[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-25-g76427f6
git at osgeo.org
git at osgeo.org
Sat Dec 5 17:55:51 PST 2020
the project "PostGIS".
via 76427f6b01c37dd005659353d9c6474455842c6b (commit)
from fa9e07d775235fc7dba60b0ab64487286e521de5 (commit)
revisions in full, below.
commit 76427f6b01c37dd005659353d9c6474455842c6b
Author: Regina Obe <lr at pcorp.us>
Date: Sat Dec 5 20:55:42 2020 -0500
Fix for GEOS 3.9 regression topogeom - closes #4809 for PostGIS 3.1
diff --git a/liblwgeom/lwin_wkt_parse.c b/liblwgeom/lwin_wkt_parse.c
index d9ecfcb..122d4ce 100644
--- a/liblwgeom/lwin_wkt_parse.c
+++ b/liblwgeom/lwin_wkt_parse.c
@@ -1,9 +1,8 @@
-/* A Bison parser, made by GNU Bison 3.4.2. */
+/* A Bison parser, made by GNU Bison 3.0.4. */
/* Bison implementation for Yacc-like parsers in C
- Copyright (C) 1984, 1989-1990, 2000-2015, 2018-2019 Free Software Foundation,
- Inc.
+ Copyright (C) 1984, 1989-1990, 2000-2015 Free Software Foundation, Inc.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
@@ -41,14 +40,11 @@
define necessary library symbols; they are noted "INFRINGES ON
USER NAME SPACE" below. */
-/* Undocumented macros, especially those whose name start with YY_,
- are private implementation details. Do not rely on them. */
/* Identify Bison output. */
#define YYBISON 1
/* Bison version. */
-#define YYBISON_VERSION "3.4.2"
+#define YYBISON_VERSION "3.0.4"
/* Skeleton name. */
#define YYSKELETON_NAME "yacc.c"
@@ -74,8 +70,8 @@
#define yychar wkt_yychar
#define yylloc wkt_yylloc
-/* First part of user prologue. */
-#line 1 "lwin_wkt_parse.y"
+/* Copy the first part of user declarations. */
+#line 1 "lwin_wkt_parse.y" /* yacc.c:339 */
/* WKT Parser */
@@ -183,17 +179,13 @@ int lwgeom_parse_wkt(LWGEOM_PARSER_RESULT *parser_result, char *wktstr, int pars
-#line 187 "lwin_wkt_parse.c"
+#line 183 "lwin_wkt_parse.c" /* yacc.c:339 */
# ifndef YY_NULLPTR
-# if defined __cplusplus
-# if 201103L <= __cplusplus
-# define YY_NULLPTR nullptr
-# else
-# define YY_NULLPTR 0
-# endif
+# if defined __cplusplus && 201103L <= __cplusplus
+# define YY_NULLPTR nullptr
# else
-# define YY_NULLPTR ((void*)0)
+# define YY_NULLPTR 0
# endif
# endif
@@ -205,8 +197,8 @@ int lwgeom_parse_wkt(LWGEOM_PARSER_RESULT *parser_result, char *wktstr, int pars
# define YYERROR_VERBOSE 1
#endif
-/* Use api.header.include to #include this header
- instead of duplicating it here. */
+/* In a future release of Bison, this section will be replaced
+ by #include "lwin_wkt_parse.h". */
#ifndef YY_WKT_YY_LWIN_WKT_PARSE_H_INCLUDED
# define YY_WKT_YY_LWIN_WKT_PARSE_H_INCLUDED
/* Debug traces. */
@@ -250,9 +242,10 @@ extern int wkt_yydebug;
/* Value type. */
#if ! defined YYSTYPE && ! defined YYSTYPE_IS_DECLARED
union YYSTYPE
-#line 112 "lwin_wkt_parse.y"
+#line 112 "lwin_wkt_parse.y" /* yacc.c:355 */
int integervalue;
double doublevalue;
@@ -261,9 +254,9 @@ union YYSTYPE
POINT coordinatevalue;
POINTARRAY *ptarrayvalue;
-#line 265 "lwin_wkt_parse.c"
+#line 258 "lwin_wkt_parse.c" /* yacc.c:355 */
typedef union YYSTYPE YYSTYPE;
# define YYSTYPE_IS_TRIVIAL 1
# define YYSTYPE_IS_DECLARED 1
@@ -290,7 +283,9 @@ int wkt_yyparse (void);
#endif /* !YY_WKT_YY_LWIN_WKT_PARSE_H_INCLUDED */
+/* Copy the second part of user declarations. */
+#line 289 "lwin_wkt_parse.c" /* yacc.c:358 */
#ifdef short
# undef short
@@ -311,13 +306,13 @@ typedef signed char yytype_int8;
#ifdef YYTYPE_UINT16
typedef YYTYPE_UINT16 yytype_uint16;
#else
-typedef unsigned short yytype_uint16;
+typedef unsigned short int yytype_uint16;
#endif
#ifdef YYTYPE_INT16
typedef YYTYPE_INT16 yytype_int16;
#else
-typedef short yytype_int16;
+typedef short int yytype_int16;
#endif
#ifndef YYSIZE_T
@@ -329,7 +324,7 @@ typedef short yytype_int16;
# include <stddef.h> /* INFRINGES ON USER NAME SPACE */
# define YYSIZE_T size_t
# else
-# define YYSIZE_T unsigned
+# define YYSIZE_T unsigned int
# endif
#endif
@@ -365,6 +360,15 @@ typedef short yytype_int16;
# define YY_ATTRIBUTE_UNUSED YY_ATTRIBUTE ((__unused__))
#endif
+#if !defined _Noreturn \
+ && (!defined __STDC_VERSION__ || __STDC_VERSION__ < 201112)
+# if defined _MSC_VER && 1200 <= _MSC_VER
+# define _Noreturn __declspec (noreturn)
+# else
+# define _Noreturn YY_ATTRIBUTE ((__noreturn__))
+# endif
+#endif
/* Suppress unused-variable warnings by "using" E. */
#if ! defined lint || defined __GNUC__
# define YYUSE(E) ((void) (E))
@@ -372,7 +376,7 @@ typedef short yytype_int16;
# define YYUSE(E) /* empty */
#endif
-#if defined __GNUC__ && ! defined __ICC && 407 <= __GNUC__ * 100 + __GNUC_MINOR__
+#if defined __GNUC__ && 407 <= __GNUC__ * 100 + __GNUC_MINOR__
/* Suppress an incorrect diagnostic about yylval being uninitialized. */
# define YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN \
_Pragma ("GCC diagnostic push") \
@@ -392,8 +396,6 @@ typedef short yytype_int16;
#endif
-#define YY_ASSERT(E) ((void) (0 && (E)))
#if ! defined yyoverflow || YYERROR_VERBOSE
/* The parser invokes alloca or malloc; define the necessary symbols. */
@@ -538,16 +540,16 @@ union yyalloc
/* YYNSTATES -- Number of states. */
#define YYNSTATES 264
+/* YYTRANSLATE[YYX] -- Symbol number corresponding to YYX as returned
+ by yylex, with out-of-bounds checking. */
#define YYUNDEFTOK 2
#define YYMAXUTOK 280
-/* YYTRANSLATE(TOKEN-NUM) -- Symbol number corresponding to TOKEN-NUM
- as returned by yylex, with out-of-bounds checking. */
#define YYTRANSLATE(YYX) \
- ((unsigned) (YYX) <= YYMAXUTOK ? yytranslate[YYX] : YYUNDEFTOK)
+ ((unsigned int) (YYX) <= YYMAXUTOK ? yytranslate[YYX] : YYUNDEFTOK)
/* YYTRANSLATE[TOKEN-NUM] -- Symbol number corresponding to TOKEN-NUM
- as returned by yylex. */
+ as returned by yylex, without out-of-bounds checking. */
static const yytype_uint8 yytranslate[] =
0, 2, 2, 2, 2, 2, 2, 2, 2, 2,
@@ -887,22 +889,22 @@ static const yytype_uint8 yyr2[] =
#define YYRECOVERING() (!!yyerrstatus)
-#define YYBACKUP(Token, Value) \
- do \
- if (yychar == YYEMPTY) \
- yychar = (Token); \
- yylval = (Value); \
- YYPOPSTACK (yylen); \
- yystate = *yyssp; \
- goto yybackup; \
- else \
- yyerror (YY_("syntax error: cannot back up")); \
- YYERROR; \
- while (0)
+#define YYBACKUP(Token, Value) \
+do \
+ if (yychar == YYEMPTY) \
+ yychar = (Token); \
+ yylval = (Value); \
+ YYPOPSTACK (yylen); \
+ yystate = *yyssp; \
+ goto yybackup; \
+ else \
+ yyerror (YY_("syntax error: cannot back up")); \
+ YYERROR; \
+while (0)
/* Error token number */
#define YYTERROR 1
@@ -961,10 +963,10 @@ do { \
/* Print *YYLOCP on YYO. Private, do not rely on its existence. */
YY_ATTRIBUTE_UNUSED
-static int
+static unsigned
yy_location_print_ (FILE *yyo, YYLTYPE const * const yylocp)
- int res = 0;
+ unsigned res = 0;
int end_col = 0 != yylocp->last_column ? yylocp->last_column - 1 : 0;
if (0 <= yylocp->first_line)
@@ -1007,42 +1009,40 @@ do { \
} while (0)
-| Print this symbol's value on YYO. |
+| Print this symbol's value on YYOUTPUT. |
static void
