[postgis-tickets] [PostGIS] #4730: Overlay GEOS 3.9 regress failures
trac at osgeo.org
Sun Aug 9 20:26:42 PDT 2020
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by robe):
My cunit was broken, but now that it's fixed, I see cunit failures as well
related to this. They are the following:
Suite: split
Test: test_lwline_split_by_point_to ...passed
Test: test_lwgeom_split ...FAILED
1. cu_split.c:136 - ASSERT_STRING_EQUAL
* Expected: SRID=1;GEOMETRYCOLLECTION(POLYGON((7 1,0 1,0 10,7 10,7
1)),POLYGON((7 10,10 10,10 1,7 1,7 10)))
* Obtained: SRID=1;GEOMETRYCOLLECTION(POLYGON((0 1,0 10,7 10,7 1,0
1)),POLYGON((7 1,7 10,10 10,10 1,7 1)))
Suite: wrapx
Test: test_lwgeom_wrapx ...FAILED
1. cu_wrapx.c:85 - ASSERT_STRING_EQUAL
* Expected: MULTILINESTRING((0 0,8 0),(-2 0,0 0))
* Obtained: MULTILINESTRING((-2 0,0 0),(0 0,8 0))
2. cu_wrapx.c:123 - ASSERT_STRING_EQUAL
* Expected: GEOMETRYCOLLECTION(MULTIPOLYGON(((22 0,20 0,20 10,22
10,22 4,22 2,22 0)),((2 10,10 10,10 0,2 0,2 2,4 2,4 4,2 4,2
10))),MULTIPOLYGON(((22 11,20 11,20 21,22 21,22 15,22 13,22 11)),((2 21,10
21,10 11,2 11,2 13,4 13,4 15,2 15,2 21))))
* Obtained: GEOMETRYCOLLECTION(MULTIPOLYGON(((20 0,20 10,22 10,22
4,22 2,22 0,20 0)),((2 0,2 2,4 2,4 4,2 4,2 10,10 10,10 0,2
0))),MULTIPOLYGON(((20 11,20 21,22 21,22 15,22 13,22 11,20 11)),((2 11,2
13,4 13,4 15,2 15,2 21,10 21,10 11,2 11))))
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4730#comment:13>
