[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-43-ga8534df
git at osgeo.org
git at osgeo.org
Tue Dec 8 10:08:21 PST 2020
the project "PostGIS".
via a8534dfd6a05a507bd948d6e25f1680f36230c2a (commit)
from b5b5c303b1fba5f146982e152b971798df443e7f (commit)
revisions in full, below.
commit a8534dfd6a05a507bd948d6e25f1680f36230c2a
Author: Martin Davis <mtnclimb at gmail.com>
Date: Tue Dec 8 10:08:14 2020 -0800
Improve Doc Building Indexes
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index b1085b8..8e6e935 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -2037,7 +2037,7 @@ WHERE
<sect3>
<title>Using the Shapefile Dumper</title>
- <para>The <filename>pgsql2shp</filename> table dumper connects directly
+ <para>The <filename>pgsql2shp</filename> table dumper connects
to the database and converts a table (possibly defined by a query) into
a shape file. The basic syntax is:</para>
@@ -2135,27 +2135,47 @@ WHERE
<title>Building Spatial Indexes</title>
<para>Indexes make using a spatial database for large data sets
- possible. Without indexing, any search for a feature would require a
+ possible. Without indexing, a search for features would require a
sequential scan of every record in the database. Indexing speeds up
- searching by organizing the data into a search tree which can be quickly
- traversed to find a particular record. PostgreSQL supports sevaral kinds of
- spatial indexes: B-Tree indexes, GiST, BRIN and SP-GiST indexes.</para>
+ searching by organizing the data into a structure which can be quickly
+ traversed to find records.
+ </para>
+ <para>The B-tree index method commonly used for attribute data
+ is not very useful for spatial data, since it only supports storing and querying
+ data in a single dimension.
+ Data such as geometry which has 2 or more dimensions)
+ requires an index method that supports range query across all the data dimensions.
+ (That said, it is possible to effectively index so-called XY data using a B-tree
+ and explict range searches.)
+ One of the main advantages of PostgreSQL for spatial data handling is that it offers several kinds of
+ indexes which work well for multi-dimensional data: GiST, BRIN and SP-GiST indexes.</para>
<itemizedlist>
<listitem>
- <para>B-Trees are used for data which can be sorted along one axis;
- for example, numbers, letters, dates. Spatial data can be sorted along
- a space-filling curve, Z-order curve or Hilbert curve.
- However, this kind of index does not allow speeding up spatial operations
- which involve comparisons of spatial extent. </para>
- </listitem>
- <listitem>
- <para>GiST (Generalized Search Trees) indexes break up data into
+ <para><emphasis role="bold">GiST (Generalized Search Tree)</emphasis> indexes break up data into
"things to one side", "things which overlap", "things which are
inside" and can be used on a wide range of data-types, including GIS
data. PostGIS uses an R-Tree index implemented on top of GiST to index
- GIS data.</para>
+ spatial data. GiST is the most commonly-used and versatile spatial index method,
+ and offers very good query performance.
+ </para>
+ </listitem>
+ <listitem>
+ <para><emphasis role="bold">BRIN (Block Range Index)</emphasis> indexes operate by summarizing
+ the spatial extent of ranges of table records.
+ Search is done via a scan of the ranges.
+ BRIN is only appropriate for use for some kinds of data
+ (spatially sorted, with infrequent or no update).
+ But it provides much faster index create time, and much smaller index size.
+ </para>
+ </listitem>
+ <listitem>
+ <para><emphasis role="bold">SP-GiST (Space-Partitioned Generalized Search Tree)</emphasis>
+ is a generic index method that supports partitioned search trees
+ such as quad-trees, k-d trees, and radix trees (tries).
+ </para>
</listitem>
</itemizedlist>
@@ -2192,74 +2212,142 @@ WHERE
</sect3>
<sect3 id="brin_indexes">
- <title>BRIN Indexes</title>
- <para>BRIN stands for "Block Range Index" and is a generic form of
- indexing that has been introduced in PostgreSQL 9.5. BRIN is a lossy kind
- of index, and its main usage is to provide a compromise for both read and
- write performance. Its primary goal is to handle very large tables for
- which some of the columns have some natural correlation with their
- physical location within the table. In addition to GIS indexing, BRIN is
- used to speed up searches on various kinds of regular or irregular data
- structures (integer, arrays etc).</para>
- <para>Once a GIS data table exceeds a few thousand rows, you will want
- to build an index to speed up spatial searches of the data (unless all
- your searches are based on attributes, in which case you'll want to
- build a normal index on the attribute fields). GiST indexes are really
- performant as long as their size doesn't exceed the amount of RAM
- available for the database, and as long as you can afford the storage
- size, and the penalty in write workload. Otherwise, BRIN index can be
- considered as an alternative. </para>
- <para>The idea of a BRIN index is to store only the bounding box enclosing
- all the geometries contained in all the rows in a set of table blocks,
- called a range. Obviously, this indexing method will only be efficient
- if the data is physically ordered in a way where the resulting bounding
- boxes for block ranges will be mutually exclusive. The resulting index
- will be really small, but will be less efficient than a GiST index in
- many cases.</para>
- <para>Building a BRIN index is way less intensive than building a GiST
- index. It's quite common to build a BRIN index ten times faster
- than a GiST index would have required. As a BRIN index only stores one
- bounding box for one to many table blocks, it's pretty common to consume
- up to a thousand times less disk space for this kind of index.</para>
- <para>You can choose the number of blocks to summarize in a range. If you
- decrease this number, the index will be bigger but will probably help to
- get better performance.</para>
- <para>The syntax for building a BRIN index on a "geometry" column is as
- follows:</para>
+ <title>BRIN Indexes</title>
+ <para>BRIN stands for "Block Range Index". It is an general-purpose
+ <ulink url="https://www.postgresql.org/docs/current/brin.html">index method</ulink> introduced in PostgreSQL 9.5.
