[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0beta1-6-ge89d573
Thu Dec 10 14:44:56 PST 2020
the project "PostGIS".
       via  e89d573b6c4e1c92a9c5322dcbb3491358191f04 (commit)
      from  b3ccfa3cbfb3fb708d83229aef09273fca6e53c5 (commit)
revisions in full, below.
commit e89d573b6c4e1c92a9c5322dcbb3491358191f04
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Dec 10 14:44:49 2020 -0800
    Add doc Spatial Query section
diff --git a/doc/.tx/config b/doc/.tx/config
index bcb9fa4..0ba44a8 100644
--- a/doc/.tx/config
+++ b/doc/.tx/config
@@ -161,6 +161,11 @@ file_filter = po/<lang>/using_postgis_dataman.xml.po
 source_file = po/templates/using_postgis_dataman.xml.pot
 source_lang = en
+[postgis.using_postgis_querypot]
+file_filter = po/<lang>/using_postgis_query.xml.po
+source_file = po/templates/using_postgis_query.xml.pot
+source_lang = en
 [postgis.using_raster_datamanxmlpot]
 file_filter = po/<lang>/using_raster_dataman.xml.po
 source_file = po/templates/using_raster_dataman.xml.pot
@@ -220,4 +225,3 @@ source_lang = en
 file_filter = po/<lang>/administration.xml.po
 source_file = po/templates/administration.xml.pot
 source_lang = en
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 80150a1..6ade51d 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -155,6 +155,7 @@ XML_SOURCES = \
 	reporting.xml \
 	using_postgis_app.xml \
 	using_postgis_dataman.xml \
+	using_postgis_query.xml \
 XML_GENERATED_SOURCES = \
diff --git a/doc/postgis.xml b/doc/postgis.xml
index 64e3856..a64c035 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -20,6 +20,7 @@
 <!ENTITY administration SYSTEM "administration.xml">
 <!ENTITY usage SYSTEM "usage.xml">
 <!ENTITY using_postgis_dataman SYSTEM "using_postgis_dataman.xml">
+<!ENTITY using_postgis_query SYSTEM "using_postgis_query.xml">
 <!ENTITY using_raster_dataman SYSTEM "using_raster_dataman.xml">
 <!ENTITY using_postgis_app SYSTEM "using_postgis_app.xml">
 <!ENTITY performance_tips SYSTEM "performance_tips.xml">
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index 65fe750..2c81460 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -1403,7 +1403,7 @@ FROM (SELECT ST_Buffer(ST_GeomFromText('POINT(1 0.5)'), 3)  As a,
             which is not evaluated by any named predicate.
             </para>
             <para>
-             For more information refer to <xref linkend="DE-9IM" />.
+             For more information refer to <xref linkend="eval_spatial_rel" />.
             </para>
 			<para><emphasis role="bold">Variant 1:</emphasis> Tests if two geometries are spatially related
@@ -1498,7 +1498,7 @@ FF1FF0102
 		<title>See Also</title>
 		<para>
-            <xref linkend="DE-9IM" />, <xref linkend="ST_RelateMatch" />,
+            <xref linkend="eval_spatial_rel" />, <xref linkend="ST_RelateMatch" />,
             <xref linkend="ST_Contains" />, <xref linkend="ST_ContainsProperly" />,
             <xref linkend="ST_Covers" />, <xref linkend="ST_CoveredBy" />,
             <xref linkend="ST_Crosses" />, <xref linkend="ST_Disjoint" />, <xref linkend="ST_Equals" />,
@@ -1536,7 +1536,7 @@ FF1FF0102
         Intersection matrix values can be computed by <xref linkend="ST_Relate" />.