-yy_symbol_value_print (FILE *yyo, int yytype, YYSTYPE const * const yyvaluep, YYLTYPE const * const yylocationp)
+yy_symbol_value_print (FILE *yyoutput, int yytype, YYSTYPE const * const yyvaluep, YYLTYPE const * const yylocationp)
- FILE *yyoutput = yyo;
- YYUSE (yyoutput);
+ FILE *yyo = yyoutput;
+ YYUSE (yyo);
YYUSE (yylocationp);
if (!yyvaluep)
return;
# ifdef YYPRINT
if (yytype < YYNTOKENS)
- YYPRINT (yyo, yytoknum[yytype], *yyvaluep);
+ YYPRINT (yyoutput, yytoknum[yytype], *yyvaluep);
# endif
- YY_IGNORE_MAYBE_UNINITIALIZED_BEGIN
YYUSE (yytype);
- YY_IGNORE_MAYBE_UNINITIALIZED_END
-| Print this symbol on YYO. |
+| Print this symbol on YYOUTPUT. |
static void
-yy_symbol_print (FILE *yyo, int yytype, YYSTYPE const * const yyvaluep, YYLTYPE const * const yylocationp)
+yy_symbol_print (FILE *yyoutput, int yytype, YYSTYPE const * const yyvaluep, YYLTYPE const * const yylocationp)
- YYFPRINTF (yyo, "%s %s (",
+ YYFPRINTF (yyoutput, "%s %s (",
yytype < YYNTOKENS ? "token" : "nterm", yytname[yytype]);
- YY_LOCATION_PRINT (yyo, *yylocationp);
- YYFPRINTF (yyo, ": ");
- yy_symbol_value_print (yyo, yytype, yyvaluep, yylocationp);
- YYFPRINTF (yyo, ")");
+ YY_LOCATION_PRINT (yyoutput, *yylocationp);
+ YYFPRINTF (yyoutput, ": ");
+ yy_symbol_value_print (yyoutput, yytype, yyvaluep, yylocationp);
+ YYFPRINTF (yyoutput, ")");
@@ -1076,7 +1076,7 @@ do { \
static void
yy_reduce_print (yytype_int16 *yyssp, YYSTYPE *yyvsp, YYLTYPE *yylsp, int yyrule)
- unsigned long yylno = yyrline[yyrule];
+ unsigned long int yylno = yyrline[yyrule];
int yynrhs = yyr2[yyrule];
int yyi;
YYFPRINTF (stderr, "Reducing stack by rule %d (line %lu):\n",
@@ -1087,7 +1087,7 @@ yy_reduce_print (yytype_int16 *yyssp, YYSTYPE *yyvsp, YYLTYPE *yylsp, int yyrule
YYFPRINTF (stderr, " $%d = ", yyi + 1);
yy_symbol_print (stderr,
yystos[yyssp[yyi + 1 - yynrhs]],
- &yyvsp[(yyi + 1) - (yynrhs)]
+ &(yyvsp[(yyi + 1) - (yynrhs)])
, &(yylsp[(yyi + 1) - (yynrhs)]) );
YYFPRINTF (stderr, "\n");
@@ -1191,10 +1191,7 @@ yytnamerr (char *yyres, const char *yystr)
case '\\':
if (*++yyp != '\\')
goto do_not_strip_quotes;
- else
- goto append;
- append:
+ /* Fall through. */
default:
if (yyres)
yyres[yyn] = *yyp;
@@ -1212,7 +1209,7 @@ yytnamerr (char *yyres, const char *yystr)
if (! yyres)
return yystrlen (yystr);
- return (YYSIZE_T) (yystpcpy (yyres, yystr) - yyres);
+ return yystpcpy (yyres, yystr) - yyres;
# endif
@@ -1290,10 +1287,10 @@ yysyntax_error (YYSIZE_T *yymsg_alloc, char **yymsg,
yyarg[yycount++] = yytname[yyx];
YYSIZE_T yysize1 = yysize + yytnamerr (YY_NULLPTR, yytname[yyx]);
- if (yysize <= yysize1 && yysize1 <= YYSTACK_ALLOC_MAXIMUM)
- yysize = yysize1;
- else
+ if (! (yysize <= yysize1
+ && yysize1 <= YYSTACK_ALLOC_MAXIMUM))
return 2;
+ yysize = yysize1;
@@ -1305,7 +1302,6 @@ yysyntax_error (YYSIZE_T *yymsg_alloc, char **yymsg,
case N: \
yyformat = S; \
break
- default: /* Avoid compiler warnings. */
YYCASE_(0, YY_("syntax error"));
YYCASE_(1, YY_("syntax error, unexpected %s"));
YYCASE_(2, YY_("syntax error, unexpected %s, expecting %s"));
@@ -1317,10 +1313,9 @@ yysyntax_error (YYSIZE_T *yymsg_alloc, char **yymsg,
YYSIZE_T yysize1 = yysize + yystrlen (yyformat);
- yysize = yysize1;
- else
+ if (! (yysize <= yysize1 && yysize1 <= YYSTACK_ALLOC_MAXIMUM))
return 2;
+ yysize = yysize1;
if (*yymsg_alloc < yysize)
@@ -1370,228 +1365,229 @@ yydestruct (const char *yymsg, int yytype, YYSTYPE *yyvaluep, YYLTYPE *yylocatio
switch (yytype)
- case 28: /* geometry_no_srid */
-#line 194 "lwin_wkt_parse.y"
+ case 28: /* geometry_no_srid */
+#line 194 "lwin_wkt_parse.y" /* yacc.c:1257 */
{ lwgeom_free(((*yyvaluep).geometryvalue)); }
-#line 1377 "lwin_wkt_parse.c"
+#line 1372 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 29: /* geometrycollection */
-#line 195 "lwin_wkt_parse.y"
+#line 195 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1383 "lwin_wkt_parse.c"
+#line 1378 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 30: /* geometry_list */
-#line 196 "lwin_wkt_parse.y"
+#line 196 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1389 "lwin_wkt_parse.c"
+#line 1384 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 31: /* multisurface */
-#line 203 "lwin_wkt_parse.y"
+#line 203 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1395 "lwin_wkt_parse.c"
+#line 1390 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 32: /* surface_list */
-#line 181 "lwin_wkt_parse.y"
+#line 181 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1401 "lwin_wkt_parse.c"
+#line 1396 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 33: /* tin */
-#line 210 "lwin_wkt_parse.y"
+#line 210 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1407 "lwin_wkt_parse.c"
+#line 1402 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 34: /* polyhedralsurface */
-#line 209 "lwin_wkt_parse.y"
+#line 209 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1413 "lwin_wkt_parse.c"
+#line 1408 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 35: /* multipolygon */
-#line 202 "lwin_wkt_parse.y"
+#line 202 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1419 "lwin_wkt_parse.c"
+#line 1414 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 36: /* polygon_list */
-#line 182 "lwin_wkt_parse.y"
+#line 182 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1425 "lwin_wkt_parse.c"
+#line 1420 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 37: /* patch_list */
-#line 183 "lwin_wkt_parse.y"
+#line 183 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1431 "lwin_wkt_parse.c"
+#line 1426 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 38: /* polygon */
-#line 206 "lwin_wkt_parse.y"
+#line 206 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1437 "lwin_wkt_parse.c"
+#line 1432 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 39: /* polygon_untagged */
-#line 208 "lwin_wkt_parse.y"
+#line 208 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1443 "lwin_wkt_parse.c"
+#line 1438 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 40: /* patch */
-#line 207 "lwin_wkt_parse.y"
+#line 207 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1449 "lwin_wkt_parse.c"
+#line 1444 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 41: /* curvepolygon */
-#line 192 "lwin_wkt_parse.y"
+#line 192 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1455 "lwin_wkt_parse.c"
+#line 1450 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 42: /* curvering_list */
-#line 179 "lwin_wkt_parse.y"
+#line 179 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1461 "lwin_wkt_parse.c"
+#line 1456 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 43: /* curvering */
-#line 193 "lwin_wkt_parse.y"
+#line 193 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1467 "lwin_wkt_parse.c"
+#line 1462 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 44: /* patchring_list */
-#line 189 "lwin_wkt_parse.y"
