[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-44-g3d0f1ea
git at osgeo.org
git at osgeo.org
Tue Dec 8 11:34:26 PST 2020
the project "PostGIS".
via 3d0f1ea1ea0f5daaeb6a2ab9333aeab1f9f44ead (commit)
from a8534dfd6a05a507bd948d6e25f1680f36230c2a (commit)
revisions in full, below.
commit 3d0f1ea1ea0f5daaeb6a2ab9333aeab1f9f44ead
Author: Regina Obe <lr at pcorp.us>
Date: Tue Dec 8 14:34:16 2020 -0500
Do fake ids and fake outputs to fix 2.5.5 upgrade tests references #4810
diff --git a/regress/core/in_gml.sql b/regress/core/in_gml.sql
index 7b7b4bb..b33a631 100644
--- a/regress/core/in_gml.sql
+++ b/regress/core/in_gml.sql
@@ -636,10 +636,10 @@ SELECT 'srs_16', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="EPSG:-1"><gml:pos
-- Ensure upcoming tests have the SRIDs they need
INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (1, 'EPSG', 4978, 'GEOCCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric X",OTHER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric Z",NORTH],AUTHORITY["EPSG","4978"]]', '+proj=geocent +datum=WGS84 +units=m +no_defs ');
INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (2, 'EPSG', 4979, 'GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World (by country)"],BBOX[-90,-180,90,180]],ID["EPSG",4979]]', '+proj=longlat +datum=WGS84 +no_defs');
-INSERT INTO spatial_ref_sys VALUES (3, 'EPSG', 4985, 'BOUNDCRS[SOURCECRS[GEOGCRS["WGS 72",DATUM["World Geodetic System 1972",ELLIPSOID["WGS 72",6378135,298.26,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["EPSG",4985]]],TARGETCRS[GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]]],ABRIDGEDTRANSFORMATION["WGS 72 to WGS 84 (1)",VERSION[
"DMA1"],METHOD["Position Vector transformation (geog2D domain)",ID["EPSG",9606]],PARAMETER["X-axis translation",0,ID["EPSG",8605]],PARAMETER["Y-axis translation",0,ID["EPSG",8606]],PARAMETER["Z-axis translation",4.5,ID["EPSG",8607]],PARAMETER["X-axis rotation",0,ID["EPSG",8608]],PARAMETER["Y-axis rotation",0,ID["EPSG",8609]],PARAMETER["Z-axis rotation",0.554,ID["EPSG",8610]],PARAMETER["Scale difference",1.0000002263,ID["EPSG",8611]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["DERIVED_FROM(EPSG)",1237]]]', '+proj=longlat +ellps=WGS72 +towgs84=0,0,4.5,0,0,0.554,0.2263 +no_defs');
-INSERT INTO spatial_ref_sys VALUES (4, 'EPSG', 8360, 'COMPD_CS["ETRS89 + Baltic 1957 height",GEOGCS["ETRS89",DATUM["European_Terrestrial_Reference_System_1989",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6258"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AXIS["Latitude",NORTH],AXIS["Longitude",EAST],AUTHORITY["EPSG","4258"]],VERT_CS["Baltic 1957 height",VERT_DATUM["Baltic 1957",2005,AUTHORITY["EPSG","1202"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Gravity-related height",UP],AUTHORITY["EPSG","8357"]],AUTHORITY["EPSG","8360"]]', '+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +vunits=m +no_defs');
-INSERT INTO spatial_ref_sys VALUES (5, 'EPSG', 8433, 'PROJCS["Macao 1920 / Macao Grid",GEOGCS["Macao 1920",DATUM["Macao_1920",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","1207"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","8428"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",22.2123972222222],PARAMETER["central_meridian",113.536469444444],PARAMETER["scale_factor",1],PARAMETER["false_easting",20000],PARAMETER["false_northing",20000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Northing",NORTH],AXIS["Easting",EAST],AUTHORITY["EPSG","8433"]]', '+proj=tmerc +lat_0=22.2123972222222 +lon_0=113.536469444444 +k=1 +x_0=20000 +y_0=20000 +ellps=intl +units=m +no_defs');
-INSERT INTO spatial_ref_sys VALUES (6, 'EPSG', 8857, NULL, '+proj=eqearth +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs');
+INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (3, 'EPSG', 4985, 'BOUNDCRS[SOURCECRS[GEOGCRS["WGS 72",DATUM["World Geodetic System 1972",ELLIPSOID["WGS 72",6378135,298.26,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["EPSG",4985]]],TARGETCRS[GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]]],ABRIDGE
DTRANSFORMATION["WGS 72 to WGS 84 (1)",VERSION["DMA1"],METHOD["Position Vector transformation (geog2D domain)",ID["EPSG",9606]],PARAMETER["X-axis translation",0,ID["EPSG",8605]],PARAMETER["Y-axis translation",0,ID["EPSG",8606]],PARAMETER["Z-axis translation",4.5,ID["EPSG",8607]],PARAMETER["X-axis rotation",0,ID["EPSG",8608]],PARAMETER["Y-axis rotation",0,ID["EPSG",8609]],PARAMETER["Z-axis rotation",0.554,ID["EPSG",8610]],PARAMETER["Scale difference",1.0000002263,ID["EPSG",8611]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["DERIVED_FROM(EPSG)",1237]]]', '+proj=longlat +ellps=WGS72 +towgs84=0,0,4.5,0,0,0.554,0.2263 +no_defs');
+INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (4, 'EPSG', 8360, 'COMPD_CS["ETRS89 + Baltic 1957 height",GEOGCS["ETRS89",DATUM["European_Terrestrial_Reference_System_1989",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6258"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AXIS["Latitude",NORTH],AXIS["Longitude",EAST],AUTHORITY["EPSG","4258"]],VERT_CS["Baltic 1957 height",VERT_DATUM["Baltic 1957",2005,AUTHORITY["EPSG","1202"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Gravity-related height",UP],AUTHORITY["EPSG","8357"]],AUTHORITY["EPSG","8360"]]', '+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +vunits=m +no_defs');
+INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (5, 'EPSG', 8433, 'PROJCS["Macao 1920 / Macao Grid",GEOGCS["Macao 1920",DATUM["Macao_1920",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","1207"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","8428"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",22.2123972222222],PARAMETER["central_meridian",113.536469444444],PARAMETER["scale_factor",1],PARAMETER["false_easting",20000],PARAMETER["false_northing",20000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Northing",NORTH],AXIS["Easting",EAST],AUTHORITY["EPSG","8433"]]', '+proj=tmerc +lat_0=22.2123972222222 +lon_0=113.536469444444 +k=1 +x_0=20000 +y_0=20000 +ellps=intl +units=m +no_defs');
+INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (6, 'EPSG', 8857, NULL, '+proj=eqearth +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs');
-- Reverse axis with all kind of simples geometry types
SELECT 'srs_17', ST_AsEWKT(ST_GeomFromGML('<gml:MultiGeometry srsName="urn:ogc:def:crs:EPSG::4326"><gml:geometryMember><gml:Point><gml:pos srsDimension="2">1 2</gml:pos></gml:Point></gml:geometryMember><gml:geometryMember><gml:LineString><gml:posList srsDimension="2">3 4 5 6</gml:posList></gml:LineString></gml:geometryMember><gml:geometryMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="2">7 8 9 10</gml:posList></gml:LineStringSegment></gml:segments></gml:Curve></gml:geometryMember><gml:geometryMember><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">11 12 13 14 15 16 11 12</gml:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">17 18 19 20 21 22 17 18</gml:posList></gml:LinearRing></gml:interior></gml:Polygon></gml:geometryMember><gml:geometryMember><gml:Surface><gml:patches><gml:PolygonPatch><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">23 24 25 26 27 28 23 24</gml
:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">25 26 27 28 29 30 25 26</gml:posList></gml:LinearRing></gml:interior></gml:PolygonPatch></gml:patches></gml:Surface></gml:geometryMember></gml:MultiGeometry>'));
