[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-32-gd01a332
git at osgeo.org
git at osgeo.org
Mon Dec 7 09:32:17 PST 2020
the project "PostGIS".
via d01a3323795db5e4ffb50e2f849b74b4870722b0 (commit)
from c8dcc2f6e11986cfe6f1df7e3f0961236c1abf37 (commit)
revisions in full, below.
commit d01a3323795db5e4ffb50e2f849b74b4870722b0
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Dec 7 09:32:18 2020 -0800
Improve Doc tuning section
diff --git a/doc/database_tuning.xml b/doc/database_tuning.xml
index 9428b5d..5bb55d5 100644
--- a/doc/database_tuning.xml
+++ b/doc/database_tuning.xml
@@ -1,29 +1,30 @@
<sect1 id="database_tuning_configuration">
- <title>Tuning your configuration for performance</title>
+ <title>Performance Tuning</title>
- <para>Tuning for PostGIS is much like tuning for any PostgreSQL workload. The only additional note to keep in mind is that
- geometries and rasters are heavy so memory related optimizations generally have more of an impact on PostGIS than other types of PostgreSQL queries.</para>
+ <para>Tuning for PostGIS performance is much like tuning for any PostgreSQL workload.
+ The only additional consideration is that geometries and rasters are usually large,
+ so memory-related optimizations generally have more of an impact on PostGIS than other types of PostgreSQL queries.</para>
<para>For general details about optimizing PostgreSQL, refer to <ulink url="https://wiki.postgresql.org/wiki/Tuning_Your_PostgreSQL_Server">Tuning your PostgreSQL Server</ulink>.</para>
- <para>For PostgreSQL 9.4+ all these can be set at the server level without touching postgresql.conf or postgresql.auto.conf
- by using the <code>ALTER SYSTEM..</code> command.</para>
+ <para>For PostgreSQL 9.4+ configuration can be set at the server level without touching <code>postgresql.conf</code> or <code>postgresql.auto.conf</code>
+ by using the <code>ALTER SYSTEM</code> command.</para>
<programlisting>ALTER SYSTEM SET work_mem = '256MB';
--- this will force, non-startup configs to take effect for new connections
+-- this forces non-startup configs to take effect for new connections
SELECT pg_reload_conf();
-- show current setting value
-- use SHOW ALL to see all settings
SHOW work_mem;</programlisting>
-<para>In addition to these settings, PostGIS also has some custom settings which you can find listed in <xref linkend="PostGIS_GUC" />.</para>
+<para>In addition to the Postgres settings, PostGIS has some custom settings which are listed in <xref linkend="PostGIS_GUC" />.</para>
<sect2>
<title>Startup</title>
<para>
- These settings are configured in postgresql.conf:
+ These settings are configured in <code>postgresql.conf</code>:
</para>
<para>
@@ -89,7 +90,8 @@ SHOW work_mem;</programlisting>
<title>Runtime</title>
<para>
- <ulink url="http://www.postgresql.org/docs/current/static/runtime-config-resource.html#GUC-WORK-MEM">work_mem</ulink> (the memory used for sort operations and complex queries)
+ <ulink url="http://www.postgresql.org/docs/current/static/runtime-config-resource.html#GUC-WORK-MEM">work_mem</ulink>
+ - sets the size of memory used for sort operations and complex queries
</para>
<itemizedlist>
@@ -117,7 +119,8 @@ SHOW work_mem;</programlisting>
</itemizedlist>
<para>
- <ulink url="http://www.postgresql.org/docs/current/static/runtime-config-resource.html#GUC-MAINTENANCE-WORK-MEM">maintenance_work_mem</ulink> (used for VACUUM, CREATE INDEX, etc.)
+ <ulink url="http://www.postgresql.org/docs/current/static/runtime-config-resource.html#GUC-MAINTENANCE-WORK-MEM">maintenance_work_mem</ulink>
+ - the memory size used for VACUUM, CREATE INDEX, etc.
</para>
<itemizedlist>
@@ -174,4 +177,3 @@ SHOW work_mem;</programlisting>
</sect2>
</sect1>
Summary of changes:
doc/database_tuning.xml | 24 +++++++++++++-----------
1 file changed, 13 insertions(+), 11 deletions(-)
hooks/post-receive
