[postgis-tickets] [PostGIS] #4809: topogeom test failing on debbie
PostGIS trac at osgeo.org
Sat Dec 5 16:06:56 PST 2020
 Reporter:  robe      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  blocker   |  Milestone:  PostGIS 3.1.0
Component:  topology  |    Version:  master
 Keywords:            |
 Looks like the topogeom tests have been failing on debbie at least for the
 past 5 days or so.  Looks like a geos issue might just be order of output
 is different.
 18:23:50  ./topology/test/regress/totopogeom .. failed (diff expected
 obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_1_pg12w64/test_191_diff)
 18:23:51
 18:23:51 --- ./topology/test/regress/totopogeom_expected        2020-03-03
 15:25:18.578620504 +0000
 18:23:51 +++
 /var/lib/jenkins/workspace/postgis/tmp/3_1_pg12w64/test_191_out
 2020-11-30 23:23:51.537992477 +0000
 18:23:51 @@ -24,7 +24,7 @@
 18:23:51  MULTIPOINT(0 -10,5 -10)|t
 18:23:51  MULTILINESTRING((-1 10,-10 10),(-10 8,-2 9))|t
 18:23:51  MULTIPOLYGON(((100 20,110 20,105 30,100 20),(102 22,108 22,105
 28,102 22)),((80 20,90 20,90 60,80 20)))|t
 18:23:51 -GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90
 -90),POLYGON((-100 -80,-90 -80,-95 -70,-100 -80),(-98 -78,-92 -78,-95
 -72,-98 -78)),MULTIPOINT(-100 -110,-95 -110),LINESTRING
 EMPTY,MULTILINESTRING((-101 -90,-110 -90),(-110 -92,-102
 -91)),MULTIPOLYGON(((0 -80,10 -80,5 -70,0 -80),(2 -78,8 -78,5 -72,2
 -78)),((-20 -80,-10 -80,-10 -40,-20
 -80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((-100 -80,-95 -70,-90 -80,-100
 -80),(-98 -78,-92 -78,-95 -72,-98 -78)),((0 -80,5 -70,10 -80,0 -80),(2
 -78,8 -78,5 -72,2 -78)),((-20 -80,-10 -40,-10 -80,-20
 -80))),MULTILINESTRING((-110 -92,-102 -91),(-101 -90,-110 -90),(-100
 -90,-90 -90)),MULTIPOINT(-100 -110,-100 -100,-95 -110))
 18:23:51 +GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90
 -80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((-95 -70,-90 -80,-100 -80,-95
 -70),(-92 -78,-95 -72,-98 -78,-92 -78)),((-10 -80,-20 -80,-10 -40,-10
 -80)),((10 -80,0 -80,5 -70,10 -80),(5 -72,2 -78,8 -78,5
 -72))),MULTILINESTRING((-110 -92,-102 -91),(-101 -90,-110 -90),(-100
 18:23:51  MULTIPOINT EMPTY
 18:23:51  MULTILINESTRING EMPTY
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4809>
