[postgis-tickets] [PostGIS] #4735: Regress on winnie cu_print
PostGIS trac at osgeo.org
Tue Aug 4 01:14:26 PDT 2020
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  PostGIS 3.1.0
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by Algunenano):
 Fricking Windows. Those tests are checking that if you pass infinity,
 print it and read it back you get the same number.
 Though I don't recall seeing this error on my desktop which should be
 running much the same chain as winnie except for version of GEOS / GDAL /
 Proj
 These are pure Postgis / C code. Are you testing current HEAD in your
 desktop too? Might be a mingw difference or something like this.
 Let me know if you can check it, if not I'll disable those 2 tests since
 they are not super important.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4735#comment:1>
