081.59 1232414.16),POINT(599105.61
1232421.09),POINT(599129.63 1232428.02),POINT(599249.73
1232462.67),POINT(599273.75 1232469.59),POINT(599297.77
1232476.52),POINT(599441.9 1232518.09),POINT(599465.92
1232525.02),POINT(599489.9400000001 1232531.95),POINT(599513.96
1232538.8800000001),POINT(599634.06 1232573.52),POINT(599658.08
1232580.45),POINT(599682.1 1232587.3800000001),POLYGON((578430.72
1226431.49,578423.79 1226455.51,579552.77 1226781.1500000001,580681.74
1227106.8,581834.73 1227439.3800000001,582963.7000000001
1227765.03,583324.01 1227868.96,584428.97 1228187.67,585533.92
1228506.3900000001,586614.85 1228818.18,587719.8
1229136.9000000001,588824.75 1229455.62,589929.7000000001
1229774.34,591010.64 1230086.1300000001,592115.59 1230404.85,593220.54
1230723.57,594325.49 1231042.29,595406.42 1231354.08,596511.37
1231672.8,597616.3200000001 1231991.52,598625.1900000001
1232282.52,599610.04 1232566.6,599706.12 1232594.31,599730.15
1232601.24,598769.3200000001 1232324.09,597808.49 1232046.94,596847.66
1231769.8,595893.76 1231468.6300000001,595869.74
1231461.7,595821.7000000001 1231447.84,595629.54 1231392.41,594500.56
1231066.77,593371.59 1230741.12,592242.62 1230415.47,591113.65
1230089.82,590008.6900000001 1229771.11,588879.72 1229445.46,587750.75
1229119.81,586621.78 1228794.16,585492.81 1228468.51,585132.5
1228364.58,584147.65 1228080.51,583186.8200000001 1227803.36,582201.97
1227519.29,581241.14 1227242.1400000001,580256.3 1226958.06,579439.59
1226722.49,578622.89 1226486.91,578454.74 1226438.41,578430.72
1226431.49)))
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4541#comment:6>