         </para>
         <para>
         </para>
 		<para>Performed by the GEOS module</para>
@@ -1587,7 +1587,7 @@ SELECT pat.name AS relationship, pat.val AS pattern,
 	<!-- Optionally add a "See Also" section -->
 	<refsection>
-		<para><xref linkend="DE-9IM" />, <xref linkend="ST_Relate" /></para>
+		<para><xref linkend="eval_spatial_rel" />, <xref linkend="ST_Relate" /></para>
 	</refsection>
 </refentry>
diff --git a/doc/usage.xml b/doc/usage.xml
index 09c1c2e..2c30496 100644
--- a/doc/usage.xml
+++ b/doc/usage.xml
@@ -3,6 +3,7 @@
   <title>PostGIS Usage</title>
   &using_postgis_dataman;
+  &using_postgis_query;
   &performance_tips;
   &using_postgis_app;
   &using_raster_dataman;
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 599d747..dd68cec 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -1,6 +1,6 @@
 <sect1 id="using_postgis_dbmanagement">
-  <title>Data Management and Queries</title>
+  <title>Data Management</title>
   <sect2 id="RefObject">
 	<title>GIS Objects</title>
@@ -1221,429 +1221,6 @@ gisdb=# SELECT
 	  </note>
 	</sect3>
-      <sect3 id="DE-9IM">
-        <title>Evaluating Spatial Relationships with the DE-9IM</title>
-        <para>
-        The OGC SFS defines a set of <emphasis>named spatial relationship predicates</emphasis> to evaluate the
-        spatial relationship between pairs of geometries.
-        PostGIS provides these as the functions
-            <xref linkend="ST_Contains" />,
-            <xref linkend="ST_Crosses" />, <xref linkend="ST_Disjoint" />, <xref linkend="ST_Equals" />,
-            <xref linkend="ST_Intersects" />, <xref linkend="ST_Overlaps" />,
-            <xref linkend="ST_Touches" />, <xref linkend="ST_Within" />.
-        It also defines the non-standard relationship predicates
-            <xref linkend="ST_Covers" />, <xref linkend="ST_CoveredBy" />,
-            and <xref linkend="ST_ContainsProperly" />.
-        </para>
-        <para>In some cases the named spatial relationships
-        are insufficient to  provide a desired spatial filter.
-        </para>
-        <informaltable frame="none" border="0">
-          <tgroup cols="1">
-            <tbody>
-              <row>
-                <entry><para><informalfigure float="1" floatstyle="left">
-                    <graphic align="left" fileref="images/de9im01.png" />
-                  </informalfigure></para><para>For example, consider a linear
-                dataset representing a road network. It may be required
-                to identify all road segments that cross
-                each other, not at a point, but in a line (perhaps to validate some business rule).
-                In this case <xref linkend="ST_Crosses" /> does not
-                provide the necessary spatial filter, since for
-                linear features it returns <varname>true</varname> only where they cross at a point.
-                </para>
-                <para>A two-step solution
-                would be to first compute the actual intersection
-                (<xref linkend="ST_Intersection" />) of pairs of road lines that spatially
-                intersect (<xref linkend="ST_Intersects" />), and then check if the intersection's
-                <xref linkend="ST_GeometryType" /> is '<varname>LINESTRING</varname>' (properly
-                dealing with cases that return
-                <varname>GEOMETRYCOLLECTION</varname>s of
-                <varname>[MULTI]POINT</varname>s,
-                <varname>[MULTI]LINESTRING</varname>s, etc.).</para>
-                <para>Clearly, a simpler and faster solution is desirable.</para></entry>
-              </row>
-            </tbody>
-          </tgroup>
-        </informaltable>
-          <tgroup cols="1">
-            <tbody>
-              <row>
-                <entry><para> <informalfigure float="1" floatstyle="right">
-                    <graphic align="right" fileref="images/de9im02.png" />
-                  </informalfigure></para> <para>A second
-                example is locating
-                wharves that intersect a lake's boundary on a line and
-                where one end of the wharf is up on shore. In other
-                words, where a wharf is within but not completely contained by a
-                lake, intersects the boundary of a lake on a line, and where
-                exactly one of the wharf's endpoints is within or on the
-                boundary of the lake. It is possible to use a
-                combination of spatial predicates to find the required
