[postgis-tickets] [PostGIS] #4734: Debbie failing regress raster on gdal_polygonize and raster_surface on GDAL 3.2 (GDAL Master)
PostGIS trac at osgeo.org
Mon Aug 3 12:52:46 PDT 2020
3.2 (GDAL Master)
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS GDAL
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"8e4f510903995abde22468a6e9a107021dacde60/git" 8e4f510/git]:
 #!CommitTicketReference repository="git"
 revision="8e4f510903995abde22468a6e9a107021dacde60"
 Fix raster regression for GDAL 3.2, polygonize behavior change. Use area
 and ST_Equals for compare instead of wkt equality. References #4734 for
 PostGIS 3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4734#comment:8>