+#line 189 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1473 "lwin_wkt_parse.c"
+#line 1468 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 45: /* ring_list */
-#line 188 "lwin_wkt_parse.y"
+#line 188 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1479 "lwin_wkt_parse.c"
+#line 1474 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 46: /* patchring */
-#line 178 "lwin_wkt_parse.y"
+#line 178 "lwin_wkt_parse.y" /* yacc.c:1257 */
{ ptarray_free(((*yyvaluep).ptarrayvalue)); }
-#line 1485 "lwin_wkt_parse.c"
+#line 1480 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 47: /* ring */
-#line 177 "lwin_wkt_parse.y"
+#line 177 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1491 "lwin_wkt_parse.c"
+#line 1486 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 48: /* compoundcurve */
-#line 191 "lwin_wkt_parse.y"
+#line 191 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1497 "lwin_wkt_parse.c"
+#line 1492 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 49: /* compound_list */
-#line 187 "lwin_wkt_parse.y"
+#line 187 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1503 "lwin_wkt_parse.c"
+#line 1498 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 50: /* multicurve */
-#line 199 "lwin_wkt_parse.y"
+#line 199 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1509 "lwin_wkt_parse.c"
+#line 1504 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 51: /* curve_list */
-#line 186 "lwin_wkt_parse.y"
+#line 186 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1515 "lwin_wkt_parse.c"
+#line 1510 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 52: /* multilinestring */
-#line 200 "lwin_wkt_parse.y"
+#line 200 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1521 "lwin_wkt_parse.c"
+#line 1516 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 53: /* linestring_list */
-#line 185 "lwin_wkt_parse.y"
+#line 185 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1527 "lwin_wkt_parse.c"
+#line 1522 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 54: /* circularstring */
-#line 190 "lwin_wkt_parse.y"
+#line 190 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1533 "lwin_wkt_parse.c"
+#line 1528 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 55: /* linestring */
-#line 197 "lwin_wkt_parse.y"
+#line 197 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1539 "lwin_wkt_parse.c"
+#line 1534 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 56: /* linestring_untagged */
-#line 198 "lwin_wkt_parse.y"
+#line 198 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1545 "lwin_wkt_parse.c"
+#line 1540 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 57: /* triangle_list */
-#line 180 "lwin_wkt_parse.y"
+#line 180 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1551 "lwin_wkt_parse.c"
+#line 1546 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 58: /* triangle */
-#line 211 "lwin_wkt_parse.y"
+#line 211 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1557 "lwin_wkt_parse.c"
+#line 1552 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 59: /* triangle_untagged */
-#line 212 "lwin_wkt_parse.y"
+#line 212 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1563 "lwin_wkt_parse.c"
+#line 1558 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 60: /* multipoint */
-#line 201 "lwin_wkt_parse.y"
+#line 201 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1569 "lwin_wkt_parse.c"
+#line 1564 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 61: /* point_list */
-#line 184 "lwin_wkt_parse.y"
+#line 184 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1575 "lwin_wkt_parse.c"
+#line 1570 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 62: /* point_untagged */
-#line 205 "lwin_wkt_parse.y"
+#line 205 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1581 "lwin_wkt_parse.c"
+#line 1576 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 63: /* point */
-#line 204 "lwin_wkt_parse.y"
+#line 204 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1587 "lwin_wkt_parse.c"
+#line 1582 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
case 64: /* ptarray */
-#line 176 "lwin_wkt_parse.y"
+#line 176 "lwin_wkt_parse.y" /* yacc.c:1257 */
-#line 1593 "lwin_wkt_parse.c"
+#line 1588 "lwin_wkt_parse.c" /* yacc.c:1257 */
break;
default:
break;
@@ -1691,33 +1687,23 @@ yyparse (void)
yylsp[0] = yylloc;
goto yysetstate;
-| yynewstate -- push a new state, which is found in yystate. |
+| yynewstate -- Push a new state, which is found in yystate. |
-yynewstate:
+ yynewstate:
/* In all cases, when you get here, the value and location stacks
have just been pushed. So pushing a state here evens the stacks. */
yyssp++;
-| yynewstate -- set current state (the top of the stack) to yystate. |
-yysetstate:
- YYDPRINTF ((stderr, "Entering state %d\n", yystate));
- YY_ASSERT (0 <= yystate && yystate < YYNSTATES);
- *yyssp = (yytype_int16) yystate;
+ yysetstate:
+ *yyssp = yystate;
if (yyss + yystacksize - 1 <= yyssp)
-#if !defined yyoverflow && !defined YYSTACK_RELOCATE
- goto yyexhaustedlab;
-#else
/* Get the current used size of the three stacks, in elements. */
- YYSIZE_T yysize = (YYSIZE_T) (yyssp - yyss + 1);
+ YYSIZE_T yysize = yyssp - yyss + 1;
-# if defined yyoverflow
+#ifdef yyoverflow
/* Give user a chance to reallocate the stack. Use copies of
these so that the &'s don't force the real ones into
@@ -1735,11 +1721,15 @@ yysetstate:
&yyvs1, yysize * sizeof (*yyvsp),
&yyls1, yysize * sizeof (*yylsp),
&yystacksize);
+ yyls = yyls1;
yyss = yyss1;
yyvs = yyvs1;
- yyls = yyls1;
-# else /* defined YYSTACK_RELOCATE */
+#else /* no yyoverflow */
+# ifndef YYSTACK_RELOCATE
+ goto yyexhaustedlab;
+# else
/* Extend the stack our own way. */
if (YYMAXDEPTH <= yystacksize)
@@ -1756,34 +1746,36 @@ yysetstate:
YYSTACK_RELOCATE (yyss_alloc, yyss);
YYSTACK_RELOCATE (yyvs_alloc, yyvs);
YYSTACK_RELOCATE (yyls_alloc, yyls);
-# undef YYSTACK_RELOCATE
+# undef YYSTACK_RELOCATE
if (yyss1 != yyssa)
YYSTACK_FREE (yyss1);
# endif
+#endif /* no yyoverflow */
yyssp = yyss + yysize - 1;
yyvsp = yyvs + yysize - 1;
yylsp = yyls + yysize - 1;
YYDPRINTF ((stderr, "Stack size increased to %lu\n",
- (unsigned long) yystacksize));
+ (unsigned long int) yystacksize));
YYABORT;
-#endif /* !defined yyoverflow && !defined YYSTACK_RELOCATE */
+ YYDPRINTF ((stderr, "Entering state %d\n", yystate));
if (yystate == YYFINAL)
YYACCEPT;
goto yybackup;
| yybackup. |
yybackup:
/* Do appropriate processing given the current state. Read a
lookahead token if we need one and don't already have one. */
@@ -1856,7 +1848,7 @@ yydefault:
-| yyreduce -- do a reduction. |
+| yyreduce -- Do a reduction. |
yyreduce:
/* yyn is the number of a rule to reduce with. */
@@ -1872,825 +1864,823 @@ yyreduce:
GCC warning that YYVAL may be used uninitialized. */
yyval = yyvsp[1-yylen];
- /* Default location. */
+ /* Default location. */
YYLLOC_DEFAULT (yyloc, (yylsp - yylen), yylen);
- yyerror_range[1] = yyloc;
