[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-39-geedc336
Mon Aug 3 06:54:20 PDT 2020
the project "PostGIS".
       via  eedc33684e18b292091d033da53f2ba734a15e23 (commit)
       via  377b845629355299c536d851e33a3b4ca9644ca5 (commit)
      from  95a3cf4c9dcd04977bf2ff1ed700156694a43344 (commit)
revisions in full, below.
commit eedc33684e18b292091d033da53f2ba734a15e23
Author: Raúl Marín <git at rmr.ninja>
Date:   Mon Aug 3 13:28:54 2020 +0200
    Normalize for OverlayNG
    References #4730
diff --git a/regress/core/mvt.sql b/regress/core/mvt.sql
index d0513ca..c813d84 100644
--- a/regress/core/mvt.sql
+++ b/regress/core/mvt.sql
@@ -269,10 +269,10 @@ SELECT 'PG42 - OFF', ST_AsText(ST_AsMVTGeom(
 	10, 0, false));
 -- Invalid polygon (intersection)
-SELECT 'PG43 - ON ', ST_AsText(ST_AsMVTGeom(
+SELECT 'PG43 - ON ', ST_AsText(ST_Normalize(ST_AsMVTGeom(
 	ST_GeomFromText('POLYGON((-10 -10, 110 110, -10 110, 110 -10, -10 -10))'),
 	ST_MakeBox2D(ST_Point(0, 0), ST_Point(100, 100)),
-	10, 0, true));
+	10, 0, true)));
 SELECT 'PG43 - OFF', ST_AsText(ST_AsMVTGeom(
@@ -365,13 +365,13 @@ SELECT 'PG56', ST_AsText(ST_AsMVTGeom(
 -- Different round behaviour between geos and wagyu
 WITH geometry AS
-    SELECT ST_AsText(ST_AsMVTGeom(
+    SELECT ST_AsText(ST_Normalize(ST_AsMVTGeom(
 	ST_GeomFromText('POLYGON((0 0, 0 99, 1 101, 100 100, 100 0, 0 0))'),
-	100, 0, true)) as g
+	100, 0, true))) as g
 SELECT 'PG57',
-        g = 'POLYGON((100 0,100 100,0 100,0 1,1 0,100 0))' OR g = 'POLYGON((0 1,0 0,100 0,100 100,0 100,0 1))'
+        g = 'POLYGON((0 1,0 100,100 100,100 0,1 0,0 1))' OR g = 'POLYGON((0 0,0 1,0 100,100 100,100 0,0 0))'
 FROM geometry;
 -- Geometrycollection test
diff --git a/regress/core/mvt_expected b/regress/core/mvt_expected
index e88d4b0..ece6d12 100644
--- a/regress/core/mvt_expected
+++ b/regress/core/mvt_expected
@@ -49,7 +49,7 @@ PG41 - ON |LINESTRING(0 10,0 4,0 2,0 0,1 0)
 PG41 - OFF|LINESTRING(0 10,0 4,0 2,0 0,1 0)
 PG42 - ON |LINESTRING(0 10,0 0,1 0)
 PG42 - OFF|LINESTRING(0 10,0 0,1 0)
-PG43 - ON |MULTIPOLYGON(((5 5,0 0,10 0,5 5)),((5 5,10 10,0 10,5 5)))
+PG43 - ON |MULTIPOLYGON(((0 10,10 10,5 5,0 10)),((0 0,5 5,10 0,0 0)))
 PG43 - OFF|MULTIPOLYGON(((5 5,-1 -1,11 -1,5 5)),((5 5,11 11,-1 11,5 5)))
 PG44|
 PG45|
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index fb6cda3..83a0ff1 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -792,9 +792,9 @@ SELECT '#2412', ST_AsText(ST_LineToCurve('LINESTRING(0 0,10 0,20 0)'));
 SELECT '#2420.1', ST_AsText(ST_LineToCurve('LINESTRING(0 0,10 0,10 10,0 10,0 0)'));
 SELECT '#2420.2', ST_AsText(ST_LineToCurve('LINESTRING(0 0,10 0,10 10,0 10)'));
-SELECT '#2423', ST_AsText(ST_Normalize(ST_CurveToLine(ST_LineToCurve(
-  ST_Intersection(ST_Buffer(ST_Point(0,0),10),ST_MakeEnvelope(-10,0,10,10))
-), 4)), 3);
+SELECT '#2423', ST_AsText(ST_CurveToLine(ST_LineToCurve(
+    ST_Normalize(ST_Intersection(ST_Buffer(ST_Point(0,0),10),ST_MakeEnvelope(-10,0,10,10)))
+), 4), 3);
 SELECT '#2424', ST_AsText(ST_SnapToGrid(ST_CurveToLine(