-                features:</para> <itemizedlist>
-                    <listitem>
-                      <para><xref linkend="ST_Contains" />(lake, wharf) = TRUE</para>
-                    </listitem>
-                    <listitem>
-                      <para><xref linkend="ST_ContainsProperly" />(lake, wharf) = FALSE</para>
-                    </listitem>
-                    <listitem>
-                      <para><xref linkend="ST_GeometryType" />(<xref linkend="ST_Intersection" />(wharf, lake)) =
-                      'LINESTRING'</para>
-                    </listitem>
-                    <listitem>
-                      <para><xref linkend="ST_NumGeometries" />(<xref linkend="ST_Multi" />(<xref linkend="ST_Intersection" />(<xref linkend="ST_Boundary" />(wharf),
-                      <xref linkend="ST_Boundary" />(lake)))) = 1</para>
-                      <para>... but needless to say, this is quite complicated.</para>
-                    </listitem>
-                  </itemizedlist></entry>
-              </row>
-            </tbody>
-          </tgroup>
-        </informaltable>
-        <para>These requirements can be met by using the
-        Dimensionally Extended 9-Intersection Model (DE-9IM for short).</para>
-        <sect4>
-          <title>Theory</title>
-          <para>According to the <ulink
-          url="http://www.opengeospatial.org/standards/sfs">OpenGIS Simple
-          Features Implementation Specification for SQL</ulink>, "the basic
-          approach to comparing two geometries is to make pair-wise tests of
-          the intersections between the Interiors, Boundaries and Exteriors of
-          the two geometries and to classify the relationship between the two
-          geometries based on the entries in the resulting 'intersection'
-          matrix."</para>
-        <para>In the theory of point-set topology,
-        the points in a geometry embedded in 2-dimensional space
-        can be categorized into the following sets:
-        </para>
-          <glosslist>
-            <glossentry>
-              <glossterm>Boundary</glossterm>
-              <glossdef>
-                <para>The boundary of a geometry is the set of geometries of
-                the next lower dimension. For <varname>POINT</varname>s, which
-                have a dimension of 0, the boundary is the empty set. The
-                boundary of a <varname>LINESTRING</varname> is the two
-                endpoints. For <varname>POLYGON</varname>s, the boundary is
-                the linework of the exterior and interior
-                rings.</para>
-              </glossdef>
-            </glossentry>
-            <glossentry>
-              <glossterm>Interior</glossterm>
-              <glossdef>
-                <para>The interior of a geometry are those points of a
-                geometry that are not in the boundary. For
-                <varname>POINT</varname>s, the interior is the
-                point itself. The interior of a
-                <varname>LINESTRING</varname> is the set of points
-                between the endpoints. For <varname>POLYGON</varname>s, the
-                interior is the areal surface inside the polygon.</para>
-              </glossdef>
-            </glossentry>
-            <glossentry>
-              <glossterm>Exterior</glossterm>
-              <glossdef>
-                <para>The exterior of a geometry is the rest of the space
-                in which the geometry is embedded;
-                in other words, all points not in the interior or on the boundary of the geometry.
-                It is a 2-dimensional non-closed surface.
-                </para>
-              </glossdef>
-            </glossentry>
-          </glosslist>
-        <para>The <ulink url="http://en.wikipedia.org/wiki/DE-9IM">Dimensionally Extended 9-Intersection Model</ulink>
-        (DE-9IM) describes the spatial relationship between two geometries
-        by specifying the dimensions of the 9 intersections between the above sets for each geometry.
-        The intersection dimensions can be formally represented
-        in a 3x3 <emphasis role="bold">intersection matrix</emphasis>.
-        </para>
-        <para>For a geometry <emphasis>g</emphasis>
-            the <emphasis>Interior</emphasis>, <emphasis>Boundary</emphasis>, and <emphasis>Exterior</emphasis>
-            are denoted using the notation
-          <emphasis>I(g)</emphasis>, <emphasis>B(g)</emphasis>, and
-          <emphasis>E(g)</emphasis>.