YY_REDUCE_PRINT (yyn);
switch (yyn)
- case 2:
-#line 218 "lwin_wkt_parse.y"
+ case 2:
+#line 218 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ wkt_parser_geometry_new((yyvsp[0].geometryvalue), SRID_UNKNOWN); WKT_ERROR(); }
-#line 1885 "lwin_wkt_parse.c"
+#line 1876 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 3:
-#line 220 "lwin_wkt_parse.y"
+#line 220 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ wkt_parser_geometry_new((yyvsp[0].geometryvalue), (yyvsp[-2].integervalue)); WKT_ERROR(); }
-#line 1891 "lwin_wkt_parse.c"
+#line 1882 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 4:
-#line 223 "lwin_wkt_parse.y"
+#line 223 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = (yyvsp[0].geometryvalue); }
-#line 1897 "lwin_wkt_parse.c"
+#line 1888 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 5:
-#line 224 "lwin_wkt_parse.y"
+#line 224 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1903 "lwin_wkt_parse.c"
+#line 1894 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 6:
-#line 225 "lwin_wkt_parse.y"
+#line 225 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1909 "lwin_wkt_parse.c"
+#line 1900 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 7:
-#line 226 "lwin_wkt_parse.y"
+#line 226 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1915 "lwin_wkt_parse.c"
+#line 1906 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 8:
-#line 227 "lwin_wkt_parse.y"
+#line 227 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1921 "lwin_wkt_parse.c"
+#line 1912 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 9:
-#line 228 "lwin_wkt_parse.y"
+#line 228 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1927 "lwin_wkt_parse.c"
+#line 1918 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 10:
-#line 229 "lwin_wkt_parse.y"
+#line 229 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1933 "lwin_wkt_parse.c"
+#line 1924 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 11:
-#line 230 "lwin_wkt_parse.y"
+#line 230 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1939 "lwin_wkt_parse.c"
+#line 1930 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 12:
-#line 231 "lwin_wkt_parse.y"
+#line 231 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1945 "lwin_wkt_parse.c"
+#line 1936 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 13:
-#line 232 "lwin_wkt_parse.y"
+#line 232 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1951 "lwin_wkt_parse.c"
+#line 1942 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 14:
-#line 233 "lwin_wkt_parse.y"
+#line 233 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1957 "lwin_wkt_parse.c"
+#line 1948 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 15:
-#line 234 "lwin_wkt_parse.y"
+#line 234 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1963 "lwin_wkt_parse.c"
+#line 1954 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 16:
-#line 235 "lwin_wkt_parse.y"
+#line 235 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1969 "lwin_wkt_parse.c"
+#line 1960 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 17:
-#line 236 "lwin_wkt_parse.y"
+#line 236 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1975 "lwin_wkt_parse.c"
+#line 1966 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 18:
-#line 237 "lwin_wkt_parse.y"
+#line 237 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 1981 "lwin_wkt_parse.c"
+#line 1972 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 19:
-#line 241 "lwin_wkt_parse.y"
+#line 241 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 1987 "lwin_wkt_parse.c"
+#line 1978 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 20:
-#line 243 "lwin_wkt_parse.y"
+#line 243 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 1993 "lwin_wkt_parse.c"
+#line 1984 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 21:
-#line 245 "lwin_wkt_parse.y"
+#line 245 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 1999 "lwin_wkt_parse.c"
+#line 1990 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 22:
-#line 247 "lwin_wkt_parse.y"
+#line 247 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COLLECTIONTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2005 "lwin_wkt_parse.c"
+#line 1996 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 23:
-#line 251 "lwin_wkt_parse.y"
+#line 251 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_add_geom((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2011 "lwin_wkt_parse.c"
+#line 2002 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 24:
-#line 253 "lwin_wkt_parse.y"
+#line 253 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2017 "lwin_wkt_parse.c"
+#line 2008 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 25:
-#line 257 "lwin_wkt_parse.y"
+#line 257 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2023 "lwin_wkt_parse.c"
+#line 2014 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 26:
-#line 259 "lwin_wkt_parse.y"
+#line 259 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2029 "lwin_wkt_parse.c"
+#line 2020 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 27:
-#line 261 "lwin_wkt_parse.y"
+#line 261 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2035 "lwin_wkt_parse.c"
+#line 2026 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 28:
-#line 263 "lwin_wkt_parse.y"
+#line 263 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTISURFACETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2041 "lwin_wkt_parse.c"
+#line 2032 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 29:
-#line 267 "lwin_wkt_parse.y"
+#line 267 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2047 "lwin_wkt_parse.c"
+#line 2038 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 30:
-#line 269 "lwin_wkt_parse.y"
+#line 269 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2053 "lwin_wkt_parse.c"
+#line 2044 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 31:
-#line 271 "lwin_wkt_parse.y"
+#line 271 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2059 "lwin_wkt_parse.c"
+#line 2050 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 32:
-#line 273 "lwin_wkt_parse.y"
+#line 273 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2065 "lwin_wkt_parse.c"
+#line 2056 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 33:
-#line 275 "lwin_wkt_parse.y"
+#line 275 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2071 "lwin_wkt_parse.c"
+#line 2062 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 34:
-#line 277 "lwin_wkt_parse.y"
+#line 277 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2077 "lwin_wkt_parse.c"
+#line 2068 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 35:
-#line 281 "lwin_wkt_parse.y"
+#line 281 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2083 "lwin_wkt_parse.c"
+#line 2074 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 36:
-#line 283 "lwin_wkt_parse.y"
