[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-48-gddd41fd
Wed Aug 12 14:00:18 PDT 2020
the project "PostGIS".
       via  ddd41fdc0d3d5db63d6b7ad12b609ebf341421ed (commit)
      from  99d890475aff67551cac4a3d06cbfe2c222fe581 (commit)
revisions in full, below.
commit ddd41fdc0d3d5db63d6b7ad12b609ebf341421ed
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Aug 12 14:00:01 2020 -0700
    Be more aggressive about obtaining an outside point from gbox. References #4689
diff --git a/liblwgeom/lwgeodetic_tree.c b/liblwgeom/lwgeodetic_tree.c
index 35b0ff4..9baa8cd 100644
--- a/liblwgeom/lwgeodetic_tree.c
+++ b/liblwgeom/lwgeodetic_tree.c
@@ -476,7 +476,7 @@ int circ_tree_get_point_outside(const CIRC_NODE* node, POINT2D* pt)
 	POINT3D center3d;
 	GEOGRAPHIC_POINT g;
-	if (node->radius >= M_PI) return LW_FAILURE;
+	// if (node->radius >= M_PI) return LW_FAILURE;
 	geog2cart(&(node->center), &center3d);
 	vector_scale(&center3d, -1.0);
 	cart2geog(&center3d, &g);
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 37846fc..034720d 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1295,3 +1295,6 @@ SELECT '#4670-2', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geomet
 SELECT '#4670-3', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 3));
 SELECT '#4670-4', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 4));
 SELECT '#4670-5', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 5));
+SELECT '#4689', _ST_DistanceTree('POLYGON ((30 10, 40 40, 20 40, 30 10))'::geography, 'POLYGON((81 6,140 35,-70 18,-51 0,-60 -46,106 -6,81 6))');
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index a495b41..a329953 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -433,3 +433,4 @@ ERROR:  BOX2D_construct: args can not be empty points
 #4670-3|LINESTRING(0 0,1 1,3 3,2 2,4 4)
 #4670-4|LINESTRING(0 0,1 1,3 3,4 4,2 2)
 ERROR:  LWGEOM_addpoint: Invalid offset
+#4689|0
Summary of changes:
 liblwgeom/lwgeodetic_tree.c   | 2 +-
 regress/core/tickets.sql      | 3 +++
 regress/core/tickets_expected | 1 +
 3 files changed, 5 insertions(+), 1 deletion(-)
hooks/post-receive