+ BRIN is a <emphasis>lossy</emphasis>
+ index method, meaning that a a secondary check is required to confirm
+ that a record matches a given search condition
+ (which is the case for all provided spatial indexes).
+ It provides much faster index creation and much smaller index size,
+ with reasonable read performance.
+ Its primary purpose is to support indexing very large tables
+ on columns which have a correlation with their
+ physical location within the table. In addition to spatial indexing,
+ BRIN can speed up searches on various kinds of attribute data
+ structures (integer, arrays etc).</para>
+ <para>Once a spatial table exceeds a few thousand rows, you will want
+ to build an index to speed up spatial searches of the data.
+ GiST indexes are very performant as long as their size doesn't exceed the amount of RAM
+ available for the database, and as long as you can afford the index storage
+ size, and the cost of index update on write. Otherwise, for very large tables BRIN index can be
+ considered as an alternative.</para>
+ <para>A BRIN index stores the bounding box enclosing
+ all the geometries contained in the rows in a contiguous set of table blocks,
+ called a <emphasis>block range</emphasis>.
+ When executing a query using the index the block ranges are scanned to
+ find the ones that intersect the query extent.
+ This is efficient only if the data is physically ordered so that the bounding
+ boxes for block ranges have minimal overlap (and ideally are mutually exclusive).
+ The resulting index is very small in size,
+ but is typically less performant for read than a GiST index over the same data.</para>
+ <para>Building a BRIN index is much less CPU-intensive than building a GiST index.
+ It's common to find that a BRIN index is ten times faster to build
+ than a GiST index over the same data. And because a BRIN index stores only one
+ bounding box for each range of table blocks, it's common to use
+ up to a thousand times less disk space than a GiST index.</para>
+ <para>You can choose the number of blocks to summarize in a range. If you
+ decrease this number, the index will be bigger but will probably provide
+ better performance.</para>
+ <para>For BRIN to be effective, the table data should be stored in
+ a physical order which minimizes the amount of block extent overlap.
+ It may be that the data is already sorted appropriately
+ (for instance, if it is loaded from another dataset that is already sorted in spatial order).
+ Otherwise, this can be accomplished by sorting the data by a one-dimensional spatial key.
+ One way to do this is to create a new table sorted by the geometry values
+ (which in recent PostGIS versions uses an efficient Hilbert curve ordering):
+ </para>
+ <para><programlisting>
+CREATE TABLE table_sorted AS
+ SELECT * FROM table ORDER BY geom;
+</programlisting></para>
+ <para>Alternatively, data can be sorted in-place by using a GeoHash as a (temporary) index,
+ and clustering on that index:
+ </para>
+CREATE INDEX idx_temp_geohash ON table
+ USING btree (ST_GeoHash( ST_Transform( geom, 4326 ), 20));
+CLUSTER table USING idx_temp_geohash;
+ <para>The syntax for building a BRIN index on a <code>geometry</code> column is:</para>
+ <para><programlisting>CREATE INDEX [indexname] ON [tablename] USING BRIN ( [geome_col] ); </programlisting></para>
+ <para>The above syntax builds a 2D index. To build a 3D-dimensional index, use this syntax:</para>
+ <programlisting>
+CREATE INDEX [indexname] ON [tablename]
+ USING BRIN ([geome_col] brin_geometry_inclusion_ops_3d);</programlisting>
+ <para>You can also get a 4D-dimensional index using the 4D operator class:</para>
+ <programlisting>
+ USING BRIN ([geome_col] brin_geometry_inclusion_ops_4d);</programlisting>
+ <para>The above commands use the default number of blocks in a range, which is 128.
