[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-43-gb89a6f0
git at osgeo.org
git at osgeo.org
Mon Aug 3 13:41:48 PDT 2020
the project "PostGIS".
via b89a6f04ab68ebb21df2b35350ba73d3e8c568ae (commit)
from 98c1cb2a0de604f60af6f044237d300883de8057 (commit)
revisions in full, below.
commit b89a6f04ab68ebb21df2b35350ba73d3e8c568ae
Author: Regina Obe <lr at pcorp.us>
Date: Mon Aug 3 16:41:41 2020 -0400
Get rid of unused wkt function and const - quieting more gittie complaints. References #4734 for PostGIS 3.1.0
diff --git a/raster/test/cunit/cu_gdal.c b/raster/test/cunit/cu_gdal.c
index 680c262..becb9e1 100644
--- a/raster/test/cunit/cu_gdal.c
+++ b/raster/test/cunit/cu_gdal.c
@@ -98,16 +98,6 @@ static void test_gdal_rasterize() {
cu_free_raster(raster);
-static char *
-lwgeom_to_text(const LWGEOM *lwgeom) {
- char *wkt;
- size_t wkt_size;
- wkt = lwgeom_to_wkt(lwgeom, WKT_ISO, DBL_DIG, &wkt_size);
- return wkt;
static rt_raster fillRasterToPolygonize(int hasnodata, double nodataval) {
rt_band band = NULL;
rt_pixtype pixtype = PT_32BF;
@@ -189,12 +179,12 @@ static void test_gdal_polygonize() {
CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(gobserved), lwgeom_area(gexpected), FLT_EPSILON );
CU_ASSERT_DOUBLE_EQUAL(gv[2].val, 2.8, FLT_EPSILON);
- gobserved = (const LWGEOM *)gv[2].geom;
+ gobserved = (LWGEOM *)gv[2].geom;
gexpected = lwgeom_from_wkt("POLYGON((5 1,5 3,6 3,6 6,5 6,5 8,6 8,6 7,7 7,7 6,8 6,8 3,7 3,7 2,6 2,6 1,5 1))",
LW_PARSER_CHECK_NONE);
CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(gobserved), lwgeom_area(gexpected), FLT_EPSILON);
- gobserved = (const LWGEOM *)gv[3].geom;
+ gobserved = (LWGEOM *)gv[3].geom;
"POLYGON((0 0,0 9,9 9,9 0,0 0),(6 7,6 8,3 8,3 7,2 7,2 6,1 6,1 3,2 3,2 2,3 2,3 1,6 1,6 2,7 2,7 3,8 3,8 6,7 6,7 7,6 7))",
@@ -231,7 +221,7 @@ static void test_gdal_polygonize() {
//rtdealloc(wkt);
@@ -240,7 +230,7 @@ static void test_gdal_polygonize() {
//rtdealloc(wkt);
CU_ASSERT_DOUBLE_EQUAL(gv[3].val, 0.0, FLT_EPSILON);
Summary of changes:
raster/test/cunit/cu_gdal.c | 18 ++++--------------
1 file changed, 4 insertions(+), 14 deletions(-)
hooks/post-receive