+#line 283 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2089 "lwin_wkt_parse.c"
+#line 2080 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 37:
-#line 285 "lwin_wkt_parse.y"
+#line 285 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2095 "lwin_wkt_parse.c"
+#line 2086 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 38:
-#line 287 "lwin_wkt_parse.y"
+#line 287 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(TINTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2101 "lwin_wkt_parse.c"
+#line 2092 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 39:
-#line 291 "lwin_wkt_parse.y"
+#line 291 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2107 "lwin_wkt_parse.c"
+#line 2098 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 40:
-#line 293 "lwin_wkt_parse.y"
+#line 293 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2113 "lwin_wkt_parse.c"
+#line 2104 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 41:
-#line 295 "lwin_wkt_parse.y"
+#line 295 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2119 "lwin_wkt_parse.c"
+#line 2110 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 42:
-#line 297 "lwin_wkt_parse.y"
+#line 297 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(POLYHEDRALSURFACETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2125 "lwin_wkt_parse.c"
+#line 2116 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 43:
-#line 301 "lwin_wkt_parse.y"
+#line 301 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2131 "lwin_wkt_parse.c"
+#line 2122 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 44:
-#line 303 "lwin_wkt_parse.y"
+#line 303 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2137 "lwin_wkt_parse.c"
+#line 2128 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 45:
-#line 305 "lwin_wkt_parse.y"
+#line 305 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2143 "lwin_wkt_parse.c"
+#line 2134 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 46:
-#line 307 "lwin_wkt_parse.y"
+#line 307 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOLYGONTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2149 "lwin_wkt_parse.c"
+#line 2140 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 47:
-#line 311 "lwin_wkt_parse.y"
+#line 311 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2155 "lwin_wkt_parse.c"
+#line 2146 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 48:
-#line 313 "lwin_wkt_parse.y"
+#line 313 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2161 "lwin_wkt_parse.c"
+#line 2152 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 49:
-#line 317 "lwin_wkt_parse.y"
+#line 317 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2167 "lwin_wkt_parse.c"
+#line 2158 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 50:
-#line 319 "lwin_wkt_parse.y"
+#line 319 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2173 "lwin_wkt_parse.c"
+#line 2164 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 51:
-#line 323 "lwin_wkt_parse.y"
+#line 323 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize((yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2179 "lwin_wkt_parse.c"
+#line 2170 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 52:
-#line 325 "lwin_wkt_parse.y"
+#line 325 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize((yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2185 "lwin_wkt_parse.c"
+#line 2176 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 53:
-#line 327 "lwin_wkt_parse.y"
+#line 327 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2191 "lwin_wkt_parse.c"
+#line 2182 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 54:
-#line 329 "lwin_wkt_parse.y"
+#line 329 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_polygon_finalize(NULL, NULL); WKT_ERROR(); }
-#line 2197 "lwin_wkt_parse.c"
+#line 2188 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 55:
-#line 333 "lwin_wkt_parse.y"
+#line 333 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = (yyvsp[-1].geometryvalue); }
-#line 2203 "lwin_wkt_parse.c"
+#line 2194 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 56:
-#line 335 "lwin_wkt_parse.y"
+#line 335 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2209 "lwin_wkt_parse.c"
+#line 2200 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 57:
-#line 338 "lwin_wkt_parse.y"
+#line 338 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2215 "lwin_wkt_parse.c"
+#line 2206 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 58:
-#line 342 "lwin_wkt_parse.y"
+#line 342 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize((yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2221 "lwin_wkt_parse.c"
+#line 2212 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 59:
-#line 344 "lwin_wkt_parse.y"
+#line 344 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize((yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2227 "lwin_wkt_parse.c"
+#line 2218 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 60:
-#line 346 "lwin_wkt_parse.y"
+#line 346 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2233 "lwin_wkt_parse.c"
+#line 2224 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 61:
-#line 348 "lwin_wkt_parse.y"
+#line 348 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_finalize(NULL, NULL); WKT_ERROR(); }
-#line 2239 "lwin_wkt_parse.c"
+#line 2230 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 62:
-#line 352 "lwin_wkt_parse.y"
+#line 352 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2245 "lwin_wkt_parse.c"
+#line 2236 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 63:
-#line 354 "lwin_wkt_parse.y"
+#line 354 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_curvepolygon_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2251 "lwin_wkt_parse.c"
+#line 2242 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 64:
-#line 357 "lwin_wkt_parse.y"
+#line 357 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2257 "lwin_wkt_parse.c"
+#line 2248 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 65:
-#line 358 "lwin_wkt_parse.y"
+#line 358 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2263 "lwin_wkt_parse.c"
+#line 2254 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 66:
-#line 359 "lwin_wkt_parse.y"
+#line 359 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2269 "lwin_wkt_parse.c"
+#line 2260 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 67:
-#line 360 "lwin_wkt_parse.y"
+#line 360 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2275 "lwin_wkt_parse.c"
+#line 2266 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 68:
-#line 364 "lwin_wkt_parse.y"
+#line 364 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_polygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].ptarrayvalue),'Z'); WKT_ERROR(); }
-#line 2281 "lwin_wkt_parse.c"
+#line 2272 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 69:
-#line 366 "lwin_wkt_parse.y"
