[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0beta1
Wed Dec 9 16:03:31 PST 2020
the project "PostGIS".
       via  721a0b732c6c96a23e9703d195aadae95760098c (commit)
      from  9b6e05405a8240091012fe9318c6090c0292e562 (commit)
revisions in full, below.
commit 721a0b732c6c96a23e9703d195aadae95760098c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Dec 9 16:02:28 2020 -0800
    Prepare for 3.1.0beta1
diff --git a/NEWS b/NEWS
index 299d6af..296d92b 100644
--- a/NEWS
+++ b/NEWS
@@ -1,6 +1,6 @@
-PostGIS 3.1.0alpha4
-2020/xx/xx
-Only tickets not included in 3.1.0alpha3
+PostGIS 3.1.0beta1
+2020/12/09
+Only tickets not included in 3.1.0beta1
  * Breaking changes *
   - #4214, Deprecated ST_Count(tablename,...), ST_ApproxCount(tablename, ...)
diff --git a/README.postgis b/README.postgis
index 5a461be..3afabd2 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.1.0alpha3
-:Date: 2020-11-19
+:Version: 3.1.beta1
+:Date: 2020-12-09
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index e618043..9aa2af0 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=1
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0beta1
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 3f47950..5119737 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,11 +2,49 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
-    <sect1><title>Release 3.1.0alpha3</title>
+    <sect1>
+        <title>Release 3.1.0beta1</title>
+        <para>Release date: 2020/12/09</para>
+        <para>Only changes since 3.1.0alpha2 are listed.
+            This version requires PostgreSQL 9.6-13 and GEOS >= 3.6+
+            Additional features and enhancements enabled if you are
+            running Proj6+, PostgreSQL 12+, and GEOS 3.9.0dev</para>
+        <simplesect>
+            <title>Breaking changes</title>
+            <para>4214, Deprecated ST_Count(tablename,...),
+                ST_ApproxCount(tablename, ...)
+                ST_SummaryStats(tablename, ..),
+                ST_Histogram(tablename, ...), ST_ApproxHistogram(tablename, ...),
+                ST_Quantile(tablename, ...),
+                ST_ApproxQuantile(tablename, ...) removed.
+                (Darafei Praliaskouski)</para>
+        </simplesect>
+        <simplesect>
+            <title>Enhancements</title>
+            <para>4801, ST_ClusterKMeans supports weights in POINT[Z]M
+                geometries (Darafei Praliaskouski)</para>
+            <para>4804, ST_ReducePrecision (GEOS 3.9+) allows
+                valid precision reduction (Paul Ramsey)</para>
+            <para>4805, _ST_SortableHash exposed to work around
+                parallel soring performance issue in Postgres.
+                If your table is huge, use ORDER BY _ST_SortableHash(geom)
+                instead of ORDER BY geom to make parallel sort faster
+            <para>4625, Correlation statistics now calculated.
+                Run ANALYZE for BRIN indexes to start kicking in.
+            <para>Fix axis order issue with urn:ogc:def:crs:EPSG
+                in ST_GeomFromGML() (Even Roualt)</para>
+        </simplesect>
+    </sect1>
+    <sect1>
+        <title>Release 3.1.0alpha3</title>
         <para>Release date: 2020/11/19</para>
         <para>Only changes since 3.1.0alpah2 are listed. This version requires PostgreSQL 9.6-13 and GEOS >= 3.6+
                 Additional features and enhancements enabled if you are running Proj6+, PostgreSQL 12+, and GEOS 3.9.0dev</para>
-        <simplesect><title>Breaking changes</title>
+        <simplesect>
             <para>4737, Bump minimum protobuf-c requirement to 1.1.0 (Raúl Marín)
                     The configure step will now fail if the requirement isn't
                     met or explicitly disabled (--without-protobuf)</para>
@@ -14,14 +52,16 @@
                     into its own lib file (Regina Obe)</para>
         </simplesect>
-        <simplesect><title>New features</title>
+        <simplesect>
+            <title>New features</title>
             <para>4698, Add a precision parameter to ST_AsEWKT (Raúl Marín)</para>
             <para>Add a gridSize optional parameter to ST_Union, ST_UnaryUnion,
                 ST_Difference, ST_Intersection, ST_SymDifference, ST_Subdivide
                 Requires GEOS 3.9 (Sandro Santilli)</para>
         </simplesect>
-        <simplesect><title>Enhancements</title>
+        <simplesect>
             <para>4789, Speed up TopoJSON output for areal TopoGeometry with
                     many holes (Sandro Santilli)</para>
             <para>4758, Improve topology noding robustness (Sandro Santilli)</para>
@@ -52,18 +92,27 @@
            extracting the components of highest coordinate dimension. (Paul Ramsey)</para>
         </simplesect>
-        <simplesect><title>Bug Fixes</title>
-            <para>4691, Fix segfault during gist index creation with empty geometries (Raúl Marín)</para>
+        <simplesect>
+            <title>Bug Fixes</title>
+            <para>4691, Fix segfault during gist index creation with
+                empty geometries (Raúl Marín)</para>
             <para>Fix handling of bad WKB inputs (Oracle types) and unit tests for
-                malformed WKB. Remove memory leaks in malformed WKB cases. (Paul Ramsey)</para>
+                malformed WKB. Remove memory leaks in malformed WKB cases.
