[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-46-gfdf3262
git at osgeo.org
git at osgeo.org
Sun Aug 9 22:55:26 PDT 2020
the project "PostGIS".
via fdf3262eb1c30ba83f034886604421e1faf15db6 (commit)
from b81beb8d319b103692e5a954d77223ba3b94b346 (commit)
revisions in full, below.
commit fdf3262eb1c30ba83f034886604421e1faf15db6
Author: Regina Obe <lr at pcorp.us>
Date: Mon Aug 10 01:55:08 2020 -0400
Normalize cunit output for split and wrapx tests so pass on all versions of GEOS. References #4730 for PostGIS 3.1.0 master
diff --git a/liblwgeom/cunit/cu_split.c b/liblwgeom/cunit/cu_split.c
index 0a81bdf..3bee364 100644
--- a/liblwgeom/cunit/cu_split.c
+++ b/liblwgeom/cunit/cu_split.c
@@ -129,10 +129,12 @@ static void test_lwgeom_split(void)
geom = lwgeom_from_wkt("SRID=1;POLYGON((0 1, 10 1, 10 10, 0 10, 0 1))", LW_PARSER_CHECK_NONE);
CU_ASSERT(geom != NULL);
blade = lwgeom_from_wkt("LINESTRING(7 0,7 20)", LW_PARSER_CHECK_NONE);
- ret = lwgeom_split(geom, blade);
+ ret = lwgeom_normalize(lwgeom_split(geom, blade));
CU_ASSERT(ret != NULL);
wkt = lwgeom_to_ewkt(ret);
- in_wkt = "SRID=1;GEOMETRYCOLLECTION(POLYGON((7 1,0 1,0 10,7 10,7 1)),POLYGON((7 10,10 10,10 1,7 1,7 10)))";
+ in_wkt = lwgeom_to_ewkt(lwgeom_normalize(lwgeom_from_wkt(
+ "SRID=1;GEOMETRYCOLLECTION(POLYGON((7 1,0 1,0 10,7 10,7 1)),POLYGON((7 10,10 10,10 1,7 1,7 10)))",
+ LW_PARSER_CHECK_NONE)));
ASSERT_STRING_EQUAL(wkt, in_wkt);
lwfree(wkt);
lwgeom_free(ret);
diff --git a/liblwgeom/cunit/cu_wrapx.c b/liblwgeom/cunit/cu_wrapx.c
index 78c757a..50bb553 100644
--- a/liblwgeom/cunit/cu_wrapx.c
+++ b/liblwgeom/cunit/cu_wrapx.c
@@ -78,10 +78,13 @@ static void test_lwgeom_wrapx(void)
"LINESTRING(0 0,10 0)",
CU_ASSERT_FATAL(geom != NULL);
- ret = lwgeom_wrapx(geom, 8, -10);
+ ret = lwgeom_normalize(lwgeom_wrapx(geom, 8, -10));
CU_ASSERT_FATAL(ret != NULL);
obt_wkt = lwgeom_to_ewkt(ret);
- exp_wkt = "MULTILINESTRING((0 0,8 0),(-2 0,0 0))";
+ exp_wkt = lwgeom_to_ewkt(
+ lwgeom_normalize(lwgeom_from_wkt(
+ "MULTILINESTRING((0 0,8 0),(-2 0,0 0))",
ASSERT_STRING_EQUAL(obt_wkt, exp_wkt);
lwfree(obt_wkt);
lwgeom_free(ret);
@@ -91,10 +94,17 @@ static void test_lwgeom_wrapx(void)
"MULTILINESTRING((-5 -2,0 0),(0 0,10 10))",
- ret = lwgeom_wrapx(geom, 0, 20);
+ ret = lwgeom_normalize(lwgeom_wrapx(geom, 0, 20));
- exp_wkt = "MULTILINESTRING((15 -2,20 0),(0 0,10 10))";
+ lwgeom_normalize(
+ lwgeom_from_wkt(
+ "MULTILINESTRING((15 -2,20 0),(0 0,10 10))"
+ , LW_PARSER_CHECK_NONE
lwfree(obt_wkt);
lwgeom_free(ret);
@@ -107,19 +117,21 @@ static void test_lwgeom_wrapx(void)
- ret = lwgeom_wrapx(geom, 2, 20);
+ ret = lwgeom_normalize(lwgeom_wrapx(geom, 2, 20));
- exp_wkt = "GEOMETRYCOLLECTION("
- "MULTIPOLYGON("
- "((22 0,20 0,20 10,22 10,22 4,22 2,22 0)),"
- "((2 10,10 10,10 0,2 0,2 2,4 2,4 4,2 4,2 10))"
- "MULTIPOLYGON("
- "((22 11,20 11,20 21,22 21,22 15,22 13,22 11)),"
- "((2 21,10 21,10 11,2 11,2 13,4 13,4 15,2 15,2 21))"
+ exp_wkt =
+ lwgeom_to_ewkt(lwgeom_normalize(lwgeom_from_wkt("GEOMETRYCOLLECTION("
+ "MULTIPOLYGON("
+ "((22 0,20 0,20 10,22 10,22 4,22 2,22 0)),"
+ "((2 10,10 10,10 0,2 0,2 2,4 2,4 4,2 4,2 10))"
+ "MULTIPOLYGON("
+ "((22 11,20 11,20 21,22 21,22 15,22 13,22 11)),"
+ "((2 21,10 21,10 11,2 11,2 13,4 13,4 15,2 15,2 21))"
lwfree(obt_wkt);
lwgeom_free(ret);
@@ -133,19 +145,21 @@ static void test_lwgeom_wrapx(void)
- "MULTILINESTRING((15 -2,20 0),(0 0,10 10)),"
- "POINT(15 0),"
- "POLYGON EMPTY"
+ "GEOMETRYCOLLECTION("
+ "MULTILINESTRING((15 -2,20 0),(0 0,10 10)),"
+ "POINT(15 0),"
+ "POLYGON EMPTY"
+ LW_PARSER_CHECK_NONE)) );
lwfree(obt_wkt);
lwgeom_free(ret);
lwgeom_free(geom);
static int
Summary of changes:
liblwgeom/cunit/cu_split.c | 6 +++--
liblwgeom/cunit/cu_wrapx.c | 58 ++++++++++++++++++++++++++++------------------
2 files changed, 40 insertions(+), 24 deletions(-)
hooks/post-receive