+#line 366 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_polygon_new((yyvsp[0].ptarrayvalue),'Z'); WKT_ERROR(); }
-#line 2287 "lwin_wkt_parse.c"
+#line 2278 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 70:
-#line 370 "lwin_wkt_parse.y"
+#line 370 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_polygon_add_ring((yyvsp[-2].geometryvalue),(yyvsp[0].ptarrayvalue),'2'); WKT_ERROR(); }
-#line 2293 "lwin_wkt_parse.c"
+#line 2284 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 71:
-#line 372 "lwin_wkt_parse.y"
+#line 372 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_polygon_new((yyvsp[0].ptarrayvalue),'2'); WKT_ERROR(); }
-#line 2299 "lwin_wkt_parse.c"
+#line 2290 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 72:
-#line 375 "lwin_wkt_parse.y"
+#line 375 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.ptarrayvalue) = (yyvsp[-1].ptarrayvalue); }
-#line 2305 "lwin_wkt_parse.c"
+#line 2296 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 73:
-#line 378 "lwin_wkt_parse.y"
+#line 378 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2311 "lwin_wkt_parse.c"
+#line 2302 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 74:
-#line 382 "lwin_wkt_parse.y"
+#line 382 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2317 "lwin_wkt_parse.c"
+#line 2308 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 75:
-#line 384 "lwin_wkt_parse.y"
+#line 384 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2323 "lwin_wkt_parse.c"
+#line 2314 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 76:
-#line 386 "lwin_wkt_parse.y"
+#line 386 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2329 "lwin_wkt_parse.c"
+#line 2320 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 77:
-#line 388 "lwin_wkt_parse.y"
+#line 388 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(COMPOUNDTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2335 "lwin_wkt_parse.c"
+#line 2326 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 78:
-#line 392 "lwin_wkt_parse.y"
+#line 392 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_compound_add_geom((yyvsp[-2].geometryvalue),(yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2341 "lwin_wkt_parse.c"
+#line 2332 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 79:
-#line 394 "lwin_wkt_parse.y"
+#line 394 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2347 "lwin_wkt_parse.c"
+#line 2338 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 80:
-#line 396 "lwin_wkt_parse.y"
+#line 396 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2353 "lwin_wkt_parse.c"
+#line 2344 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 81:
-#line 398 "lwin_wkt_parse.y"
+#line 398 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_compound_new((yyvsp[0].geometryvalue)); WKT_ERROR(); }
-#line 2359 "lwin_wkt_parse.c"
+#line 2350 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 82:
-#line 400 "lwin_wkt_parse.y"
+#line 400 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2365 "lwin_wkt_parse.c"
+#line 2356 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 83:
-#line 402 "lwin_wkt_parse.y"
+#line 402 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2371 "lwin_wkt_parse.c"
+#line 2362 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 84:
-#line 406 "lwin_wkt_parse.y"
+#line 406 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2377 "lwin_wkt_parse.c"
+#line 2368 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 85:
-#line 408 "lwin_wkt_parse.y"
+#line 408 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2383 "lwin_wkt_parse.c"
+#line 2374 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 86:
-#line 410 "lwin_wkt_parse.y"
+#line 410 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2389 "lwin_wkt_parse.c"
+#line 2380 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 87:
-#line 412 "lwin_wkt_parse.y"
+#line 412 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTICURVETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2395 "lwin_wkt_parse.c"
+#line 2386 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 88:
-#line 416 "lwin_wkt_parse.y"
+#line 416 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2401 "lwin_wkt_parse.c"
+#line 2392 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 89:
-#line 418 "lwin_wkt_parse.y"
+#line 418 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2407 "lwin_wkt_parse.c"
+#line 2398 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 90:
-#line 420 "lwin_wkt_parse.y"
+#line 420 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2413 "lwin_wkt_parse.c"
+#line 2404 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 91:
-#line 422 "lwin_wkt_parse.y"
+#line 422 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2419 "lwin_wkt_parse.c"
+#line 2410 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 92:
-#line 424 "lwin_wkt_parse.y"
+#line 424 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2425 "lwin_wkt_parse.c"
+#line 2416 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 93:
-#line 426 "lwin_wkt_parse.y"
+#line 426 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2431 "lwin_wkt_parse.c"
+#line 2422 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 94:
-#line 428 "lwin_wkt_parse.y"
+#line 428 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2437 "lwin_wkt_parse.c"
+#line 2428 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 95:
-#line 430 "lwin_wkt_parse.y"
+#line 430 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2443 "lwin_wkt_parse.c"
+#line 2434 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 96:
-#line 434 "lwin_wkt_parse.y"
+#line 434 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2449 "lwin_wkt_parse.c"
+#line 2440 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 97:
-#line 436 "lwin_wkt_parse.y"
+#line 436 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2455 "lwin_wkt_parse.c"
+#line 2446 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 98:
-#line 438 "lwin_wkt_parse.y"
+#line 438 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2461 "lwin_wkt_parse.c"
+#line 2452 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 99:
-#line 440 "lwin_wkt_parse.y"
+#line 440 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTILINETYPE, NULL, NULL); WKT_ERROR(); }
-#line 2467 "lwin_wkt_parse.c"
+#line 2458 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 100:
-#line 444 "lwin_wkt_parse.y"
+#line 444 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2473 "lwin_wkt_parse.c"
+#line 2464 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 101:
-#line 446 "lwin_wkt_parse.y"
+#line 446 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2479 "lwin_wkt_parse.c"
+#line 2470 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 102:
-#line 450 "lwin_wkt_parse.y"
+#line 450 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_circularstring_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2485 "lwin_wkt_parse.c"