+ To specify the number of blocks to summarise in a range, use this syntax</para>
+ USING BRIN ( [geome_col] ) WITH (pages_per_range = [number]); </programlisting></para>
+ <para>Keep in mind that a BRIN index only stores one index
+ entry for a large number of rows. If your table stores geometries with
+ a mixed number of dimensions, it's likely that the resulting index will
+ have poor performance. You can avoid this performance penalty by
+ choosing the operator class with the least number of dimensions of the
+ stored geometries
+ </para>
+ <para>The <code>geography</code> datatype is supported for BRIN indexing. The
+ syntax for building a BRIN index on a geography column is:</para>
+ <para><programlisting>CREATE INDEX [indexname] ON [tablename] USING BRIN ( [geog_col] ); </programlisting></para>
+ <para>The above syntax builds a 2D-index for geospatial objects on the spheroid. </para>
+ <para>Currently, only "inclusion support" is provided, meaning
+ that just the <varname>&&</varname>, <varname>~</varname> and
+ <varname>@</varname> operators can be used for the 2D cases (for both
+ <code>geometry</code> and <code>geography</code>), and just the <varname>&&&</varname>
+ operator for 3D geometries.
+ There is currently no support for kNN searches.</para>
+ <para>An important difference between BRIN and other index types is that the database does not
+ maintain the index dynamically. Changes to spatial data in the table
+ are simply appended to the end of the index. This will cause index search performance to
+ degrade over time. The index can be updated by performing a <code>VACUUM</code>,
+ or by using a special function <code>brin_summarize_new_values(regclass)</code>.
+ For this reason BRIN may be most appropriate for use with data that is read-only,
+ or only rarely changing. For more information refer to the
+ <ulink url="https://www.postgresql.org/docs/current/brin-intro.html#BRIN-OPERATION">manual</ulink>.
+ </para>
+ <para>To summarize using BRIN for spatial data:
+ </para>
+ <itemizedlist>
+ <listitem><para>Index build time is very fast, and index size is very small.</para></listitem>
+ <listitem><para>Index query time is slower than GiST, but can still be very acceptable.</para></listitem>
+ <listitem><para>Requires table data to be sorted in a spatial ordering.</para></listitem>
+ <listitem><para>Requires manual index maintenance.</para></listitem>
+ <listitem><para>Most appropriate for very large tables,
+ with low or no overlap (e.g. points),
+ and which are static or change infrequently.</para></listitem>
+ </itemizedlist>
- <para><programlisting>CREATE INDEX [indexname] ON [tablename] USING BRIN ( [geometryfield] ); </programlisting></para>
- <para>The above syntax will always build a 2D-index. To get a 3D-dimensional index, you can create one using this syntax</para>
- <programlisting>CREATE INDEX [indexname] ON [tablename] USING BRIN ([geometryfield] brin_geometry_inclusion_ops_3d);</programlisting>
- <para>You can also get a 4D-dimensional index using the 4D operator class</para>
- <programlisting>CREATE INDEX [indexname] ON [tablename] USING BRIN ([geometryfield] brin_geometry_inclusion_ops_4d);</programlisting>
- <para>These above syntaxes will use the default number or block in a range, which is 128. To specify the number of blocks you want to summarise in a range, you can create one using this syntax</para>
- <para><programlisting>CREATE INDEX [indexname] ON [tablename] USING BRIN ( [geometryfield] ) WITH (pages_per_range = [number]); </programlisting></para>
- <para>Also, keep in mind that a BRIN index will only store one index
- value for a large number of rows. If your table stores geometries with
- a mixed number of dimensions, it's likely that the resulting index will
- have poor performance. You can avoid this drop of performance by
- choosing the operator class whith the least number of dimensions of the
- stored geometries
- </para>
- <para>Also the "geography" datatype is supported for BRIN indexing. The
- syntax for building a BRIN index on a "geography" column is as follows:</para>
- <para><programlisting>CREATE INDEX [indexname] ON [tablename] USING BRIN ( [geographyfield] ); </programlisting></para>
- <para>The above syntax will always build a 2D-index for geospatial objects on the spheroid. </para>
- <para>Currently, just the "inclusion support" is considered here, meaning
- that just <varname>&&</varname>, <varname>~</varname> and
- <varname>@</varname> operators can be used for the 2D cases (both for
- "geometry" and for "geography"), and just the <varname>&&&</varname>
- operator can be used for the 3D geometries. There is no support
- for kNN searches at the moment.</para>
</sect3>
<sect3 id="spgist_indexes">
@@ -2274,7 +2362,7 @@ WHERE
routing, ip routing, substring search, etc. </para>
<para>As it is the case for GiST indexes, SP-GiST indexes are lossy, in the
- sense that they store the bounding box englobing the spatial objects.
+ sense that they store the bounding box enclosing spatial objects.
SP-GiST indexes can be considered as an alternative to GiST indexes. The
performance tests reveal that SP-GiST indexes are especially beneficial
when there are many overlapping objects, that is, with so-called
Summary of changes:
doc/using_postgis_dataman.xml | 254 ++++++++++++++++++++++++++++--------------
1 file changed, 171 insertions(+), 83 deletions(-)
hooks/post-receive
