[postgis-tickets] [SCM] PostGIS branch stable-2.4 updated. 63c987e448bf8f028d9738df1ee7ba14eaa18b03
git at osgeo.org
git at osgeo.org
Fri Aug 14 18:51:52 PDT 2020
the project "PostGIS".
The branch, stable-2.4 has been updated
via 63c987e448bf8f028d9738df1ee7ba14eaa18b03 (commit)
from 1129a184a5b03fb79353e8a32a9f2b4246c71018 (commit)
revisions in full, below.
commit 63c987e448bf8f028d9738df1ee7ba14eaa18b03
Author: Regina Obe <lr at pcorp.us>
Date: Fri Aug 14 21:51:28 2020 -0400
how to release and version info
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index f377810..9f5c076 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,6 +1,6 @@
How to release
-Date: 2018-04-01
+Date: 2020-08-14
Versioning Scheme
@@ -57,9 +57,14 @@ documentation -- that means having the required software:
Release procedure
-- Re-generate the ChangeLog (make ChangeLog)
+- For first micro of a minor, make sure to pull the latest translations from transifex
+ TODO: more detail here - there is a job on debbie for 3.1 for examples
+ https://debbie.postgis.net/view/PostGIS/job/PostGIS_docs_translations_2.5
+ and she's setup with an api key to pull and push translations.
+- Ensure all bots are green: https://trac.osgeo.org/postgis
- Edit NEWS: set release date and check all notable changes have
- been reported (extract from ChangeLog).
+ been reported (extract from git log).
- Edit README.postgis and set release date and version.
- Add release notes in doc/release_notes.xml
- Update Version.config to drop the "dev" suffix
@@ -69,33 +74,31 @@ Release procedure
(this should only be needed for trunk release)
- Commit all changes
- If this is a minor or major release (no branch exists):
- $ base=http://svn.osgeo.org/postgis/
$ rev=x.x
- $ svn copy -m "Branch $rev" $base/trunk $base/branches/$rev
+ $ git checkout master; git checkout -b "$rev"; git push -u osgeo $rev
Go to: https://debbie.postgis.net and copy last branch version and make new job
a) Replace PostGIS_* string params with new version
b) Replace repository url with new branch repo url
c) Update the PostGIS_trunk by updating the PostGIS_* string params
- Go to: https://trac.osgeo.org/postgis/ edit the matrix to reflect new branch
+ Go to: https://trac.osgeo.org/postgis/ edit the matrix to reflect new branch
- Tag branch: (replace x.x and x.x.x with minor and micro version e.g 2.3, 2.3.1
- $ brev=x.x
$ rev=x.x.x
- $ svn copy -m "Tagged release $rev" $base/branches/$brev $base/tags/$rev
+ $ git tag -a $rev -m "Tagged release $rev"; git push osgeo --tags
- Run: sh make_dist.sh $rev (note, debbie should have already done this,
and the file will be waiting in postgis.net/stuff. You might need to wait a few minutes to see it.)
If impatient check status of job - https://debbie.postgis.net/job/PostGIS_Make_Dist/
- Documentation should also have been built and should be in postgis.net/stuff
(this sometimes takes sometime so wait 15 minutes)
- Test generated tarball (including extension upgrade)
-- Copy tarball, pdf, doc-html.. to http://download.osgeo.org/postgis/ web site and edit postgis.net/source page
+- Copy tarball, pdf, doc-html.. to https://download.osgeo.org/postgis/ web site and edit postgis.net/source page
- Announce on e-mail
- postgis-users
- postgis-devel
- - pgsql-announce (send note to david at fetter dot org to be included in Weekly news)
+ - pgsql-announce (send email just to them, not with other ccs, they reject if others in cc)
+ - send note to david at fetter dot org to be included in Weekly news
- osgeo-discuss
- Update web sites
- PostGIS News
@@ -104,10 +107,13 @@ Release procedure
b) Update links on https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/pages/source.html
c) commit and wait 5 minutes to see changes on website
- PostGIS doc release versioned doc - http://postgis.net/documentation/
+ - On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
+ - nginx -t #to confirm you didn't breat the config
+ - service nginx reload
Verify the documentation is up to date (might need to change the apach config)
- Wikipedia
- Twitter
- This should automatically happen as a result of posting to PostGIS website since Planet PostGIS autotweets.
+ This should automatically happen as a result of posting to PostGIS website since Planet PostGIS and Planet PostgreSQL both autotweet.
- Update Trac and make old Milestone as completed
- Push the revision number forward (see Versioning Scheme)
- Remove the "dev" suffixed version from extensions/upgradeable_versions.mk
diff --git a/README.postgis b/README.postgis
index a299d3e..765c583 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,9 +1,9 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.4.7
-:Date: 2019-03-11
-:Website: http://postgis.net
+:Version: 2.4.9
+:Date: 2020-08-14
+:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
the features to R-tree indexing, and provides many spatial functions for
Summary of changes:
HOWTO_RELEASE | 30 ++++++++++++++++++------------
README.postgis | 6 +++---
2 files changed, 21 insertions(+), 15 deletions(-)
hooks/post-receive
