[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-45-gb81beb8
git at osgeo.org
git at osgeo.org
Wed Aug 5 01:18:57 PDT 2020
the project "PostGIS".
via b81beb8d319b103692e5a954d77223ba3b94b346 (commit)
from 6dc7c14e2e5fc8d4d04c1b336825cf774bbd8890 (commit)
revisions in full, below.
commit b81beb8d319b103692e5a954d77223ba3b94b346
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Aug 5 10:17:17 2020 +0200
ST_CreateTopoGeo edge splitting improvement
Direclty use ST_Split now that it supports split by multipoint,
avoid use of ST_UnaryUnion to be immune to GEOS-3.9 OverlayNG
behavioural changes (in case they will remain)
diff --git a/topology/sql/sqlmm.sql.in b/topology/sql/sqlmm.sql.in
index 629eef4..a2f41d3 100644
--- a/topology/sql/sqlmm.sql.in
+++ b/topology/sql/sqlmm.sql.in
@@ -13,7 +13,7 @@
-/* #define POSTGIS_TOPOLOGY_DEBUG 1 */
+/*#define POSTGIS_TOPOLOGY_DEBUG 1*/
-- SQL/MM block
@@ -497,22 +497,15 @@ BEGIN
#endif
- -- Further split edges by points
- -- TODO: optimize this adding ST_Split support for multiline/multipoint
+ -- Further split edges by points, if needed
- FOR rec IN SELECT geom FROM ST_Dump(points)
- LOOP
- -- Use the node to split edges
- SELECT ST_Collect(geom)
- FROM ST_Dump(ST_Split(nodededges, rec.geom))
- INTO STRICT nodededges;
- END LOOP;
- SELECT ST_UnaryUnion(nodededges) INTO STRICT nodededges;
+ IF points IS NOT NULL THEN
+ nodededges := ST_Split(nodededges, points);
#ifdef POSTGIS_TOPOLOGY_DEBUG
- RAISE DEBUG 'Noded edges became % after point-split',
- ST_NumGeometries(nodededges);
+ RAISE DEBUG 'Noded edges became % after point-split',
+ ST_NumGeometries(nodededges);
#endif
+ END IF; -- points is not null
-- Collect all nodes (from points and noded linework endpoints)
Summary of changes:
topology/sql/sqlmm.sql.in | 21 +++++++--------------
1 file changed, 7 insertions(+), 14 deletions(-)
hooks/post-receive
