[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-20-g0a083db
Thu Dec 3 12:18:03 PST 2020
the project "PostGIS".
       via  0a083db6c7399a94051cb8dbe156d79c52e50536 (commit)
      from  99128ad0195da994e0cc82648008103adab75f61 (commit)
revisions in full, below.
commit 0a083db6c7399a94051cb8dbe156d79c52e50536
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Dec 3 11:02:14 2020 -0800
    Polish handling of curvilinear geometry types being
    sent to GEOS. GEOS only takes linear types, so all
    curvilinear types need to be (a) stroked and (b)
    re-typed to a linear type. The lwgeom_has_arc() function
    is to exact for that work: it will correctly note
    that curve types with no curve components have no arc.
    So a new broader test for any type that *might* have
    an arc is added, to handle the GEOS transformation
    situation.
    Closes #4796
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index a5ea431..805ea7c 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2278,8 +2278,24 @@ extern void lwgeom_trim_bits_in_place(LWGEOM *geom, int32_t prec_x, int32_t prec
  * SQLMM internal functions
+* Geometry includes at least one actual circular arc
 int lwgeom_has_arc(const LWGEOM *geom);
+* Geometry type is one of the potentially "arc containing"
+* types (circstring, multicurve, etc) but does not necessarily
+* contain an actual arc.
+int lwgeom_type_arc(const LWGEOM *geom);
+* Convert type with arcs into equivalent linearized type
 LWGEOM *lwgeom_stroke(const LWGEOM *geom, uint32_t perQuad);
+* Convert linearized type into arc type, de-linearizing the
+* strokes where possible.
 LWGEOM *lwgeom_unstroke(const LWGEOM *geom);
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index c2a41ee..e1e8e6a 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -407,7 +407,7 @@ LWGEOM2GEOS(const LWGEOM* lwgeom, uint8_t autofix)
 	LWDEBUGF(4, "LWGEOM2GEOS got a %s", lwtype_name(lwgeom->type));
-	if (lwgeom_has_arc(lwgeom))
+	if (lwgeom_type_arc(lwgeom))
 		LWGEOM* lwgeom_stroked = lwgeom_stroke(lwgeom, 32);
 		GEOSGeometry* g = LWGEOM2GEOS(lwgeom_stroked, autofix);
diff --git a/liblwgeom/lwstroke.c b/liblwgeom/lwstroke.c
index 7377ad4..ff025ff 100644
--- a/liblwgeom/lwstroke.c
+++ b/liblwgeom/lwstroke.c
@@ -72,8 +72,6 @@ lwgeom_has_arc(const LWGEOM *geom)
 	case TINTYPE:
 		return LW_FALSE;
 	case CIRCSTRINGTYPE:
-	case CURVEPOLYTYPE:
-	case COMPOUNDTYPE:
 		return LW_TRUE;
 	/* It's a collection that MAY contain an arc */
 	default:
@@ -87,7 +85,21 @@ lwgeom_has_arc(const LWGEOM *geom)
+int
+lwgeom_type_arc(const LWGEOM *geom)
+	switch (geom->type)
+	case COMPOUNDTYPE:
+	case CIRCSTRINGTYPE:
+	case CURVEPOLYTYPE:
+	case MULTISURFACETYPE:
+	case MULTICURVETYPE:
+		return LW_TRUE;
+	default:
+		return LW_FALSE;
  * Begin curve segmentize functions
diff --git a/regress/core/sql-mm-general.sql b/regress/core/sql-mm-general.sql
index eee49d3..1f898ea 100644
