[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-51-ge6c9403
git at osgeo.org
git at osgeo.org
Thu Aug 13 13:13:16 PDT 2020
the project "PostGIS".
via e6c9403689953350cc0bec69086fd49ee194f43f (commit)
from d1735b10d59ffedff43b939f4e7e7fafd1138259 (commit)
revisions in full, below.
commit e6c9403689953350cc0bec69086fd49ee194f43f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Aug 13 13:13:11 2020 -0700
Remove more memory leaks from tests
diff --git a/liblwgeom/cunit/cu_split.c b/liblwgeom/cunit/cu_split.c
index 714ea75..b7bcb1e 100644
--- a/liblwgeom/cunit/cu_split.c
+++ b/liblwgeom/cunit/cu_split.c
@@ -129,17 +129,21 @@ static void test_lwgeom_split(void)
geom = lwgeom_from_wkt("SRID=1;POLYGON((0 1, 10 1, 10 10, 0 10, 0 1))", LW_PARSER_CHECK_NONE);
CU_ASSERT(geom != NULL);
blade = lwgeom_from_wkt("LINESTRING(7 0,7 20)", LW_PARSER_CHECK_NONE);
- ret = lwgeom_normalize(lwgeom_split(geom, blade));
+ tmp1 = lwgeom_split(geom, blade);
+ ret = lwgeom_normalize(tmp1);
+ lwgeom_free(tmp1);
CU_ASSERT(ret != NULL);
wkt = lwgeom_to_ewkt(ret);
- tmp1 = lwgeom_normalize(lwgeom_from_wkt(
+ tmp1 = lwgeom_from_wkt(
"SRID=1;GEOMETRYCOLLECTION(POLYGON((7 1,0 1,0 10,7 10,7 1)),POLYGON((7 10,10 10,10 1,7 1,7 10)))",
- LW_PARSER_CHECK_NONE));
- in_wkt = lwgeom_to_ewkt(tmp1);
+ LW_PARSER_CHECK_NONE);
+ tmp2 = lwgeom_normalize(tmp1);
+ in_wkt = lwgeom_to_ewkt(tmp2);
ASSERT_STRING_EQUAL(wkt, in_wkt);
lwfree(wkt);
lwfree(in_wkt);
lwgeom_free(tmp1);
+ lwgeom_free(tmp2);
lwgeom_free(ret);
lwgeom_free(geom);
lwgeom_free(blade);
diff --git a/liblwgeom/cunit/cu_wrapx.c b/liblwgeom/cunit/cu_wrapx.c
index d3e3a37..a5ca09a 100644
--- a/liblwgeom/cunit/cu_wrapx.c
+++ b/liblwgeom/cunit/cu_wrapx.c
@@ -19,7 +19,7 @@
static void test_lwgeom_wrapx(void)
- LWGEOM *geom, *ret;
+ LWGEOM *geom, *ret, *tmp, *tmp2;
char *exp_wkt, *obt_wkt;
@@ -78,13 +78,18 @@ static void test_lwgeom_wrapx(void)
"LINESTRING(0 0,10 0)",
CU_ASSERT_FATAL(geom != NULL);
- ret = lwgeom_normalize(lwgeom_wrapx(geom, 8, -10));
+ tmp = lwgeom_wrapx(geom, 8, -10);
+ ret = lwgeom_normalize(tmp);
+ lwgeom_free(tmp);
CU_ASSERT_FATAL(ret != NULL);
obt_wkt = lwgeom_to_ewkt(ret);
- exp_wkt = lwgeom_to_ewkt(
- lwgeom_normalize(lwgeom_from_wkt(
+ tmp = lwgeom_from_wkt(
"MULTILINESTRING((0 0,8 0),(-2 0,0 0))",
- LW_PARSER_CHECK_NONE)));
+ tmp2 = lwgeom_normalize(tmp);
+ lwgeom_free(tmp);
+ exp_wkt = lwgeom_to_ewkt(tmp2);
ASSERT_STRING_EQUAL(obt_wkt, exp_wkt);
lwfree(obt_wkt);
lwfree(exp_wkt);
@@ -95,17 +100,16 @@ static void test_lwgeom_wrapx(void)
"MULTILINESTRING((-5 -2,0 0),(0 0,10 10))",
- ret = lwgeom_normalize(lwgeom_wrapx(geom, 0, 20));
+ tmp = lwgeom_wrapx(geom, 0, 20);
+ lwgeom_free(tmp);
- lwgeom_normalize(
- lwgeom_from_wkt(
- "MULTILINESTRING((15 -2,20 0),(0 0,10 10))"
- , LW_PARSER_CHECK_NONE
+ tmp = lwgeom_from_wkt("MULTILINESTRING((15 -2,20 0),(0 0,10 10))", LW_PARSER_CHECK_NONE);
+ lwgeom_free(tmp);
lwfree(obt_wkt);
lwfree(exp_wkt);
@@ -119,11 +123,12 @@ static void test_lwgeom_wrapx(void)
- ret = lwgeom_normalize(lwgeom_wrapx(geom, 2, 20));
+ tmp = lwgeom_wrapx(geom, 2, 20);
+ lwgeom_free(tmp);
- exp_wkt =
- lwgeom_to_ewkt(lwgeom_normalize(lwgeom_from_wkt("GEOMETRYCOLLECTION("
+ tmp = lwgeom_from_wkt("GEOMETRYCOLLECTION("
"MULTIPOLYGON("
"((22 0,20 0,20 10,22 10,22 4,22 2,22 0)),"
"((2 10,10 10,10 0,2 0,2 2,4 2,4 4,2 4,2 10))"
@@ -133,7 +138,11 @@ static void test_lwgeom_wrapx(void)
"((2 21,10 21,10 11,2 11,2 13,4 13,4 15,2 15,2 21))"
+ lwgeom_free(tmp);
lwfree(obt_wkt);
lwfree(exp_wkt);
@@ -148,17 +157,22 @@ static void test_lwgeom_wrapx(void)
+ lwgeom_free(tmp);
"MULTILINESTRING((15 -2,20 0),(0 0,10 10)),"
"POINT(15 0),"
"POLYGON EMPTY"
- LW_PARSER_CHECK_NONE)) );
+ lwgeom_free(tmp);
lwfree(obt_wkt);
lwfree(exp_wkt);
Summary of changes:
liblwgeom/cunit/cu_split.c | 12 ++++++----
liblwgeom/cunit/cu_wrapx.c | 58 ++++++++++++++++++++++++++++------------------
2 files changed, 44 insertions(+), 26 deletions(-)
hooks/post-receive
