[postgis-tickets] [PostGIS] #4807: topology/totopogeom.sql failing (GEOS 3.9)
trac at osgeo.org
Thu Dec 3 10:07:47 PST 2020
Reporter: pramsey | Owner: strk
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Keywords: |
--- ./topology/test/regress/totopogeom_expected 2020-11-26
16:01:06.000000000 -0800
+++ /tmp/pgis_reg/test_189_out 2020-12-03 10:05:10.000000000 -0800
@@ -24,7 +24,7 @@
MULTIPOINT(0 -10,5 -10)|t
MULTILINESTRING((-1 10,-10 10),(-10 8,-2 9))|t
MULTIPOLYGON(((100 20,110 20,105 30,100 20),(102 22,108 22,105 28,102
22)),((80 20,90 20,90 60,80 20)))|t
-GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90
-90),POLYGON((-100 -80,-90 -80,-95 -70,-100 -80),(-98 -78,-92 -78,-95
-72,-98 -78)),MULTIPOINT(-100 -110,-95 -110),LINESTRING
EMPTY,MULTILINESTRING((-101 -90,-110 -90),(-110 -92,-102
-91)),MULTIPOLYGON(((0 -80,10 -80,5 -70,0 -80),(2 -78,8 -78,5 -72,2
-78)),((-20 -80,-10 -80,-10 -40,-20
-80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((-100 -80,-95 -70,-90 -80,-100
-80),(-98 -78,-92 -78,-95 -72,-98 -78)),((0 -80,5 -70,10 -80,0 -80),(2
-78,8 -78,5 -72,2 -78)),((-20 -80,-10 -40,-10 -80,-20
-80))),MULTILINESTRING((-110 -92,-102 -91),(-101 -90,-110 -90),(-100
-90,-90 -90)),MULTIPOINT(-100 -110,-100 -100,-95 -110))
+GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90
-80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((-95 -70,-90 -80,-100 -80,-95
-70),(-92 -78,-95 -72,-98 -78,-92 -78)),((-10 -80,-20 -80,-10 -40,-10
-80)),((10 -80,0 -80,5 -70,10 -80),(5 -72,2 -78,8 -78,5
-72))),MULTILINESTRING((-110 -92,-102 -91),(-101 -90,-110 -90),(-100
MULTIPOINT EMPTY
MULTIPOINT EMPTY
MULTILINESTRING EMPTY
GEOS 3.9, MacOS. I've tried some different kinds of normalizing but I just
don't understand what's happening under the hood enough to fix this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4807>
