[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.4-26-g5e2440d
git at osgeo.org
git at osgeo.org
Sat Aug 1 17:27:05 PDT 2020
the project "PostGIS".
The branch, stable-2.5 has been updated
via 5e2440dc19a676523e8b6c99c9afdf777311bc63 (commit)
from a695e0597a89858663a003ede2bd1e566a89e538 (commit)
revisions in full, below.
commit 5e2440dc19a676523e8b6c99c9afdf777311bc63
Author: Regina Obe <lr at pcorp.us>
Date: Sat Aug 1 20:26:55 2020 -0400
Revise ST_ConcaveHull to run for 0.99 as well, ammend NEWs for #4129. Closes #4541 for PostGIS 2.5.5. references #4129 for PostGIS 2.5.5
diff --git a/NEWS b/NEWS
index 38c2314..9586eee 100644
--- a/NEWS
+++ b/NEWS
@@ -7,10 +7,12 @@ PostGIS 2.5.5
- Handle non-closed edge rings by human readable error (Sandro Santilli)
- #4706, Fix crash in ST_ChangeEdgeGeom on corrupted topology (Sandro Santilli)
- #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
- - #4661, Fix access to spatial_ref_sys with a non default schema (Raúl Marín)
+ - #4661,4129, Fix access to spatial_ref_sys with a non default schema (Raúl Marín)
- #4670, ST_AddPoint: Fix bug when a positive position is requested (Raúl Marín)
- #4699, crash on null input to ST_Union(raster, otherarg) (Jaime Casanova, 2ndQuadrant)
- #4691, Fix segfault during gist index creation with empty geometries (Raúl Marín)
+ - #4541, ST_ConcaveHull returns a "geometrycollection"
+ type instead of the expected "polygon" (Regina Obe)
PostGIS 2.5.4
2020/02/28
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 9688fac..315f31f 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -5930,6 +5930,7 @@ $$
LANGUAGE plpgsql IMMUTABLE STRICT _PARALLEL;
-- Availability: 2.0.0
+-- Changed: 2.5.5
-- Changed: 2.5.0
CREATE OR REPLACE FUNCTION ST_ConcaveHull(param_geom geometry, param_pctconvex float, param_allow_holes boolean DEFAULT false) RETURNS geometry AS
@@ -5962,7 +5963,7 @@ $$
RETURN var_resultgeom;
END IF;
END IF;
- IF @extschema at .ST_Dimension(var_resultgeom) > 1 AND param_pctconvex BETWEEN 0 and 0.98 THEN
+ IF @extschema at .ST_Dimension(var_resultgeom) > 1 AND param_pctconvex BETWEEN 0 and 0.99 THEN
-- get linestring that forms envelope of geometry
var_enline := @extschema at .ST_Boundary(@extschema at .ST_Envelope(var_param_geom));
var_buf := @extschema at .ST_Length(var_enline)/1000.0;
Summary of changes:
NEWS | 4 +++-
postgis/postgis.sql.in | 3 ++-
2 files changed, 5 insertions(+), 2 deletions(-)
hooks/post-receive