-          Also, <emphasis>dim(g)</emphasis> denotes the dimension of
-          <emphasis>g</emphasis> with the domain of
-          <literal>{0,1,2,F}</literal>
-          (as computed by <xref linkend="ST_Dimension" />)
-        </para>
-        <itemizedlist spacing="compact">
-        <listitem>
-            <para><literal>0</literal> => point</para>
-        </listitem>
-        <listitem>
-            <para><literal>1</literal> => line</para>
-        </listitem>
-        <listitem>
-            <para><literal>2</literal> => area</para>
-        </listitem>
-        <listitem>
-            <para><literal>F</literal> => empty set</para>
-        </listitem>
-        </itemizedlist>
-        <para>
-          Using this notation, the intersection matrix
-          for two geometries <emphasis>a</emphasis> and <emphasis>b</emphasis> is:</para>
-          <informaltable tabstyle="styledtable">
-            <tgroup align="center" cols="4">
-              <thead>
-                <row>
-                  <entry></entry>
-                  <entry><emphasis role="bold">Interior</emphasis></entry>
-                  <entry><emphasis role="bold">Boundary</emphasis></entry>
-                  <entry><emphasis role="bold">Exterior</emphasis></entry>
-                </row>
-              </thead>
-              <tbody>
-                <row>
-                  <entry><emphasis>dim( I(a) ∩ I(b) )</emphasis></entry>
-                  <entry><emphasis>dim( I(a) ∩ B(b) )</emphasis></entry>
-                  <entry><emphasis>dim( I(a) ∩ E(b) )</emphasis></entry>
-                </row>
-                <row>
-                  <entry><emphasis>dim( B(a) ∩ I(b) )</emphasis></entry>
-                  <entry><emphasis>dim( B(a) ∩ B(b) )</emphasis></entry>
-                  <entry><emphasis>dim( B(a) ∩ E(b) )</emphasis></entry>
-                </row>
-                <row>
-                  <entry><emphasis>dim( E(a) ∩ I(b) )</emphasis></entry>
-                  <entry><emphasis>dim( E(a) ∩ B(b) )</emphasis></entry>
-                  <entry><emphasis>dim( E(a) ∩ E(b) )</emphasis></entry>
-                </row>
-              </tbody>
-            </tgroup>
-          </informaltable>
-         <para>Visually, for two overlapping polygonal geometries, this looks like:</para>
-            <tgroup cols="2">
-              <colspec colwidth="80pt" />
-              <tbody>
-                <row>
-                  <entry></entry>
-                  <entry align="center"><para><informalfigure>
-                      <graphic align="center" fileref="images/de9im04.png"
-                               valign="middle" />
-                    </informalfigure></para></entry>
-                </row>
-                <row>
-                  <entry align="center" valign="middle"><para><informalfigure>
-                      <graphic align="center" fileref="images/de9im03.png"
-                  <entry><para> <informaltable tabstyle="styledtable">
-                        <thead valign="middle">
-                          <row>
-                            <entry></entry>
-                            <entry><emphasis
-                            role="bold">Interior</emphasis></entry>
-                            <entry><emphasis
-                            role="bold">Boundary</emphasis></entry>
-                            <entry><emphasis
-                            role="bold">Exterior</emphasis></entry>
-                          </row>
-                        </thead>
-                        <tbody valign="middle">
-                          <row>
-                            <entry spanname="de9im_a" style=""><emphasis
