[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-48-g9b6e054
Tue Dec 8 13:24:45 PST 2020
the project "PostGIS".
       via  9b6e05405a8240091012fe9318c6090c0292e562 (commit)
      from  2a09c0294a9790997c381bd2d38697f62757246a (commit)
revisions in full, below.
commit 9b6e05405a8240091012fe9318c6090c0292e562
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Dec 8 16:24:40 2020 -0500
    include srtext for srid for EPSG:2393 and put in logic to delete  to fix 2.1.9 upgrade tests references #4810
diff --git a/regress/core/in_gml.sql b/regress/core/in_gml.sql
index 4206c94..534e79e 100644
--- a/regress/core/in_gml.sql
+++ b/regress/core/in_gml.sql
@@ -641,7 +641,7 @@ INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUE
 INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (5, 'EPSG', 8433, 'PROJCS["Macao 1920 / Macao Grid",GEOGCS["Macao 1920",DATUM["Macao_1920",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","1207"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","8428"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",22.2123972222222],PARAMETER["central_meridian",113.536469444444],PARAMETER["scale_factor",1],PARAMETER["false_easting",20000],PARAMETER["false_northing",20000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Northing",NORTH],AXIS["Easting",EAST],AUTHORITY["EPSG","8433"]]', '+proj=tmerc +lat_0=22.2123972222222 +lon_0=113.536469444444 +k=1 +x_0=20000 +y_0=20000 +ellps=intl +units=m +no_defs');
 INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (6, 'EPSG', 8857, NULL, '+proj=eqearth +lon_0=0 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs');
-INSERT INTO spatial_ref_sys(srid, auth_name, auth_srid, srtext, proj4text) VALUES (7, 'EPSG', 2393, NULL, '+proj=tmerc +lat_0=0 +lon_0=27 +k=1 +x_0=3500000 +y_0=0 +ellps=intl +towgs84=-96.062,-82.428,-121.753,4.801,0.345,-1.376,1.496 +units=m +no_defs');
+INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (7,'EPSG',2393,'PROJCS["KKJ / Finland Uniform Coordinate System",GEOGCS["KKJ",DATUM["Kartastokoordinaattijarjestelma_1966",SPHEROID["International 1924",6378388,297,AUTHORITY["EPSG","7022"]],TOWGS84[-96.062,-82.428,-121.753,4.801,0.345,-1.376,1.496],AUTHORITY["EPSG","6123"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4123"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",27],PARAMETER["scale_factor",1],PARAMETER["false_easting",3500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","2393"]]','+proj=tmerc +lat_0=0 +lon_0=27 +k=1 +x_0=3500000 +y_0=0 +ellps=intl +towgs84=-96.062,-82.428,-121.753,4.801,0.345,-1.376,1.496 +units=m +no_defs ');
 -- Reverse axis with all kind of simples geometry types
@@ -1291,4 +1291,4 @@ SELECT 'double_31', ST_AsEWKT(ST_GeomFromGML('<gml:Point><gml:pos>1 $0%@#$^%#</g
 -- #4652
 SELECT '#4652', ST_AsEWKT(ST_GeomFromGML('<gml:Curve id="id-69b216c9-2c07-434d-8664-e321b3697725-0" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:28992"> <gml:segments> <gml:LineStringSegment> <gml:posList>119675.91899999976 526436.1209999993 119676.54699999839 526439.4930000007 119676.44299999997 526439.5130000003 119676.03299999982 526439.6220000014 119675.38500000164 526439.868999999</gml:posList> </gml:LineStringSegment> <gml:LineStringSegment> <gml:posList>119675.38500000164 526439.868999999 119675.15500452081 526439.9735735222 119674.92922525379 526440.0869634049 119674.70800000057 526440.2089999989</gml:posList> </gml:LineStringSegment> <gml:LineStringSegment> <gml:posList>119674.70800000057 526440.2089999989 119674.01347910661 526440.6575801083 119673.38748824484 526441.1976901226</gml:posList> </gml:LineStringSegment> </gml:segments> </gml:Curve>',28992));
-DELETE FROM spatial_ref_sys WHERE srid BETWEEN 1 and 6;
+DELETE FROM spatial_ref_sys WHERE srid BETWEEN 1 and 7;
Summary of changes:
 regress/core/in_gml.sql | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
