[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-47-g2a09c02
git at osgeo.org
git at osgeo.org
Tue Dec 8 13:14:41 PST 2020
the project "PostGIS".
via 2a09c0294a9790997c381bd2d38697f62757246a (commit)
via f7ab9d6ca42c05bcd3ca36bded6abcaaceffb0b8 (commit)
from ffca75a77c4c0451e7a451ddff6841eb49ce2c00 (commit)
revisions in full, below.
commit 2a09c0294a9790997c381bd2d38697f62757246a
Merge: f7ab9d6 ffca75a
Author: Regina Obe <lr at pcorp.us>
Date: Tue Dec 8 16:14:32 2020 -0500
Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit f7ab9d6ca42c05bcd3ca36bded6abcaaceffb0b8
Date: Tue Dec 8 16:04:42 2020 -0500
Do fake srid for EPSG:2393 to fix 2.1.9 upgrade tests references #4810
diff --git a/regress/core/in_gml.sql b/regress/core/in_gml.sql
index b33a631..4206c94 100644
--- a/regress/core/in_gml.sql
+++ b/regress/core/in_gml.sql
@@ -641,6 +641,9 @@ INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUE
INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (5, 'EPSG', 8433, 'PROJCS["Macao 1920 / Macao Grid",GEOGCS["Macao 1920",DATUM["Macao_1920",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","1207"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","8428"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",22.2123972222222],PARAMETER["central_meridian",113.536469444444],PARAMETER["scale_factor",1],PARAMETER["false_easting",20000],PARAMETER["false_northing",20000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Northing",NORTH],AXIS["Easting",EAST],AUTHORITY["EPSG","8433"]]', '+proj=tmerc +lat_0=22.2123972222222 +lon_0=113.536469444444 +k=1 +x_0=20000 +y_0=20000 +ellps=intl +units=m +no_defs');
INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (6, 'EPSG', 8857, NULL, '+proj=eqearth +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs');
+INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (7, 'EPSG', 2393, NULL, '+proj=tmerc +lat_0=0 +lon_0=27 +k=1 +x_0=3500000 +y_0=0 +ellps=intl +towgs84=-96.062,-82.428,-121.753,4.801,0.345,-1.376,1.496 +units=m +no_defs');
-- Reverse axis with all kind of simples geometry types
SELECT 'srs_17', ST_AsEWKT(ST_GeomFromGML('<gml:MultiGeometry srsName="urn:ogc:def:crs:EPSG::4326"><gml:geometryMember><gml:Point><gml:pos srsDimension="2">1 2</gml:pos></gml:Point></gml:geometryMember><gml:geometryMember><gml:LineString><gml:posList srsDimension="2">3 4 5 6</gml:posList></gml:LineString></gml:geometryMember><gml:geometryMember><gml:Curve><gml:segments><gml:LineStringSegment><gml:posList srsDimension="2">7 8 9 10</gml:posList></gml:LineStringSegment></gml:segments></gml:Curve></gml:geometryMember><gml:geometryMember><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">11 12 13 14 15 16 11 12</gml:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">17 18 19 20 21 22 17 18</gml:posList></gml:LinearRing></gml:interior></gml:Polygon></gml:geometryMember><gml:geometryMember><gml:Surface><gml:patches><gml:PolygonPatch><gml:exterior><gml:LinearRing><gml:posList srsDimension="2">23 24 25 26 27 28 23 24</gml
:posList></gml:LinearRing></gml:exterior><gml:interior><gml:LinearRing><gml:posList srsDimension="2">25 26 27 28 29 30 25 26</gml:posList></gml:LinearRing></gml:interior></gml:PolygonPatch></gml:patches></gml:Surface></gml:geometryMember></gml:MultiGeometry>'));
@@ -648,7 +651,7 @@ SELECT 'srs_17', ST_AsEWKT(ST_GeomFromGML('<gml:MultiGeometry srsName="urn:ogc:d
SELECT 'srs_18', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::32631"><gml:pos>500000 0</gml:pos></gml:Point>'));
-- Projected CRS with northing, easting axis order, but with no explicit AXIS (EPSG 2393: KKJ / Finland Uniform Coordinate System). We must swap the coordinates
-SELECT 'srs_19', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::2393"><gml:pos>6000000 3500000</gml:pos></gml:Point>'));
+SELECT 'srs_19', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::7"><gml:pos>6000000 3500000</gml:pos></gml:Point>'));
-- Geocentric CRS with explicit geocentric AXIS (WGS 84 geocentric). No coordinate swapping
SELECT 'srs_20', ST_AsEWKT(ST_GeomFromGML('<gml:Point srsName="urn:ogc:def:crs:EPSG::1"><gml:pos srsDimension="3">1 2 3</gml:pos></gml:Point>'));
diff --git a/regress/core/in_gml_expected b/regress/core/in_gml_expected
index 4de90f2..02f6481 100644
--- a/regress/core/in_gml_expected
+++ b/regress/core/in_gml_expected
@@ -216,7 +216,7 @@ ERROR: unknown spatial reference system
srs_17|SRID=4326;GEOMETRYCOLLECTION(POINT(2 1),LINESTRING(4 3,6 5),LINESTRING(8 7,10 9),POLYGON((12 11,14 13,16 15,12 11),(18 17,20 19,22 21,18 17)),POLYGON((24 23,26 25,28 27,24 23),(26 25,28 27,30 29,26 25)))
srs_18|SRID=32631;POINT(500000 0)
-srs_19|SRID=2393;POINT(3500000 6000000)
+srs_19|SRID=7;POINT(3500000 6000000)
srs_20|SRID=1;POINT(1 2 3)
srs_21|SRID=2;POINT(2 49 3)
srs_22|SRID=3;POINT(2 49)
Summary of changes:
regress/core/in_gml.sql | 5 ++++-
regress/core/in_gml_expected | 2 +-
2 files changed, 5 insertions(+), 2 deletions(-)
hooks/post-receive