   'MULTICURVE(COMPOUNDCURVE((0 0, 10 0),CIRCULARSTRING(10 0, 20 1, 30 10)))',
commit 377b845629355299c536d851e33a3b4ca9644ca5
Date:   Mon Aug 3 13:30:12 2020 +0200
    cu_split: Improve format to ease debugging
diff --git a/liblwgeom/cunit/cu_split.c b/liblwgeom/cunit/cu_split.c
index 6481c63..0a81bdf 100644
--- a/liblwgeom/cunit/cu_split.c
+++ b/liblwgeom/cunit/cu_split.c
@@ -83,177 +83,154 @@ static void test_lwgeom_split(void)
 	LWGEOM *geom, *blade, *ret;
 	char *wkt, *in_wkt;
-	geom = lwgeom_from_wkt(
-"MULTILINESTRING((-5 -2,0 0),(0 0,10 10))",
-	LW_PARSER_CHECK_NONE);
+	geom = lwgeom_from_wkt("MULTILINESTRING((-5 -2,0 0),(0 0,10 10))", LW_PARSER_CHECK_NONE);
 	CU_ASSERT(geom != NULL);
-	blade = lwgeom_from_wkt(
-		"POINT(0 0)",
+	blade = lwgeom_from_wkt("POINT(0 0)", LW_PARSER_CHECK_NONE);
 	CU_ASSERT(blade != NULL);
 	ret = lwgeom_split(geom, blade);
 	CU_ASSERT(ret != NULL);
 	wkt = lwgeom_to_ewkt(ret);
 	in_wkt = "GEOMETRYCOLLECTION(LINESTRING(-5 -2,0 0),LINESTRING(0 0,10 10))";
-        if (strcmp(in_wkt, wkt))
-                fprintf(stderr, "\nExp:  %s\nObt:  %s\n", in_wkt, wkt);
-	CU_ASSERT_STRING_EQUAL(wkt, in_wkt);
+	ASSERT_STRING_EQUAL(wkt, in_wkt);
 	lwfree(wkt);
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
         /* See #1311 */
-                "LINESTRING(0 0,10 0,20 4,0 3)",
-        CU_ASSERT(geom != NULL);
-        blade = lwgeom_from_wkt("POINT(10 0)", LW_PARSER_CHECK_NONE);
-        ret = lwgeom_split(geom, blade);
-        CU_ASSERT(ret != NULL);
-        wkt = lwgeom_to_ewkt(ret);
+	geom = lwgeom_from_wkt("LINESTRING(0 0,10 0,20 4,0 3)", LW_PARSER_CHECK_NONE);
+	CU_ASSERT(geom != NULL);
+	blade = lwgeom_from_wkt("POINT(10 0)", LW_PARSER_CHECK_NONE);
+	ret = lwgeom_split(geom, blade);
+	CU_ASSERT(ret != NULL);
+	wkt = lwgeom_to_ewkt(ret);
 	in_wkt = "GEOMETRYCOLLECTION(LINESTRING(0 0,10 0),LINESTRING(10 0,20 4,0 3))";
-        lwfree(wkt);
+	lwfree(wkt);
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
   /* See #2528 (1) -- memory leak test, needs valgrind to check */
-  geom = lwgeom_from_wkt("SRID=1;LINESTRING(0 1,10 1)", LW_PARSER_CHECK_NONE);
-  blade = lwgeom_from_wkt("LINESTRING(7 0,7 3)", LW_PARSER_CHECK_NONE);
+	geom = lwgeom_from_wkt("SRID=1;LINESTRING(0 1,10 1)", LW_PARSER_CHECK_NONE);
+	blade = lwgeom_from_wkt("LINESTRING(7 0,7 3)", LW_PARSER_CHECK_NONE);
 	in_wkt = "SRID=1;GEOMETRYCOLLECTION(LINESTRING(0 1,7 1),LINESTRING(7 1,10 1))";
-  lwfree(wkt);
+	lwfree(wkt);
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
   /* See #2528 (2) -- memory leak test, needs valgrind to check */
-  geom = lwgeom_from_wkt("SRID=1;POLYGON((0 1, 10 1, 10 10, 0 10, 0 1))", LW_PARSER_CHECK_NONE);
-  blade = lwgeom_from_wkt("LINESTRING(7 0,7 20)", LW_PARSER_CHECK_NONE);
+	geom = lwgeom_from_wkt("SRID=1;POLYGON((0 1, 10 1, 10 10, 0 10, 0 1))", LW_PARSER_CHECK_NONE);
+	blade = lwgeom_from_wkt("LINESTRING(7 0,7 20)", LW_PARSER_CHECK_NONE);
 	in_wkt = "SRID=1;GEOMETRYCOLLECTION(POLYGON((7 1,0 1,0 10,7 10,7 1)),POLYGON((7 10,10 10,10 1,7 1,7 10)))";
-  lwfree(wkt);
+	lwfree(wkt);