--- a/regress/core/sql-mm-general.sql
+++ b/regress/core/sql-mm-general.sql
@@ -1,20 +1,22 @@
-SELECT ST_HasArc(ST_GeomFromText('POINT(0 0)'));
-SELECT ST_HasArc(ST_GeomFromText('LINESTRING(0 0, 1 1, 1 0)'));
-SELECT ST_HasArc(ST_GeomFromEWKT('CIRCULARSTRING(
+SELECT 'arc1', ST_HasArc(ST_GeomFromText('POINT(0 0)'));
+SELECT 'arc2', ST_HasArc(ST_GeomFromText('LINESTRING(0 0, 1 1, 1 0)'));
+SELECT 'arc2a', ST_HasArc(ST_GeomFromText('COMPOUNDCURVE((0 0, 1 1, 1 0))'));
+SELECT 'arc2b', ST_HasArc(ST_GeomFromText('COMPOUNDCURVE((0 0, 1 1, 1 0), CIRCULARSTRING(1 0, 1 1, 1 0))'));
+SELECT 'arc3', ST_HasArc(ST_GeomFromEWKT('CIRCULARSTRING(
                 0 0 0 0,
                 0.26794919243112270647255365849413 1 3 -2,
                 0.5857864376269049511983112757903 1.4142135623730950488016887242097 1 2)'));
-SELECT ST_HasArc(ST_GeomFromEWKT('COMPOUNDCURVE(CIRCULARSTRING(
+SELECT 'arc4', ST_HasArc(ST_GeomFromEWKT('COMPOUNDCURVE(CIRCULARSTRING(
                 0 0 0 0,
                 0.5857864376269049511983112757903 1.4142135623730950488016887242097 1 2),
                 (0.5857864376269049511983112757903 1.4142135623730950488016887242097 1 2,
                 2 0 0 0,
                 0 0 0 0))'));
-SELECT ST_HasArc(ST_GeomFromEWKT('POLYGON(
+SELECT 'arc5', ST_HasArc(ST_GeomFromEWKT('POLYGON(
                 (-10 -10, 10 -10, 10 10, -10 10, -10 -10),
                 (5 0, 0 5, -5 0, 0 -5, 5 0))'));
-SELECT ST_HasArc(ST_GeomFromEWKT('CURVEPOLYGON(CIRCULARSTRING(
+SELECT 'arc6', ST_HasArc(ST_GeomFromEWKT('CURVEPOLYGON(CIRCULARSTRING(
                 -2 0 0 0,
                 -1 -1 1 2,
                 0 0 2 4,
@@ -27,16 +29,16 @@ SELECT ST_HasArc(ST_GeomFromEWKT('CURVEPOLYGON(CIRCULARSTRING(
                 1 0 3 6,
                 0 1 3 4,
                 -1 0 1 2))'));
-SELECT ST_HasArc(ST_GeomFromEWKT('MULTIPOINT((0 0), (3 2))'));
-SELECT ST_HasArc(ST_GeomFromEWKT('MULTILINESTRING(
+SELECT 'arc7', ST_HasArc(ST_GeomFromEWKT('MULTIPOINT((0 0), (3 2))'));
+SELECT 'arc8', ST_HasArc(ST_GeomFromEWKT('MULTILINESTRING(
                 (0 0, 3 2),
                 (4 8, 9 8),
                 (2 9, 4 8))'));
-SELECT ST_HasArc(ST_GeomFromEWKT('MULTICURVE(
+SELECT 'arc9', ST_HasArc(ST_GeomFromEWKT('MULTICURVE(
                 (0 0, 3 2),
                 (4 8, 9 8),
                 (2 9, 4 8))'));
-SELECT ST_HasArc(ST_GeomFromEWKT('MULTICURVE((
+SELECT 'arc10', ST_HasArc(ST_GeomFromEWKT('MULTICURVE((
                 5 5 1 3,
                 3 5 2 2,
                 3 3 3 1,
@@ -45,15 +47,15 @@ SELECT ST_HasArc(ST_GeomFromEWKT('MULTICURVE((
                 0 0 0 0,
                 0.5857864376269049511983112757903 1.4142135623730950488016887242097 1 2))'));
-SELECT ST_HasArc(ST_GeomFromEWKT('MULTIPOLYGON(
+SELECT 'arc11', ST_HasArc(ST_GeomFromEWKT('MULTIPOLYGON(
                 ((-10 -10, 10 -10, 10 10, -10 10, -10 -10),
                 (5 0, 0 5, -5 0, 0 -5, 5 0)),
