[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-37-g95a3cf4
Mon Aug 3 03:22:21 PDT 2020
the project "PostGIS".
       via  95a3cf4c9dcd04977bf2ff1ed700156694a43344 (commit)
      from  25825b61d26844c794d7f6c8f47dc3f5458c9c95 (commit)
revisions in full, below.
commit 95a3cf4c9dcd04977bf2ff1ed700156694a43344
Author: Raúl Marín <git at rmr.ninja>
Date:   Mon Aug 3 11:42:28 2020 +0200
    Rework ASSERT_STRING_EQUAL to not crash on NULL inputs
diff --git a/liblwgeom/Makefile.in b/liblwgeom/Makefile.in
index 03ce001..5470f9a 100644
--- a/liblwgeom/Makefile.in
+++ b/liblwgeom/Makefile.in
@@ -202,6 +202,7 @@ check: check-unit
 check-regress:
+.PHONY: check-unit
 check-unit: liblwgeom.la
 	$(MAKE) -C cunit check
diff --git a/liblwgeom/cunit/Makefile.in b/liblwgeom/cunit/Makefile.in
index be2dd97..a228a3d 100644
--- a/liblwgeom/cunit/Makefile.in
+++ b/liblwgeom/cunit/Makefile.in
@@ -89,13 +89,14 @@ else
 all: cu_tester
 # Build and run the unit tester
+.PHONY: check
 check: cu_tester
 	$(LIBTOOL) --mode=execute $(LIBTOOL_VALGRIND) ./cu_tester
 endif
 # Build the main unit test executable
-cu_tester: ../liblwgeom.la $(OBJS)
+cu_tester: ../liblwgeom.la $(OBJS) cu_tester.h
 	$(LIBTOOL) --mode=link $(CC) $(CFLAGS) -o $@ $(OBJS) $(LDFLAGS) -static ../liblwgeom.la
 # Command to build each of the .o files
diff --git a/liblwgeom/cunit/cu_tester.h b/liblwgeom/cunit/cu_tester.h
index baa5e62..6c253d5 100644
--- a/liblwgeom/cunit/cu_tester.h
+++ b/liblwgeom/cunit/cu_tester.h
@@ -14,6 +14,7 @@
 #define _CU_TESTER_H 1
 #include "liblwgeom.h"
+#include <stdio.h>
 #define MAX_CUNIT_ERROR_LENGTH 512
@@ -40,11 +41,25 @@ typedef void (*PG_SuiteSetup)(void);
   CU_ASSERT_EQUAL(o,e); \
 } while (0);
-#define ASSERT_STRING_EQUAL(o,e) do { \
-  if ( strcmp(o,e) != 0 ) \
-    fprintf(stderr, "[%s:%d]\n Expected: %s\n Obtained: %s\n", __FILE__, __LINE__, (e), (o)); \
-  CU_ASSERT_STRING_EQUAL(o,e); \
-} while (0);
+static inline void
+assert_string_equal_impl(const char *obtained, const char *expected, const char *file, int line)
+	CU_BOOL error = (!obtained && expected) || (obtained && !expected) || (strcmp(obtained, expected) != 0);
+	char *msg = NULL;
+	if (error)
+		msg = lwalloc(60 + (obtained ? strlen(obtained) : 4) + (expected ? strlen(expected) : 4));
+		sprintf(msg,
+			"ASSERT_STRING_EQUAL\n\t* Expected: %s\n\t* Obtained: %s",
+			expected ? expected : "NULL",
+			obtained ? obtained : "NULL");
+	CU_assertImplementation(!error, line, msg, file, NULL, CU_FALSE);
+	if (msg)
+		lwfree(msg);
+#define ASSERT_STRING_EQUAL(o, e) assert_string_equal_impl(o, e, __FILE__, __LINE__)
 #define ASSERT_VARLENA_EQUAL(v, s) \
 	do \
Summary of changes:
 liblwgeom/Makefile.in       |  1 +
 liblwgeom/cunit/Makefile.in |  3 ++-
 liblwgeom/cunit/cu_tester.h | 25 ++++++++++++++++++++-----
 3 files changed, 23 insertions(+), 6 deletions(-)
hooks/post-receive
