[postgis-tickets] [PostGIS] #4740: Berrie64 pg13 branch - weird regress failure on tickets
trac at osgeo.org
Thu Aug 20 02:31:01 PDT 2020
Reporter: robe | Owner: pramsey
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by Algunenano):
It seems this looks similar to #2168.
In geography_distance there is a round to nanometers to avoid this:
/* Knock off any funny business at the nanometer level, ticket
#2168 */
distance = round(distance * INVMINDIST) / INVMINDIST;
Which is not present in geography_distance_tree. @pramsey do you think
it's the same issue and should be solved in the same way or it should be
investigated further?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4740#comment:9>