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
   /* Split line by multiline */
-  geom = lwgeom_from_wkt("LINESTRING(0 0, 10 0)", LW_PARSER_CHECK_NONE);
-  CU_ASSERT_FATAL(geom != NULL);
-  blade = lwgeom_from_wkt("MULTILINESTRING((1 1,1 -1),(2 1,2 -1,3 -1,3 1))",
-  if ( ! ret ) printf("%s", cu_error_msg);
-  CU_ASSERT_FATAL(ret != NULL);
-  CU_ASSERT_FATAL(wkt != NULL);
+	geom = lwgeom_from_wkt("LINESTRING(0 0, 10 0)", LW_PARSER_CHECK_NONE);
+	CU_ASSERT_FATAL(geom != NULL);
+	blade = lwgeom_from_wkt("MULTILINESTRING((1 1,1 -1),(2 1,2 -1,3 -1,3 1))", LW_PARSER_CHECK_NONE);
+	if (!ret)
+		printf("%s", cu_error_msg);
+	CU_ASSERT_FATAL(ret != NULL);
+	CU_ASSERT_FATAL(wkt != NULL);
 	in_wkt = "GEOMETRYCOLLECTION(LINESTRING(0 0,1 0),LINESTRING(1 0,2 0),LINESTRING(2 0,3 0),LINESTRING(3 0,10 0))";
-  lwfree(wkt);
+	lwfree(wkt);
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
   /* Split line by polygon (boundary) */
-"POLYGON((1 -2,1 1,2 1,2 -1,3 -1,3 1,11 1,11 -2,1 -2))",
+	blade = lwgeom_from_wkt("POLYGON((1 -2,1 1,2 1,2 -1,3 -1,3 1,11 1,11 -2,1 -2))", LW_PARSER_CHECK_NONE);
+	if (!ret)
-  lwfree(wkt);
+	lwfree(wkt);
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
-  /* Split line by EMPTY polygon (boundary) */
-  blade = lwgeom_from_wkt("POLYGON EMPTY", LW_PARSER_CHECK_NONE);
+	/* Split line by EMPTY polygon (boundary) */
+	blade = lwgeom_from_wkt("POLYGON EMPTY", LW_PARSER_CHECK_NONE);
+	if (!ret)
 	in_wkt = "GEOMETRYCOLLECTION(LINESTRING(0 0,10 0))";
-  lwfree(wkt);
+	lwfree(wkt);
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
   /* Split line by multipolygon (boundary) */
-"MULTIPOLYGON(((1 -1,1 1,2 1,2 -1,1 -1)),((3 -1,3 1,11 1,11 -1,3 -1)))",
+	blade = lwgeom_from_wkt("MULTIPOLYGON(((1 -1,1 1,2 1,2 -1,1 -1)),((3 -1,3 1,11 1,11 -1,3 -1)))",
+				LW_PARSER_CHECK_NONE);
+	if (!ret)
-  lwfree(wkt);
+	lwfree(wkt);
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
-  /* Split line by multipoint */
-  blade = lwgeom_from_wkt("MULTIPOINT(2 0,8 0,4 0)", LW_PARSER_CHECK_NONE);
+	/* Split line by multipoint */
+	blade = lwgeom_from_wkt("MULTIPOINT(2 0,8 0,4 0)", LW_PARSER_CHECK_NONE);
+	if (!ret)
 	in_wkt = "GEOMETRYCOLLECTION(LINESTRING(8 0,10 0),LINESTRING(0 0,2 0),LINESTRING(4 0,8 0),LINESTRING(2 0,4 0))";
-  lwfree(wkt);
+	lwfree(wkt);
 	lwgeom_free(ret);
 	lwgeom_free(geom);
 	lwgeom_free(blade);
-  /* See #3401 -- robustness issue */
-  geom = lwgeom_from_wkt("LINESTRING(-180 0,0 0)", LW_PARSER_CHECK_NONE);
-  blade = lwgeom_from_wkt("POINT(-20 0)", LW_PARSER_CHECK_NONE);
+	/* See #3401 -- robustness issue */
+	geom = lwgeom_from_wkt("LINESTRING(-180 0,0 0)", LW_PARSER_CHECK_NONE);
+	blade = lwgeom_from_wkt("POINT(-20 0)", LW_PARSER_CHECK_NONE);
 		LWCOLLECTION *split = lwgeom_as_lwcollection(ret);
 		LWLINE *l1, *l2;
Summary of changes:
 liblwgeom/cunit/cu_split.c | 205 ++++++++++++++++++++-------------------------
 regress/core/mvt.sql       |  10 +--
 regress/core/mvt_expected  |   2 +-
 regress/core/tickets.sql   |   6 +-
 4 files changed, 100 insertions(+), 123 deletions(-)
hooks/post-receive
