[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. a3950db3e6fbbe94cc73dbdc4925caca1f68c488
git at osgeo.org
git at osgeo.org
Sun Dec 6 21:16:24 PST 2020
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via a3950db3e6fbbe94cc73dbdc4925caca1f68c488 (commit)
from f1f62ce593df5dd6f124f939a46bef7b380022c4 (commit)
revisions in full, below.
commit a3950db3e6fbbe94cc73dbdc4925caca1f68c488
Author: Regina Obe <lr at pcorp.us>
Date: Mon Dec 7 00:16:19 2020 -0500
Steps gone thru for upgrading bessie32 from FreeBSD 12.0 to 12.2
diff --git a/freebsd/bessie32_setup.txt b/freebsd/bessie32_setup.txt
index 0b0696c..72c8a12 100644
--- a/freebsd/bessie32_setup.txt
+++ b/freebsd/bessie32_setup.txt
@@ -1,8 +1,6 @@
Bessie32-12 currently setup on winnie's virtual box - ssh port 51023
Built from: https://download.freebsd.org/ftp/releases/VM-IMAGES/12.0-RELEASE/i386/Latest/FreeBSD-12.0-RELEASE-i386.vmdk.xz(date DEC 2018)
-Built from: https://download.freebsd.org/ftp/releases/VM-IMAGES/11.1-RELEASE/i386/Latest/FreeBSD-11.1-RELEASE-i386.vmdk.xz (date July 2017)
(to do admin stuff)
#upgrade to latest patches
freebsd-update fetch
@@ -108,12 +106,6 @@ sudo gmake install
sudo gmake installcheck PGUSER=postgres
sudo cpan TAP::Parser::SourceHandler::pgTAP
-##upgrade to 12.1 (not yet done)
-sudo -i
-freebsd-update upgrade -r 12.1-RELEASE
-freebsd-update install
#reboot
shutdown -r now
@@ -128,4 +120,34 @@ shutdown -r now
#set the time
cp /usr/share/zoneinfo/EST /etc/localtime
- date 1912231036 #sets it to Mon Dec 23 10:36:00 EST 2019
\ No newline at end of file
+ date 1912231036 #sets it to Mon Dec 23 10:36:00 EST 2019
+#upgrade to 12.2
+#check version running
+sudo -i
+freebsd-version -k #kernel version # read 12.0-RELEASE-p10
+freebsd-version -u #client apps userland read 12.0-RELEASE-p10
+freebsd-update upgrade -r 12.2-RELEASE
+#after all downloaded
+ /usr/sbin/freebsd-update install
+ reboot
+ #run again after logging back in
+/usr/sbin/freebsd-update install
+freebsd-version -k #now reads 12.2-RELEASE-p1
+freebsd-version -u #now reads 12.2-RELEASE-p1
+#this failed (as detailed here - https://forums.freebsd.org/threads/pkg-update-error.74260/)
+pkg update #update available list
+#so did the suggested accepted fix
+portsnap fetch
+portsnap extract
+cd /root
+wget https://raw.githubusercontent.com/freebsd/portmaster/master/portmaster
+chmod +x portmaster
+sh portmaster pkg
+#then repeat with
+pkg update
+pkg upgrade
Summary of changes:
freebsd/bessie32_setup.txt | 40 +++++++++++++++++++++++++++++++---------
1 file changed, 31 insertions(+), 9 deletions(-)
hooks/post-receive