                 ((9 2, 3 8, 9 4, 9 2)))'));
-SELECT ST_HasArc(ST_GeomFromEWKT('MULTISURFACE(
+SELECT 'arc12', ST_HasArc(ST_GeomFromEWKT('MULTISURFACE(
-SELECT ST_HasArc(ST_GeomFromEWKT('MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(
+SELECT 'arc13', ST_HasArc(ST_GeomFromEWKT('MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(
                 -2 0 0 0,
                 -1 -1 1 2,
                 0 0 2 4,
diff --git a/regress/core/sql-mm-general_expected b/regress/core/sql-mm-general_expected
index 786d4f9..58044c3 100644
--- a/regress/core/sql-mm-general_expected
+++ b/regress/core/sql-mm-general_expected
@@ -1,14 +1,16 @@
-f
-f
-t
-t
-f
-t
-f
-f
-f
-t
-f
-f
-t
+arc1|f
+arc2|f
+arc2a|f
+arc2b|t
+arc3|t
+arc4|t
+arc5|f
+arc6|t
+arc7|f
+arc8|f
+arc9|f
+arc10|t
+arc11|f
+arc12|f
+arc13|t
 LINESTRING(-13151357.927248 3913656.64539871,-13151419.0845266 3913664.12016378,-13151441.323537 3913666.61175286,-13151456.8908442 3913666.61175286,-13151476.9059536 3913666.61175286,-13151496.921063 3913666.61175287,-13151521.3839744 3913666.61175287,-13151591.4368571 3913665.36595828)
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 523fa66..956a49c 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1313,3 +1313,4 @@ SELECT '#4718',
 SELECT '#4727', _ST_DistanceTree('SRID=4326;POLYGON((-179.9 -85.05112877980659, -179.9 74.99999999999997, -152 80, -130 84.99999999999997, -115 85.05112877980659, -60 85.05112877980659, -60 79, -70 70, -130 50, -80 6, -65 -53, -100 -85.05112877980659, -179.9 -85.05112877980659))'::geography,
 				ST_MakePoint(-150,-40), 0.0, true);
+SELECT '#4796', st_astext(st_snaptogrid(st_normalize(st_simplifypreservetopology('MULTISURFACE(((178632.044 397744.007,178631.118 397743.786,178646.399 397679.574,178693.864 397690.889,178698.958 397669.487,178700.206 397669.784,178758.532 397683.689,178748.351 397726.468,178752.199 397727.384,178748.782 397741.904,178744.897 397740.98,178738.157 397769.303,178632.044 397744.007)))'::geometry,1)),1));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index a60213f..1d56d2e 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -437,3 +437,4 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4748|SRID=3031;POINT(-2399498.7 3213318.5)
 #4718|270.000|90.000
 #4727|0
+#4796|POLYGON((178632 397744,178738 397769,178745 397741,178749 397742,178752 397727,178748 397726,178759 397684,178699 397669,178694 397691,178646 397680,178632 397744))
Summary of changes:
 liblwgeom/liblwgeom.h.in             | 16 ++++++++++++++++
 liblwgeom/lwgeom_geos.c              |  2 +-
 liblwgeom/lwstroke.c                 | 18 +++++++++++++++---
 regress/core/sql-mm-general.sql      | 28 +++++++++++++++-------------
 regress/core/sql-mm-general_expected | 28 +++++++++++++++-------------
 regress/core/tickets.sql             |  1 +
 regress/core/tickets_expected        |  1 +
 7 files changed, 64 insertions(+), 30 deletions(-)
hooks/post-receive
