[postgis-tickets] [PostGIS] #4685: Error upgrading postGIS from 2.4.4 to 2.5.4 on postgres 10.12
trac at osgeo.org
Sat Aug 1 17:07:38 PDT 2020
Reporter: sjezewskisf | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.5.5
Component: build/upgrade/install | Version: 2.5.x
Resolution: worksforme | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => worksforme
Comment:
I'm not able to replicate this issue. I tested upgrading a PostgreSQL
10.5 from PostGIS 2.4.7 to 2.5.5dev and did not run into any issues.
Given that 2.4.4 is many micros behind I suppose some fixes have happened
since then or a fix is already in place in 2.5.5 unreleased.
So I'm marking this as worksforme.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4685#comment:5>