-                            <entry><para><informalfigure>
-                                <graphic fileref="images/de9im05.png" />
-                              </informalfigure></para><para><emphasis>dim( I(a) ∩ I(b) ) =
-                            </emphasis><emphasis
-                            role="bold">2</emphasis></para></entry>
-                                <graphic fileref="images/de9im06.png" />
-                              </informalfigure></para><para><emphasis>dim( I(a) ∩ B(b)  =
-                            role="bold">1</emphasis></para></entry>
-                                <graphic fileref="images/de9im07.png" />
-                              </informalfigure></para><para><emphasis>dim( I(a) ∩ E(b) ) =
-                          </row>
-                          <row>
-                            <entry><emphasis
-                                <graphic fileref="images/de9im08.png" />
-                              </informalfigure></para><para><emphasis>dim( B(a) ∩ I(b) ) =
-                                <graphic fileref="images/de9im09.png" />
-                              </informalfigure></para><para><emphasis>dim( B(a) ∩ B(b) ) =
-                            role="bold">0</emphasis></para></entry>
-                                <graphic fileref="images/de9im10.png" />
-                              </informalfigure></para><para><emphasis>dim( B(a) ∩ E(b) ) =
-                          </row>
-                          <row>
-                            <entry><emphasis
-                                <graphic fileref="images/de9im11.png" />
-                              </informalfigure></para><para><emphasis>dim( E(a) ∩ I(b) ) =
-                                <graphic fileref="images/de9im12.png" />
-                              </informalfigure></para><para><emphasis>dim( E(a) ∩ B(b) ) =
-                                <graphic fileref="images/de9im13.png" />
-                              </informalfigure></para><para><emphasis>dim( E(a) ∩ E(b)  =
-                          </row>
-                        </tbody>
-                      </tgroup>
-                    </informaltable></para></entry>
-                </row>
-              </tbody>
-            </tgroup>
-          </informaltable>
-          <para>Reading from left to right and top to bottom, the intersection matrix is
-          represented as the text string '<emphasis role="bold">212101212</emphasis>'.</para>
-          <para>
-          PostGIS provides the <xref linkend="ST_Relate" /> function
-          to compute the intersection matrix:
-          </para>
-          <programlisting>
-SELECT ST_Relate( 'LINESTRING (1 1, 5 5)',
-                  'POLYGON ((3 3, 3 7, 7 7, 7 3, 3 3))' );
-st_relate
-1010F0212
-</programlisting>
-          <para>
-          To specify fully general spatial relationships,
-          an <emphasis role="bold">intersection matrix pattern</emphasis> is used.
-          This is a matrix representation augmented with the additional symbols
-          <literal>{T,*}</literal>:
-            </para>
-            <listitem>
-              <para><literal>T</literal> =>
-              intersection dimension is non-empty; i.e. is in <literal>{0,1,2}</literal></para>
-            </listitem>
-            <listitem>
-              <para><literal>*</literal> => don't care</para>
-            </listitem>
-          </itemizedlist>
-          <para>Using intersection matrix patterns,
-          specific spatial relationships can be evaluated in a more succinct way.
-          The <xref linkend="ST_Relate" /> and the <xref linkend="ST_RelateMatch" />
-          functions can be used to test intersection matrix patterns.
