[postgis-tickets] [PostGIS] #4732: long planning time
trac at osgeo.org
Tue Aug 11 05:09:13 PDT 2020
Reporter: michal | Owner: pramsey
Type: enhancement | Status: new
Priority: low | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by michal):
steps to reproduce (create some data, two cities with a lot of points plus
some points in between):
drop table if exists tmp_within;
create table tmp_within (name text, way geography);
insert into tmp_within select left(md5(i::text), 8) as desc,
geography(st_makepoint(48+random(), 17+random())) from
generate_series(1,25000) as i;
geography(st_makepoint(48+random(), 19+random())) from
generate_series(25000,50000) as i;
geography(st_makepoint(48+random(), 17+3*random())) from
generate_series(50000,75000) as i;
create index on tmp_within using gist(way) ;
analyze tmp_within;
and then select which points are near our point (48.9,17.1) - within
roughly 1km (I generally don't care about the difference between square
and round buffer, as long as it is fast).
selecting rows within (square) buffer:
explain analyze select name from tmp_within where way &&
st_buffer(geography(st_makepoint(48.9, 17.1)), 1000);
Index Scan using tmp_within_way_idx on tmp_within (cost=0.28..3.90 rows=1
width=9) (actual time=0.096..0.116 rows=13 loops=1)
Index Cond: (way &&
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geography)
Planning Time: 15.122 ms
Execution Time: 0.135 ms
selecting rows with st_dwithin (which is round):
st_dwithin(way,geography(st_makepoint(48.9, 17.1)), 1000);
Index Scan using tmp_within_way_idx on tmp_within (cost=0.53..29.15
rows=8 width=9) (actual time=0.697..0.793 rows=12 loops=1)
Index Cond: (way &&
_st_expand('0101000020E610000033333333337348409A99999999193140'::geography,
'1000'::double precision))
Filter: st_dwithin(way,
'1000'::double precision, true)
Rows Removed by Filter: 5
Planning Time: 0.300 ms
Execution Time: 0.838 ms
The first approach, which is far less accurate, spends long time in
planning (and less time in execution, which is expectable, since it is far
less accurate).
the fastest approach should be (I am not sure, why the _ in front of
_st_expand is neccessary):
_st_expand(geography(st_makepoint(48.9, 17.1)), 1000);
width=9) (actual time=0.182..0.280 rows=17 loops=1)
Index Cond: (way &&
'0101000020E610000033333333337348409A99999999193140'::geography)
Planning Time: 0.419 ms
Execution Time: 0.313 ms
Why is there such huge difference in planning time between the approaches?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4732#comment:3>