+                (Paul Ramsey)</para>
             <para>4740, Round values in geography_distance_tree
-                    as we do on geography_distance (Raúl Marín, Paul Ramsey, Regina Obe)</para>
-            <para>4739, Ensure all functions using postgis_oid initialize the internal cache (Raúl Marín)</para>
-            <para>4767, #4768, #4771, #4772, Fix segfault when parsing invalid WKB (Raúl Marín)</para>
+                as we do on geography_distance (Raúl Marín, Paul Ramsey,
+                Regina Obe)</para>
+            <para>4739, Ensure all functions using postgis_oid initialize
+                the internal cache (Raúl Marín)</para>
+            <para>4767, #4768, #4771, #4772, Fix segfault when parsing
+                invalid WKB (Raúl Marín)</para>
             <para>4769, Fix segfault in st_addband (Raúl Marín)</para>
-            <para>4790, Fix ST_3dintersects calculations with identical vertices (Nicklas Avén)</para>
-            <para>4742, tiger geocoder reverted to 2018 version on tiger upgrade (Regina Obe)</para>
-            <para>3372, TopoElementArray cannot be null - change domain constraint (Regina Obe)</para>
+            <para>4790, Fix ST_3dintersects calculations with identical
+                vertices (Nicklas Avén)</para>
+            <para>4742, tiger geocoder reverted to 2018 version on tiger
+                upgrade (Regina Obe)</para>
+            <para>3372, TopoElementArray cannot be null - change
+                domain constraint (Regina Obe)</para>
         </simplesect>
     </sect1>
     <sect1>
@@ -80,18 +129,18 @@
         <simplesect>
-                <para>4675, topology.GetRingEdges now implemented in C (Sandro Santilli)</para>
-                <para>4681, ST_GetFaceGeometry: print corruption information (Sandro Santilli)</para>
-                <para>4651, ST_Simplify: Don't copy if nothing is removed (Raúl Marín)</para>
-                <para>4657, Avoid De-TOASTing where possible (Paul Ramsey)</para>
-                <para>4490, Tweak function costs (Raúl Marín)</para>
-                <para>4672, Cache getSRSbySRID and getSRIDbySRS (Raúl Marín)</para>
-                <para>4676, Avoid decompressing toasted geometries to read only the header (Raúl Marín)
-                        Optimize cast to Postgresql point type (Raúl Marín)</para>
-                <para>4620, Update internal wagyu to 0.5.0 (Raúl Marín)</para>
-                <para>4623, Optimize varlena returning functions (Raúl Marín)</para>
-                <para>4677, Share gserialized objects between different cache types (Raúl Marín)</para>
-                <para>Fix compilation with MSVC compiler / Standardize shebangs (Loïc Bartoletti)</para>
+            <para>4675, topology.GetRingEdges now implemented in C (Sandro Santilli)</para>
+            <para>4681, ST_GetFaceGeometry: print corruption information (Sandro Santilli)</para>
+            <para>4651, ST_Simplify: Don't copy if nothing is removed (Raúl Marín)</para>
+            <para>4657, Avoid De-TOASTing where possible (Paul Ramsey)</para>
+            <para>4490, Tweak function costs (Raúl Marín)</para>
+            <para>4672, Cache getSRSbySRID and getSRIDbySRS (Raúl Marín)</para>
+            <para>4676, Avoid decompressing toasted geometries to read only the header (Raúl Marín)
+                    Optimize cast to Postgresql point type (Raúl Marín)</para>
+            <para>4620, Update internal wagyu to 0.5.0 (Raúl Marín)</para>
+            <para>4623, Optimize varlena returning functions (Raúl Marín)</para>
+            <para>4677, Share gserialized objects between different cache types (Raúl Marín)</para>
+            <para>Fix compilation with MSVC compiler / Standardize shebangs (Loïc Bartoletti)</para>
         </simplesect>
         <simplesect>
Summary of changes:
 NEWS                  |  6 ++--
 README.postgis        |  4 +--
 Version.config        |  2 +-
 doc/release_notes.xml | 99 ++++++++++++++++++++++++++++++++++++++-------------
 4 files changed, 80 insertions(+), 31 deletions(-)
hooks/post-receive