-          For the first example above, the intersection matrix pattern specifying
-          two lines intersecting in a line is
-          '<emphasis role="bold">1*1***1**</emphasis>':</para>
-          <programlisting>-- Find road segments that intersect in a line
-SELECT a.id
-FROM roads a, roads b
-WHERE a.id != b.id
-      AND a.geom && b.geom
-      AND ST_Relate(a.geom, b.geom, '1*1***1**');</programlisting>
-          <para>For the second example, the intersection matrix pattern
-          specifying a line partly inside and partly outside a polygon is
-          '<emphasis role="bold">102101FF2</emphasis>':</para>
-          <programlisting>-- Find wharves partly on a lake's shoreline
-SELECT a.lake_id, b.wharf_id
-FROM lakes a, wharfs b
-WHERE a.geom && b.geom
-      AND ST_Relate(a.geom, b.geom, '102101FF2');</programlisting>
-          <para>For more information, refer to:</para>
-            <listitem>
-              <para><ulink url="http://www.opengeospatial.org/standards/sfs">OpenGIS Simple
-          Features Implementation Specification for SQL</ulink> (version 1.1, section 2.1.13.2)</para>
-            </listitem>
-            <listitem>
-                <para><ulink url="https://en.wikipedia.org/wiki/DE-9IM">Dimensionally
-              Extended Nine-Intersection Model (DE-9IM)</ulink></para>
-            </listitem>
-            <listitem>
-              <para><ulink url="http://docs.geotools.org/latest/userguide/library/jts/dim9.html">GeoTools: Point Set Theory and the DE-9IM Matrix</ulink></para>
-            </listitem>
-          </itemizedlist>
-        </sect4>
-      </sect3>
   </sect2>
   <sect2 id="loading-data">
@@ -2471,268 +2048,4 @@ CREATE INDEX [indexname] ON [tablename]
 	</sect3>
   </sect2>
-  <sect2>
-	<title>Querying Spatial Data</title>
-	<para>The <emphasis>raison d'etre</emphasis> of spatial database
-	functionality is performing queries inside the database which would
-	ordinarily require desktop GIS functionality. Using PostGIS effectively
-	requires knowing what spatial functions are available,
-    how to use them in queries, and ensuring that
-	appropriate indexes are in place to provide good performance.
-    </para>
-	<sect3>
-	  <title>Taking Advantage of Indexes</title>
-	  <para>When constructing a query it is important to remember that only
-	  the bounding-box-based operators such as && can take advantage
-	  of the GiST spatial index. Functions such as
-	  <varname>ST_Distance()</varname> cannot use the index to optimize their
-	  operation. For example, the following query would be quite slow on a
-	  large table:</para>
-	  <programlisting>SELECT the_geom
-FROM geom_table
-WHERE ST_Distance(the_geom, 'SRID=312;POINT(100000 200000)') < 100</programlisting>
-	  <para>This query is selecting all the geometries in geom_table which are
-	  within 100 units of the point (100000, 200000). It will be slow because
-	  it is calculating the distance between each point in the table and our
-	  specified point, ie. one <varname>ST_Distance()</varname> calculation
-	  for each row in the table. We can avoid this by using the single step
-		index accelerated function ST_DWithin to reduce the number of distance
-		calculations required:</para>
-FROM geom_table
-WHERE ST_DWithin(the_geom, 'SRID=312;POINT(100000 200000)', 100)
-</programlisting>
-	  <para>This query selects the same geometries, but it does it in a more
-	  efficient way. Assuming there is a GiST index on the_geom, the query
-	  planner will recognize that it can use the index to reduce the number of
-	  rows before calculating the result of the <varname>ST_Distance()</varname>
-	  function. Notice that the <varname>ST_MakeEnvelope</varname> geometry which is
-	  used in the && operation is a 200 unit square box centered on
-	  the original point - this is our "query box". The && operator
-	  uses the index to quickly reduce the result set down to only those
-	  geometries which have bounding boxes that overlap the "query box".
