[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-42-gb5b5c30
git at osgeo.org
git at osgeo.org
Tue Dec 8 09:55:03 PST 2020
the project "PostGIS".
via b5b5c303b1fba5f146982e152b971798df443e7f (commit)
from 816d70dd6d1d261a5668c8c7563ba5e2251e7b8e (commit)
revisions in full, below.
commit b5b5c303b1fba5f146982e152b971798df443e7f
Author: Regina Obe <lr at pcorp.us>
Date: Tue Dec 8 12:54:55 2020 -0500
Try to fix dronie upgrade issue. References #4810
diff --git a/regress/core/in_gml.sql b/regress/core/in_gml.sql
index 49c1c3f..7b7b4bb 100644
--- a/regress/core/in_gml.sql
+++ b/regress/core/in_gml.sql
@@ -634,18 +634,12 @@ SELECT 'srs_15', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName=""><gml:pos>1 2</g
SELECT 'srs_16', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="EPSG:-1"><gml:pos>1 2</gml:pos></gml:Point>'));
-- Ensure upcoming tests have the SRIDs they need
-INSERT INTO spatial_ref_sys VALUES (4978, 'EPSG', 4978, 'GEOCCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric X",OTHER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric Z",NORTH],AUTHORITY["EPSG","4978"]]', '+proj=geocent +datum=WGS84 +units=m +no_defs ')
- ON CONFLICT DO NOTHING;
-INSERT INTO spatial_ref_sys VALUES (4979, 'EPSG', 4979, 'GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World (by country)"],BBOX[-90,-180,90,180]],ID["EPSG",4979]]', '+proj=longlat +datum=WGS84 +no_defs')
-INSERT INTO spatial_ref_sys VALUES (4985, 'EPSG', 4985, 'BOUNDCRS[SOURCECRS[GEOGCRS["WGS 72",DATUM["World Geodetic System 1972",ELLIPSOID["WGS 72",6378135,298.26,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["EPSG",4985]]],TARGETCRS[GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]]],ABRIDGEDTRANSFORMATION["WGS 72 to WGS 84 (1)",VERSI
ON["DMA1"],METHOD["Position Vector transformation (geog2D domain)",ID["EPSG",9606]],PARAMETER["X-axis translation",0,ID["EPSG",8605]],PARAMETER["Y-axis translation",0,ID["EPSG",8606]],PARAMETER["Z-axis translation",4.5,ID["EPSG",8607]],PARAMETER["X-axis rotation",0,ID["EPSG",8608]],PARAMETER["Y-axis rotation",0,ID["EPSG",8609]],PARAMETER["Z-axis rotation",0.554,ID["EPSG",8610]],PARAMETER["Scale difference",1.0000002263,ID["EPSG",8611]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["DERIVED_FROM(EPSG)",1237]]]', '+proj=longlat +ellps=WGS72 +towgs84=0,0,4.5,0,0,0.554,0.2263 +no_defs')
-INSERT INTO spatial_ref_sys VALUES (8360, 'EPSG', 8360, 'COMPD_CS["ETRS89 + Baltic 1957 height",GEOGCS["ETRS89",DATUM["European_Terrestrial_Reference_System_1989",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6258"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AXIS["Latitude",NORTH],AXIS["Longitude",EAST],AUTHORITY["EPSG","4258"]],VERT_CS["Baltic 1957 height",VERT_DATUM["Baltic 1957",2005,AUTHORITY["EPSG","1202"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Gravity-related height",UP],AUTHORITY["EPSG","8357"]],AUTHORITY["EPSG","8360"]]', '+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +vunits=m +no_defs')
-INSERT INTO spatial_ref_sys VALUES (8433, 'EPSG', 8433, 'PROJCS["Macao 1920 / Macao Grid",GEOGCS["Macao 1920",DATUM["Macao_1920",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","1207"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","8428"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",22.2123972222222],PARAMETER["central_meridian",113.536469444444],PARAMETER["scale_factor",1],PARAMETER["false_easting",20000],PARAMETER["false_northing",20000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Northing",NORTH],AXIS["Easting",EAST],AUTHORITY["EPSG","8433"]]', '+proj=tmerc +lat_0=22.2123972222222 +lon_0=113.536469444444 +k=1 +x_0=20000 +y_0=20000 +ellps=intl +units=m +no_defs')
-INSERT INTO spatial_ref_sys VALUES (8857, 'EPSG', 8857, NULL, '+proj=eqearth +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs')
+INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (1, 'EPSG', 4978, 'GEOCCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Geocentric X",OTHER],AXIS["Geocentric Y",OTHER],AXIS["Geocentric Z",NORTH],AUTHORITY["EPSG","4978"]]', '+proj=geocent +datum=WGS84 +units=m +no_defs ');
+INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (2, 'EPSG', 4979, 'GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World (by country)"],BBOX[-90,-180,90,180]],ID["EPSG",4979]]', '+proj=longlat +datum=WGS84 +no_defs');
+INSERT INTO spatial_ref_sys VALUES (3, 'EPSG', 4985, 'BOUNDCRS[SOURCECRS[GEOGCRS["WGS 72",DATUM["World Geodetic System 1972",ELLIPSOID["WGS 72",6378135,298.26,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,3],AXIS["geodetic latitude (Lat)",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["geodetic longitude (Lon)",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],AXIS["ellipsoidal height (h)",up,ORDER[3],LENGTHUNIT["metre",1]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["EPSG",4985]]],TARGETCRS[GEOGCRS["WGS 84",DATUM["World Geodetic System 1984",ELLIPSOID["WGS 84",6378137,298.257223563,LENGTHUNIT["metre",1]]],PRIMEM["Greenwich",0,ANGLEUNIT["degree",0.0174532925199433]],CS[ellipsoidal,2],AXIS["latitude",north,ORDER[1],ANGLEUNIT["degree",0.0174532925199433]],AXIS["longitude",east,ORDER[2],ANGLEUNIT["degree",0.0174532925199433]],ID["EPSG",4326]]],ABRIDGEDTRANSFORMATION["WGS 72 to WGS 84 (1)",VERSION[