+#line 2476 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 103:
-#line 452 "lwin_wkt_parse.y"
+#line 452 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_circularstring_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2491 "lwin_wkt_parse.c"
+#line 2482 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 104:
-#line 454 "lwin_wkt_parse.y"
+#line 454 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_circularstring_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2497 "lwin_wkt_parse.c"
+#line 2488 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 105:
-#line 456 "lwin_wkt_parse.y"
+#line 456 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_circularstring_new(NULL, NULL); WKT_ERROR(); }
-#line 2503 "lwin_wkt_parse.c"
+#line 2494 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 106:
-#line 460 "lwin_wkt_parse.y"
+#line 460 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_linestring_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2509 "lwin_wkt_parse.c"
+#line 2500 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 107:
-#line 462 "lwin_wkt_parse.y"
+#line 462 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_linestring_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2515 "lwin_wkt_parse.c"
+#line 2506 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 108:
-#line 464 "lwin_wkt_parse.y"
+#line 464 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_linestring_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2521 "lwin_wkt_parse.c"
+#line 2512 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 109:
-#line 466 "lwin_wkt_parse.y"
+#line 466 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_linestring_new(NULL, NULL); WKT_ERROR(); }
-#line 2527 "lwin_wkt_parse.c"
+#line 2518 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 110:
-#line 470 "lwin_wkt_parse.y"
+#line 470 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2533 "lwin_wkt_parse.c"
+#line 2524 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 111:
-#line 472 "lwin_wkt_parse.y"
+#line 472 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2539 "lwin_wkt_parse.c"
+#line 2530 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 112:
-#line 476 "lwin_wkt_parse.y"
+#line 476 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2545 "lwin_wkt_parse.c"
+#line 2536 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 113:
-#line 478 "lwin_wkt_parse.y"
+#line 478 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2551 "lwin_wkt_parse.c"
+#line 2542 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 114:
-#line 482 "lwin_wkt_parse.y"
+#line 482 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_triangle_new((yyvsp[-2].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2557 "lwin_wkt_parse.c"
+#line 2548 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 115:
-#line 484 "lwin_wkt_parse.y"
+#line 484 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_triangle_new((yyvsp[-2].ptarrayvalue), (yyvsp[-5].stringvalue)); WKT_ERROR(); }
-#line 2563 "lwin_wkt_parse.c"
+#line 2554 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 116:
-#line 486 "lwin_wkt_parse.y"
+#line 486 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_triangle_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2569 "lwin_wkt_parse.c"
+#line 2560 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 117:
-#line 488 "lwin_wkt_parse.y"
+#line 488 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_triangle_new(NULL, NULL); WKT_ERROR(); }
-#line 2575 "lwin_wkt_parse.c"
+#line 2566 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 118:
-#line 492 "lwin_wkt_parse.y"
+#line 492 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2581 "lwin_wkt_parse.c"
+#line 2572 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 119:
-#line 496 "lwin_wkt_parse.y"
+#line 496 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, (yyvsp[-1].geometryvalue), NULL); WKT_ERROR(); }
-#line 2587 "lwin_wkt_parse.c"
+#line 2578 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 120:
-#line 498 "lwin_wkt_parse.y"
+#line 498 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, (yyvsp[-1].geometryvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2593 "lwin_wkt_parse.c"
+#line 2584 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 121:
-#line 500 "lwin_wkt_parse.y"
+#line 500 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2599 "lwin_wkt_parse.c"
+#line 2590 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 122:
-#line 502 "lwin_wkt_parse.y"
+#line 502 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_collection_finalize(MULTIPOINTTYPE, NULL, NULL); WKT_ERROR(); }
-#line 2605 "lwin_wkt_parse.c"
+#line 2596 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 123:
-#line 506 "lwin_wkt_parse.y"
+#line 506 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2611 "lwin_wkt_parse.c"
+#line 2602 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 124:
-#line 508 "lwin_wkt_parse.y"
+#line 508 "lwin_wkt_parse.y" /* yacc.c:1646 */
-#line 2617 "lwin_wkt_parse.c"
+#line 2608 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 125:
-#line 512 "lwin_wkt_parse.y"
+#line 512 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_point_new(wkt_parser_ptarray_new((yyvsp[0].coordinatevalue)),NULL); WKT_ERROR(); }
-#line 2623 "lwin_wkt_parse.c"
+#line 2614 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 126:
-#line 514 "lwin_wkt_parse.y"
+#line 514 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_point_new(wkt_parser_ptarray_new((yyvsp[-1].coordinatevalue)),NULL); WKT_ERROR(); }
-#line 2629 "lwin_wkt_parse.c"
+#line 2620 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 127:
-#line 516 "lwin_wkt_parse.y"
+#line 516 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_point_new(NULL, NULL); WKT_ERROR(); }
-#line 2635 "lwin_wkt_parse.c"
+#line 2626 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 128:
-#line 520 "lwin_wkt_parse.y"
+#line 520 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_point_new((yyvsp[-1].ptarrayvalue), NULL); WKT_ERROR(); }
-#line 2641 "lwin_wkt_parse.c"
+#line 2632 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 129:
-#line 522 "lwin_wkt_parse.y"
+#line 522 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_point_new((yyvsp[-1].ptarrayvalue), (yyvsp[-3].stringvalue)); WKT_ERROR(); }
-#line 2647 "lwin_wkt_parse.c"
+#line 2638 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 130:
-#line 524 "lwin_wkt_parse.y"
+#line 524 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_point_new(NULL, (yyvsp[-1].stringvalue)); WKT_ERROR(); }
-#line 2653 "lwin_wkt_parse.c"
+#line 2644 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 131:
-#line 526 "lwin_wkt_parse.y"
+#line 526 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.geometryvalue) = wkt_parser_point_new(NULL,NULL); WKT_ERROR(); }
