[postgis-tickets] [PostGIS] #4430: PostGIS bundle fails in silent install mode for PostgreSQL 11.2
trac at osgeo.org
Mon Aug 17 06:12:27 PDT 2020
Reporter: danielheden | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS Packaging
Component: postgis | Version: 3.0.x
Resolution: worksforme | Keywords: silent install
Changes (by robe):
* status: new => closed
* version: 2.5.x => 3.0.x
* resolution: => worksforme
Comment:
I tested the silent installer with the latest release PostGIS 3.0.2 and
seemed to work fine for my PostgreSQL 10, 11, and 12 installs. In theory
you shouldn't even need the /USERNAME=postgres /PASSWORD=xxxxxx /PORT=5432
switches as I have the build test database turned off by default. If you
were using that as a metric of the installer working, that might be the
issue as a database is not created.
It only needs those additional switches for installing the test database.
I hadn't tested with those switches.
I'm going to close this out as I can't replicate at least for the latest
releases.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4430#comment:7>
