[postgis-tickets] [PostGIS] #4720: Memory leak when using Geography
trac at osgeo.org
Fri Aug 28 05:40:21 PDT 2020
Reporter: kthujvu | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.3
Component: postgis | Version: 3.0.x
Resolution: | Keywords: geography memory
Comment (by Algunenano):
I can reproduce it with the 110m query when loading the data from the shp
as a geography.
The setup operation (to create the points relation) takes ~5 MB and
mantains the memory stable, so the issue comes from the last JOIN.
Since the only way I know to leak memory from Postgis is in indexes (since
those don't work with the same Memory context limits) I tried the same
query disabling indexscan (`set enable_indexscan = false;`) and with that
the issue does not appear.
I've had a look at the offending function
(`gserialized_gist_geog_distance`) but I haven't seen anywhere were a leak
might happen, so I don't really know if it's the index leaking memory or
the function finishing faster and caching some results. It needs a more in
depth investigation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4720#comment:4>