-#line 2659 "lwin_wkt_parse.c"
+#line 2650 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 132:
-#line 530 "lwin_wkt_parse.y"
+#line 530 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.ptarrayvalue) = wkt_parser_ptarray_add_coord((yyvsp[-2].ptarrayvalue), (yyvsp[0].coordinatevalue)); WKT_ERROR(); }
-#line 2665 "lwin_wkt_parse.c"
+#line 2656 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 133:
-#line 532 "lwin_wkt_parse.y"
+#line 532 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.ptarrayvalue) = wkt_parser_ptarray_new((yyvsp[0].coordinatevalue)); WKT_ERROR(); }
-#line 2671 "lwin_wkt_parse.c"
+#line 2662 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 134:
-#line 536 "lwin_wkt_parse.y"
+#line 536 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.coordinatevalue) = wkt_parser_coord_2((yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2677 "lwin_wkt_parse.c"
+#line 2668 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 135:
-#line 538 "lwin_wkt_parse.y"
+#line 538 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.coordinatevalue) = wkt_parser_coord_3((yyvsp[-2].doublevalue), (yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2683 "lwin_wkt_parse.c"
+#line 2674 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
case 136:
-#line 540 "lwin_wkt_parse.y"
+#line 540 "lwin_wkt_parse.y" /* yacc.c:1646 */
{ (yyval.coordinatevalue) = wkt_parser_coord_4((yyvsp[-3].doublevalue), (yyvsp[-2].doublevalue), (yyvsp[-1].doublevalue), (yyvsp[0].doublevalue)); WKT_ERROR(); }
-#line 2689 "lwin_wkt_parse.c"
+#line 2680 "lwin_wkt_parse.c" /* yacc.c:1646 */
break;
-#line 2693 "lwin_wkt_parse.c"
+#line 2684 "lwin_wkt_parse.c" /* yacc.c:1646 */
default: break;
/* User semantic actions sometimes alter yychar, and that requires
@@ -2716,13 +2706,14 @@ yyreduce:
/* Now 'shift' the result of the reduction. Determine what state
that goes to, based on the state we popped back to and the rule
number reduced by. */
- const int yylhs = yyr1[yyn] - YYNTOKENS;
- const int yyi = yypgoto[yylhs] + *yyssp;
- yystate = (0 <= yyi && yyi <= YYLAST && yycheck[yyi] == *yyssp
- ? yytable[yyi]
- : yydefgoto[yylhs]);
+ yyn = yyr1[yyn];
+ yystate = yypgoto[yyn - YYNTOKENS] + *yyssp;
+ if (0 <= yystate && yystate <= YYLAST && yycheck[yystate] == *yyssp)
+ yystate = yytable[yystate];
+ else
+ yystate = yydefgoto[yyn - YYNTOKENS];
goto yynewstate;
@@ -2805,11 +2796,14 @@ yyerrlab:
| yyerrorlab -- error raised explicitly by YYERROR. |
yyerrorlab:
- /* Pacify compilers when the user code never invokes YYERROR and the
- label yyerrorlab therefore never appears in user code. */
- if (0)
- YYERROR;
+ /* Pacify compilers like GCC when the user code never invokes
+ YYERROR and the label yyerrorlab therefore never appears in user
+ code. */
+ if (/*CONSTCOND*/ 0)
+ goto yyerrorlab;
+ yyerror_range[1] = yylsp[1-yylen];
/* Do not reclaim the symbols of the rule whose action triggered
this YYERROR. */
YYPOPSTACK (yylen);
@@ -2875,7 +2869,6 @@ yyacceptlab:
yyresult = 0;
goto yyreturn;
| yyabortlab -- YYABORT comes here. |
@@ -2883,7 +2876,6 @@ yyabortlab:
yyresult = 1;
goto yyreturn;
#if !defined yyoverflow || YYERROR_VERBOSE
| yyexhaustedlab -- memory exhaustion comes here. |
@@ -2894,10 +2886,6 @@ yyexhaustedlab:
/* Fall through. */
#endif
-| yyreturn -- parsing is finished, return the result. |
yyreturn:
if (yychar != YYEMPTY)
@@ -2927,6 +2915,6 @@ yyreturn:
#endif
return yyresult;
-#line 542 "lwin_wkt_parse.y"
+#line 542 "lwin_wkt_parse.y" /* yacc.c:1906 */
diff --git a/liblwgeom/lwin_wkt_parse.h b/liblwgeom/lwin_wkt_parse.h
index 4fd6f2e..eeb89b0 100644
--- a/liblwgeom/lwin_wkt_parse.h
+++ b/liblwgeom/lwin_wkt_parse.h
@@ -1,9 +1,8 @@
/* Bison interface for Yacc-like parsers in C
- Inc.
@@ -31,9 +30,6 @@
This special exception was added by the Free Software Foundation in
version 2.2 of Bison. */
/* Debug traces. */
@@ -77,9 +73,10 @@ extern int wkt_yydebug;
/* Value type. */
union YYSTYPE
+#line 112 "lwin_wkt_parse.y" /* yacc.c:1909 */
int integervalue;
double doublevalue;
@@ -88,9 +85,9 @@ union YYSTYPE
-#line 92 "lwin_wkt_parse.h"
+#line 89 "lwin_wkt_parse.h" /* yacc.c:1909 */
diff --git a/topology/test/regress/totopogeom.sql b/topology/test/regress/totopogeom.sql
index 6f78aeec..9d93521 100644
--- a/topology/test/regress/totopogeom.sql
+++ b/topology/test/regress/totopogeom.sql
@@ -87,7 +87,7 @@ inp as ( select
::geometry as g),
tg as ( select totopogeom(g, 'tt', 5) as g from inp )
-select St_AsText(inp.g), st_astext(tg.g::geometry) from inp, tg;
+select St_AsText(inp.g), st_astext(ST_Normalize(tg.g::geometry)) from inp, tg;
-- Convert some empties
SELECT ST_AsText(toTopoGeom('POINT EMPTY', 'tt', 1)::geometry);
diff --git a/topology/test/regress/totopogeom_expected b/topology/test/regress/totopogeom_expected
index 7f222f8..bda0c3a 100644
--- a/topology/test/regress/totopogeom_expected
+++ b/topology/test/regress/totopogeom_expected
@@ -24,7 +24,7 @@ POLYGON((0 20,10 20,5 30,0 20),(2 22,8 22,5 28,2 22))|t
MULTIPOINT(0 -10,5 -10)|t
MULTILINESTRING((-1 10,-10 10),(-10 8,-2 9))|t
MULTIPOLYGON(((100 20,110 20,105 30,100 20),(102 22,108 22,105 28,102 22)),((80 20,90 20,90 60,80 20)))|t
-GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90 -90),POLYGON((-100 -80,-90 -80,-95 -70,-100 -80),(-98 -78,-92 -78,-95 -72,-98 -78)),MULTIPOINT(-100 -110,-95 -110),LINESTRING EMPTY,MULTILINESTRING((-101 -90,-110 -90),(-110 -92,-102 -91)),MULTIPOLYGON(((0 -80,10 -80,5 -70,0 -80),(2 -78,8 -78,5 -72,2 -78)),((-20 -80,-10 -80,-10 -40,-20 -80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((-100 -80,-95 -70,-90 -80,-100 -80),(-98 -78,-92 -78,-95 -72,-98 -78)),((0 -80,5 -70,10 -80,0 -80),(2 -78,8 -78,5 -72,2 -78)),((-20 -80,-10 -40,-10 -80,-20 -80))),MULTILINESTRING((-110 -92,-102 -91),(-101 -90,-110 -90),(-100 -90,-90 -90)),MULTIPOINT(-100 -110,-100 -100,-95 -110))
+GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90 -90),POLYGON((-100 -80,-90 -80,-95 -70,-100 -80),(-98 -78,-92 -78,-95 -72,-98 -78)),MULTIPOINT(-100 -110,-95 -110),LINESTRING EMPTY,MULTILINESTRING((-101 -90,-110 -90),(-110 -92,-102 -91)),MULTIPOLYGON(((0 -80,10 -80,5 -70,0 -80),(2 -78,8 -78,5 -72,2 -78)),((-20 -80,-10 -80,-10 -40,-20 -80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((0 -80,5 -70,10 -80,0 -80),(2 -78,8 -78,5 -72,2 -78)),((-20 -80,-10 -40,-10 -80,-20 -80)),((-100 -80,-95 -70,-90 -80,-100 -80),(-98 -78,-92 -78,-95 -72,-98 -78))),MULTILINESTRING((-100 -90,-90 -90),(-110 -90,-101 -90),(-110 -92,-102 -91)),MULTIPOINT(-95 -110,-100 -100,-100 -110))
MULTIPOINT EMPTY
MULTIPOINT EMPTY
MULTILINESTRING EMPTY
Summary of changes:
liblwgeom/lwin_wkt_parse.c | 934 +++++++++++++++---------------
liblwgeom/lwin_wkt_parse.h | 15 +-
topology/test/regress/totopogeom.sql | 2 +-
topology/test/regress/totopogeom_expected | 2 +-
4 files changed, 469 insertions(+), 484 deletions(-)
hooks/post-receive
