[postgis-tickets] [PostGIS] #4738: ST_Union creates wrong result
trac at osgeo.org
Thu Aug 13 04:02:59 PDT 2020
Reporter: laopsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by laopsahl):
If you look at the last query and change that to use ST_AsText, the lines
seems not to collapse.
And in addition to get a more correct result it's also much faster with
ST_AsText.
[local] lop at sl=# select count(*) as ST_AsBinary from (
select (ST_Dump(ST_Union(i.geom))).geom from
( select ST_AsBinary(geom) as geom from test_input_snap where id > 100 and
id < 600 ) as i
) as r;
st_asbinary
343
(1 row)
Time: 2808.473 ms (00:02.808)
[local] lop at sl=# select count(*) as ST_AsText from (
( select ST_AsText(geom) as geom from test_input_snap where id > 100 and
id < 600 ) as i
) as r;
st_astext
12091
(1 row)
Time: 336.900 ms
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4738#comment:2>
