[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.1-38-g134d865
Mon Aug 3 15:07:17 PDT 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  134d865cc8f7dd8224c03da387c2d455bad38b38 (commit)
      from  8e4f510903995abde22468a6e9a107021dacde60 (commit)
revisions in full, below.
commit 134d865cc8f7dd8224c03da387c2d455bad38b38
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Aug 3 18:07:08 2020 -0400
    Get rid of more const, unused variables  - quieting more gittie complaints. References #4734 for PostGIS 3.0.2
diff --git a/raster/test/cunit/cu_gdal.c b/raster/test/cunit/cu_gdal.c
index 680c262..54daa3e 100644
--- a/raster/test/cunit/cu_gdal.c
+++ b/raster/test/cunit/cu_gdal.c
@@ -98,16 +98,6 @@ static void test_gdal_rasterize() {
 	cu_free_raster(raster);
-static char *
-lwgeom_to_text(const LWGEOM *lwgeom) {
-	char *wkt;
-	size_t wkt_size;
-	wkt = lwgeom_to_wkt(lwgeom, WKT_ISO, DBL_DIG, &wkt_size);
-	return wkt;
 static rt_raster fillRasterToPolygonize(int hasnodata, double nodataval) {
 	rt_band band = NULL;
 	rt_pixtype pixtype = PT_32BF;
@@ -189,12 +179,12 @@ static void test_gdal_polygonize() {
 	CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(gobserved), lwgeom_area(gexpected), FLT_EPSILON );
 	CU_ASSERT_DOUBLE_EQUAL(gv[2].val, 2.8, FLT_EPSILON);
-	gobserved = (const LWGEOM *)gv[2].geom;
+	gobserved = (LWGEOM *)gv[2].geom;
 	gexpected = lwgeom_from_wkt("POLYGON((5 1,5 3,6 3,6 6,5 6,5 8,6 8,6 7,7 7,7 6,8 6,8 3,7 3,7 2,6 2,6 1,5 1))",
 				    LW_PARSER_CHECK_NONE);
 	CU_ASSERT_DOUBLE_EQUAL(lwgeom_area(gobserved), lwgeom_area(gexpected), FLT_EPSILON);
-	gobserved = (const LWGEOM *)gv[3].geom;
+	gobserved = (LWGEOM *)gv[3].geom;
 	    "POLYGON((0 0,0 9,9 9,9 0,0 0),(6 7,6 8,3 8,3 7,2 7,2 6,1 6,1 3,2 3,2 2,3 2,3 1,6 1,6 2,7 2,7 3,8 3,8 6,7 6,7 7,6 7))",
@@ -223,7 +213,7 @@ static void test_gdal_polygonize() {
 	CU_ASSERT_DOUBLE_EQUAL(gv[1].val, 0.0, FLT_EPSILON);
-	gobserved = (const LWGEOM *)gv[1].geom;
+	gobserved = (LWGEOM *)gv[1].geom;
 	gexpected = lwgeom_from_wkt("POLYGON((3 3,3 6,6 6,6 3,3 3))", LW_PARSER_CHECK_NONE);
 	//wkt = lwgeom_to_text((const LWGEOM *) gv[1].geom);
@@ -231,7 +221,7 @@ static void test_gdal_polygonize() {
 	//rtdealloc(wkt);
@@ -240,7 +230,7 @@ static void test_gdal_polygonize() {
 	//rtdealloc(wkt);
 	CU_ASSERT_DOUBLE_EQUAL(gv[3].val, 0.0, FLT_EPSILON);
@@ -268,7 +258,7 @@ static void test_gdal_polygonize() {
diff --git a/raster/test/cunit/cu_raster_geometry.c b/raster/test/cunit/cu_raster_geometry.c
index 1f75666..1836441 100644
--- a/raster/test/cunit/cu_raster_geometry.c
+++ b/raster/test/cunit/cu_raster_geometry.c
@@ -258,7 +258,6 @@ static void test_raster_surface() {
 	const int maxX = 5;
 	const int maxY = 5;
 	int x, y;
-	char *wkt = NULL;
 	LWMPOLY *mpoly = NULL;
 	int err;
 	LWGEOM *gexpected, *gobserved;
Summary of changes:
 raster/test/cunit/cu_gdal.c            | 22 ++++++----------------
 raster/test/cunit/cu_raster_geometry.c |  1 -
 2 files changed, 6 insertions(+), 17 deletions(-)
hooks/post-receive
