[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-52-g866293b
git at osgeo.org
git at osgeo.org
Sat Aug 15 00:22:25 PDT 2020
the project "PostGIS".
via 866293b52cac266d75368c0f88a01ab4eae63b0a (commit)
from e6c9403689953350cc0bec69086fd49ee194f43f (commit)
revisions in full, below.
commit 866293b52cac266d75368c0f88a01ab4eae63b0a
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Aug 15 10:21:46 2020 +0300
Don't use ST_PointInsideCircle if you need indexes, use ST_DWithin instead.
Closes #4741.
diff --git a/NEWS b/NEWS
index 8cd71f0..6b0b05e 100644
--- a/NEWS
+++ b/NEWS
@@ -21,7 +21,8 @@ Only tickets not included in 3.1.0alpha2
Affects ANALYZE, _ST_PointOutside, postgis_geobbox, ST_CombineBbox(box2d, geometry),
ST_ClipByBox2D when the geometry is fully inside or outside the bbox and
ST_BoundingDiagonal.
+ - #4741, Don't use ST_PointInsideCircle if you need indexes, use ST_DWithin instead.
+ Documentation adjusted (Darafei Praliaskouski)
* Bug fixes *
- #4691, Fix segfault during gist index creation with empty geometries (Raúl Marín)
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index c415568..160e76c 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -1339,57 +1339,6 @@ FROM (SELECT ST_Buffer(ST_GeomFromText('POINT(1 0.5)'), 3) As a,
</refsection>
</refentry>
- <refentry id="ST_PointInsideCircle">
- <refnamediv>
- <refname>ST_PointInsideCircle</refname>
- <refpurpose>Is the point geometry inside the circle defined by center_x, center_y, radius</refpurpose>
- </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>boolean <function>ST_PointInsideCircle</function></funcdef>
- <paramdef><type>geometry </type> <parameter>a_point</parameter></paramdef>
- <paramdef><type>float </type> <parameter>center_x</parameter></paramdef>
- <paramdef><type>float </type> <parameter>center_y</parameter></paramdef>
- <paramdef><type>float </type> <parameter>radius</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
- <refsection>
- <title>Description</title>
- <para>The syntax for this functions is
- ST_PointInsideCircle(<geometry>,<circle_center_x>,<circle_center_y>,<radius>).
- Returns the true if the geometry is a point and is inside the
- circle. Returns false otherwise.</para>
- <note><para>This only works for points as the name suggests</para></note>
- <para>Availability: 1.2</para>
- <para>Changed: 2.2.0 In prior versions this used to be called ST_Point_Inside_Circle</para>
- </refsection>
- <refsection>
- <title>Examples</title>
- <programlisting>SELECT ST_PointInsideCircle(ST_Point(1,2), 0.5, 2, 3);
- st_pointinsidecircle
- t
-</programlisting>
- </refsection>
- <!-- Optionally add a "See Also" section -->
- <refsection>
- <title>See Also</title>
- <para><xref linkend="ST_DWithin" /></para>
- </refsection>
- </refentry>
<refentry id="ST_Relate">
<refnamediv>
<refname>ST_Relate</refname>
@@ -2131,6 +2080,57 @@ SELECT b.tower_id, b.geom
</refsection>
</refentry>
+ <refentry id="ST_PointInsideCircle">
+ <refnamediv>
+ <refname>ST_PointInsideCircle</refname>
+ <refpurpose>Is the point geometry inside the circle defined by center_x, center_y, radius</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>boolean <function>ST_PointInsideCircle</function></funcdef>
+ <paramdef><type>geometry </type> <parameter>a_point</parameter></paramdef>
+ <paramdef><type>float </type> <parameter>center_x</parameter></paramdef>
+ <paramdef><type>float </type> <parameter>center_y</parameter></paramdef>
+ <paramdef><type>float </type> <parameter>radius</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>The syntax for this functions is
+ ST_PointInsideCircle(<geometry>,<circle_center_x>,<circle_center_y>,<radius>).
+ Returns the true if the geometry is a point and is inside the
+ circle. Returns false otherwise.</para>
+ <warning><para>Will not use spatial indexes. Use <xref linkend="ST_DWithin" /> instead.</para></warning>
+ <note><para>This only works for points as the name suggests.</para></note>
+ <para>Availability: 1.2</para>
+ <para>Changed: 2.2.0 In prior versions this used to be called ST_Point_Inside_Circle</para>
+ </refsection>
+ <refsection>
+ <title>Examples</title>
+ <programlisting>SELECT ST_PointInsideCircle(ST_Point(1,2), 0.5, 2, 3);
+ st_pointinsidecircle
+ t
+</programlisting>
+ </refsection>
+ <!-- Optionally add a "See Also" section -->
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_DWithin" /></para>
+ </refsection>
+ </refentry>
</sect2>
Summary of changes:
NEWS | 3 +-
doc/reference_relationship.xml | 102 ++++++++++++++++++++---------------------
2 files changed, 53 insertions(+), 52 deletions(-)
hooks/post-receive