"DMA1"],METHOD["Position Vector transformation (geog2D domain)",ID["EPSG",9606]],PARAMETER["X-axis translation",0,ID["EPSG",8605]],PARAMETER["Y-axis translation",0,ID["EPSG",8606]],PARAMETER["Z-axis translation",4.5,ID["EPSG",8607]],PARAMETER["X-axis rotation",0,ID["EPSG",8608]],PARAMETER["Y-axis rotation",0,ID["EPSG",8609]],PARAMETER["Z-axis rotation",0.554,ID["EPSG",8610]],PARAMETER["Scale difference",1.0000002263,ID["EPSG",8611]],USAGE[SCOPE["unknown"],AREA["World"],BBOX[-90,-180,90,180]],ID["DERIVED_FROM(EPSG)",1237]]]', '+proj=longlat +ellps=WGS72 +towgs84=0,0,4.5,0,0,0.554,0.2263 +no_defs');
+INSERT INTO spatial_ref_sys VALUES (4, 'EPSG', 8360, 'COMPD_CS["ETRS89 + Baltic 1957 height",GEOGCS["ETRS89",DATUM["European_Terrestrial_Reference_System_1989",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6258"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AXIS["Latitude",NORTH],AXIS["Longitude",EAST],AUTHORITY["EPSG","4258"]],VERT_CS["Baltic 1957 height",VERT_DATUM["Baltic 1957",2005,AUTHORITY["EPSG","1202"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Gravity-related height",UP],AUTHORITY["EPSG","8357"]],AUTHORITY["EPSG","8360"]]', '+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +vunits=m +no_defs');
+INSERT INTO spatial_ref_sys VALUES (5, 'EPSG', 8433, 'PROJCS["Macao 1920 / Macao Grid",GEOGCS["Macao 1920",DATUM["Macao_1920",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","1207"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","8428"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",22.2123972222222],PARAMETER["central_meridian",113.536469444444],PARAMETER["scale_factor",1],PARAMETER["false_easting",20000],PARAMETER["false_northing",20000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Northing",NORTH],AXIS["Easting",EAST],AUTHORITY["EPSG","8433"]]', '+proj=tmerc +lat_0=22.2123972222222 +lon_0=113.536469444444 +k=1 +x_0=20000 +y_0=20000 +ellps=intl +units=m +no_defs');
+INSERT INTO spatial_ref_sys VALUES (6, 'EPSG', 8857, NULL, '+proj=eqearth +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs');
-- Reverse axis with all kind of simples geometry types
SELECT 'srs_17', ST_AsEWKT(ST_GeomFromGML('<gml:MultiGeometry srsName="urn:ogc:def:crs:EPSG::4326"><gml:geometryMember><gml:Point><gml:pos srsDimension="2">1 2</gml:pos></gml:Point></gml:geometryMember><gml:geometryMember><gml:LineString><gml:posList srsDimension="2">3 4 5 6</gml:posList></gml:LineString></gml:geometryMember><gml:geometryMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="2">7 8 9 10</gml:posList></gml:LineStringSegment></gml:segments></gml:Curve></gml:geometryMember><gml:geometryMember><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">11 12 13 14 15 16 11 12</gml:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">17 18 19 20 21 22 17 18</gml:posList></gml:LinearRing></gml:interior></gml:Polygon></gml:geometryMember><gml:geometryMember><gml:Surface><gml:patches><gml:PolygonPatch><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">23 24 25 26 27 28 23 24</gml
:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">25 26 27 28 29 30 25 26</gml:posList></gml:LinearRing></gml:interior></gml:PolygonPatch></gml:patches></gml:Surface></gml:geometryMember></gml:MultiGeometry>'));
@@ -1293,3 +1287,5 @@ SELECT 'double_31', ST_AsEWKT(ST_GeomFromGML('<gml:Point><gml:pos>1 $0%@#$^%#</g
-- #4652
SELECT '#4652', ST_AsEWKT(ST_GeomFromGML('<gml:Curve id="id-69b216c9-2c07-434d-8664-e321b3697725-0" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:28992"> <gml:segments> <gml:LineStringSegment> <gml:posList>119675.91899999976 526436.1209999993 119676.54699999839 526439.4930000007 119676.44299999997 526439.5130000003 119676.03299999982 526439.6220000014 119675.38500000164 526439.868999999</gml:posList> </gml:LineStringSegment> <gml:LineStringSegment> <gml:posList>119675.38500000164 526439.868999999 119675.15500452081 526439.9735735222 119674.92922525379 526440.0869634049 119674.70800000057 526440.2089999989</gml:posList> </gml:LineStringSegment> <gml:LineStringSegment> <gml:posList>119674.70800000057 526440.2089999989 119674.01347910661 526440.6575801083 119673.38748824484 526441.1976901226</gml:posList> </gml:LineStringSegment> </gml:segments> </gml:Curve>',28992));
+DELETE FROM spatial_ref_sys WHERE srid BETWEEN 1 and 6;
Summary of changes:
regress/core/in_gml.sql | 20 ++++++++------------
1 file changed, 8 insertions(+), 12 deletions(-)
hooks/post-receive
