[postgis-tickets] [PostGIS] #4740: Berrie64 pg13 branch - weird regress failure on tickets
PostGIS trac at osgeo.org
Fri Aug 14 11:29:18 PDT 2020
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.1.0
Component:  postgis  |    Version:  2.5.x
 Keywords:           |
 I'm going to retest this to make sure it's not a fluke.  Odd that it's
 happening only on berrie64 which rarely has problems.
 17:34:03 Checking for shp2pgsql ... found
 17:34:03 Checking for pgsql2shp ... found
 17:34:03 TMPDIR is /tmp/pgis_reg
 17:34:03 Creating database 'postgis_reg'
 17:34:06 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis SCHEMA
 public
 17:34:11 PostgreSQL 13beta2 on aarch64-unknown-linux-gnu, compiled by gcc
 (Debian 8.3.0-6) 8.3.0, 64-bit
 17:34:11   Postgis 3.1.0dev - (e6c9403) - 2020-08-13 21:20:36
 17:34:11   scripts 3.1.0dev e6c9403
 17:34:11   GEOS: 3.7.1-CAPI-1.11.1 27a5e771
 17:34:11   PROJ: Rel. 5.2.0, September 15th, 2018
 17:35:44
 17:35:44 --- tickets_expected   2020-08-13 14:19:28.517337391 -0700
 17:35:44 +++ /tmp/pgis_reg/test_103_out 2020-08-13 14:35:44.156985845
 -0700
 17:35:44 @@ -433,4 +433,4 @@
 17:35:44  #4670-3|LINESTRING(0 0,1 1,3 3,2 2,4 4)
 17:35:44  #4670-4|LINESTRING(0 0,1 1,3 3,4 4,2 2)
 17:35:44  ERROR:  LWGEOM_addpoint: Invalid offset
 17:35:44 -#4689|0
 17:35:44 +#4689|5.92515031139973e-11
 17:35:44
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4740>
