[postgis-tickets] [PostGIS] #4739: st_dwithin : no spatial operator found
PostGIS trac at osgeo.org
Wed Aug 12 10:50:09 PDT 2020
 Reporter:  grantfin  |      Owner:  pramsey
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.1.0
Component:  postgis   |    Version:  3.0.x
 Keywords:            |
 I did look at prior issues, but they seemed much older, and possibly using
 SQL versions.
 **Product versions**
 select postgis_full_version();
  POSTGIS="3.0.1 ec2a9aa" [EXTENSION] PGSQL="120" GEOS="3.8.1-CAPI-1.13.3"
 PROJ="6.2.1" LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.2"
 WAGYU="0.4.3 (Internal)"
 select version();
                                                    version
  PostgreSQL 12.3 on x86_64-apple-darwin16.7.0, compiled by Apple LLVM
 version 8.1.0 (clang-802.0.42), 64-bit
 **Replication steps**
 create database geo_test;
 \c geo_test
 create extension postgis;
 create schema test;
 set search_path to test;
 create table a (lat float8, lng float8, idx_col public.geography generated
 always as (public.st_makepoint(lng,lat)::public.geography)stored);
 create index idx_a_geog on a using gist(idx_col);
 with g as (select public.st_makepoint(28,28)::public.geography a) select *
 from a, g where public.st_dwithin(g.a, a.idx_col, 5000, true);
 ERROR:  no spatial operator found for 'st_dwithin': opfamily 603008 type
 602965
 ''Now, include the public schema...''
 set search_path to test, public;
 SET
  lat | lng | idx_col | a
 (0 rows)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4739>
