[postgis-tickets] [PostGIS] #4737: Reduce memory usage during MVT encoding
trac at osgeo.org
Mon Aug 17 09:15:00 PDT 2020
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: fixed | Keywords:
Changes (by Raúl Marín <git@…>):
* status: assigned => closed
* resolution: => fixed
Comment:
In [changeset:"99c50d4602a6e1d94f65932cbcbee933af998ea1/git"
99c50d46/git]:
#!CommitTicketReference repository="git"
revision="99c50d4602a6e1d94f65932cbcbee933af998ea1"
MVT: Improve performance and memory usage
- Reduce memory usage (raises protobuf-c requirement to 1.1).
- Improves performance when merging tiles (from parallel queries).
- Uses protobuf values to reduce the number of transformations and
memory usage.
- Uses a temporal context when transforming data (reading rows) to
have a fast way of cleaning up memory before the parallel process
starts.
- Processes texts and cstrings with each known reading functions
instead of the `OidOutputFunctionCall` fallback.
- Avoids multiple hash function calls when a value is not found in
the hash table (once for the lookup and once for the insertion).
Closes https://github.com/postgis/postgis/pull/576
Closes #4737
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4737#comment:2>