@@ -651,22 +651,22 @@ SELECT 'srs_18', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:E
SELECT 'srs_19', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::2393"><gml:pos>6000000 3500000</gml:pos></gml:Point>'));
-- Geocentric CRS with explicit geocentric AXIS (WGS 84 geocentric). No coordinate swapping
-SELECT 'srs_20', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::4978"><gml:pos srsDimension="3">1 2 3</gml:pos></gml:Point>'));
+SELECT 'srs_20', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::1"><gml:pos srsDimension="3">1 2 3</gml:pos></gml:Point>'));
-- Geographic 3D CRS with AXIS["geodetic latitude (Lat)",north,ORDER[1],...] (WGS 84 with ellipsoidal height). We must swap coordinates
-SELECT 'srs_21', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::4979"><gml:pos srsDimension="3">49 2 3</gml:pos></gml:Point>'));
+SELECT 'srs_21', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::2"><gml:pos srsDimension="3">49 2 3</gml:pos></gml:Point>'));
-- BoundCRS of a Geographic 2D CRS with AXIS["latitude",north,ORDER[1],...] (EPSG 4985: WGS 72 BE). We must swap coordinates
-SELECT 'srs_22', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::4985"><gml:pos>49 2</gml:pos></gml:Point>'));
+SELECT 'srs_22', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::3"><gml:pos>49 2</gml:pos></gml:Point>'));
-- Projected CRS with empty srtext (EPSG 8857 : WGS 84 / Equal Earth Greenwich). We assume GIS friendly order (which is the case here)
-SELECT 'srs_23', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::8857"><gml:pos>1 2</gml:pos></gml:Point>'));
+SELECT 'srs_23', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::6"><gml:pos>1 2</gml:pos></gml:Point>'));
-- CompoundCRS of a Geographic CRS (EPSG 8360 : ETRS89 + Baltic 1957 height). We must swap coordinates
-SELECT 'srs_24', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::8360"><gml:pos srsDimension="3">49 2 3</gml:pos></gml:Point>'));
+SELECT 'srs_24', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::4"><gml:pos srsDimension="3">49 2 3</gml:pos></gml:Point>'));
-- Projected CRS with AXIS["Northing",NORTH],AXIS["Easting",EAST] in its definition (EPSG 8433 : Macao 1920 / Macao Grid). We must swap coordinates
-SELECT 'srs_25', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::8433"><gml:pos>2 1</gml:pos></gml:Point>'));
+SELECT 'srs_25', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::5"><gml:pos>2 1</gml:pos></gml:Point>'));
-- Reverse axis with severals multi geometry types
-- TODO
diff --git a/regress/core/in_gml_expected b/regress/core/in_gml_expected
index ecf9ae9..4de90f2 100644
--- a/regress/core/in_gml_expected
+++ b/regress/core/in_gml_expected
@@ -217,12 +217,12 @@ ERROR: unknown spatial reference system
srs_17|SRID=4326;GEOMETRYCOLLECTION(POINT(2 1),LINESTRING(4 3,6 5),LINESTRING(8 7,10 9),POLYGON((12 11,14 13,16 15,12 11),(18 17,20 19,22 21,18 17)),POLYGON((24 23,26 25,28 27,24 23),(26 25,28 27,30 29,26 25)))
srs_18|SRID=32631;POINT(500000 0)
srs_19|SRID=2393;POINT(3500000 6000000)
-srs_20|SRID=4978;POINT(1 2 3)
-srs_21|SRID=4979;POINT(2 49 3)
-srs_22|SRID=4985;POINT(2 49)
-srs_23|SRID=8857;POINT(1 2)
-srs_24|SRID=8360;POINT(2 49 3)
-srs_25|SRID=8433;POINT(1 2)
+srs_20|SRID=1;POINT(1 2 3)
+srs_21|SRID=2;POINT(2 49 3)
+srs_22|SRID=3;POINT(2 49)
+srs_23|SRID=6;POINT(1 2)
+srs_24|SRID=4;POINT(2 49 3)
+srs_25|SRID=5;POINT(1 2)
ns_1|POINT(1 2)
ns_2|POINT(1 2)
ns_3|POINT(1 2)
Summary of changes:
regress/core/in_gml.sql | 20 ++++++++++----------
regress/core/in_gml_expected | 12 ++++++------
2 files changed, 16 insertions(+), 16 deletions(-)
hooks/post-receive