-	  Assuming that our query box is much smaller than the extents of the
-	  entire geometry table, this will drastically reduce the number of
-	  distance calculations that need to be done.</para>
-	</sect3>
-	<sect3 id="examples_spatial_sql">
-	  <title>Examples of Spatial SQL</title>
-	  <para>The examples in this section will make use of two tables, a table
-	  of linear roads, and a table of polygonal municipality boundaries. The
-	  table definitions for the <varname>bc_roads</varname> table is:</para>
-	  <programlisting>Column      | Type              | Description
-gid         | integer           | Unique ID
-name        | character varying | Road Name
-the_geom    | geometry          | Location Geometry (Linestring)</programlisting>
-	  <para>The table definition for the <varname>bc_municipality</varname>
-	  table is:</para>
-code       | integer           | Unique ID
-name       | character varying | City / Town Name
-the_geom   | geometry          | Location Geometry (Polygon)</programlisting>
-	  <qandaset>
-		<qandaentry id="qa_total_length_roads">
-		  <question>
-			<para>What is the total length of all roads, expressed in
-			kilometers?</para>
-		  </question>
-		  <answer>
-			<para>You can answer this question with a very simple piece of
-			SQL:</para>
-			<programlisting>SELECT sum(ST_Length(the_geom))/1000 AS km_roads FROM bc_roads;
-km_roads
-70842.1243039643
-(1 row)</programlisting>
-		  </answer>
-		</qandaentry>
-		<qandaentry>
-		  <question>
-			<para>How large is the city of Prince George, in hectares?</para>
-		  </question>
-		  <answer>
-			<para>This query combines an attribute condition (on the
-			municipality name) with a spatial calculation (of the
-			area):</para>
-  ST_Area(the_geom)/10000 AS hectares
-FROM bc_municipality
-WHERE name = 'PRINCE GEORGE';
-hectares
-32657.9103824927
-		  </answer>
-		</qandaentry>
-		<qandaentry>
-		  <question>
-			<para>What is the largest municipality in the province, by
-			area?</para>
-		  </question>
-		  <answer>
-			<para>This query brings a spatial measurement into the query
-			condition. There are several ways of approaching this problem, but
-			the most efficient is below:</para>
-  name,
-FROM
-  bc_municipality
-ORDER BY hectares DESC
-LIMIT 1;
-name           | hectares
-TUMBLER RIDGE  | 155020.02556131
-			<para>Note that in order to answer this query we have to calculate
-			the area of every polygon. If we were doing this a lot it would
-			make sense to add an area column to the table that we could
-			separately index for performance. By ordering the results in a
-			descending direction, and them using the PostgreSQL "LIMIT"
-			command we can easily pick off the largest value without using an
-			aggregate function like max().</para>
-		  </answer>
-		</qandaentry>
-		<qandaentry>
-		  <question>
-			<para>What is the length of roads fully contained within each
-			municipality?</para>
-		  </question>
-		  <answer>
-			<para>This is an example of a "spatial join", because we are
-			bringing together data from two tables (doing a join) but using a
-			spatial interaction condition ("contained") as the join condition
-			rather than the usual relational approach of joining on a common
-			key:</para>
-  m.name,
-  sum(ST_Length(r.the_geom))/1000 as roads_km
-FROM
-  bc_roads AS r,
-  bc_municipality AS m
-WHERE
-  ST_Contains(m.the_geom, r.the_geom)
-GROUP BY m.name
-ORDER BY roads_km;
-name                        | roads_km
-SURREY                      | 1539.47553551242
-VANCOUVER                   | 1450.33093486576
-LANGLEY DISTRICT            | 833.793392535662
-BURNABY                     | 773.769091404338
-PRINCE GEORGE               | 694.37554369147
-...</programlisting>
-			<para>This query takes a while, because every road in the table is
-			summarized into the final result (about 250K roads for our
-			particular example table). For smaller overlays (several thousand
-			records on several hundred) the response can be very fast.</para>
-		  </answer>
-		</qandaentry>
-		<qandaentry>
-		  <question>
-			<para>Create a new table with all the roads within the city of
-			Prince George.</para>
-		  </question>
-		  <answer>
-			<para>This is an example of an "overlay", which takes in two
-			tables and outputs a new table that consists of spatially clipped
-			or cut resultants. Unlike the "spatial join" demonstrated above,
-			this query actually creates new geometries. An overlay is like a
-			turbo-charged spatial join, and is useful for more exact analysis
-			work:</para>
-			<programlisting>CREATE TABLE pg_roads as
-SELECT
-  ST_Intersection(r.the_geom, m.the_geom) AS intersection_geom,
-  ST_Length(r.the_geom) AS rd_orig_length,
-  r.*
-FROM
-  bc_roads AS r,
-WHERE
-  m.name = 'PRINCE GEORGE'
-	AND ST_Intersects(r.the_geom, m.the_geom);</programlisting>
-		  </answer>
-		</qandaentry>
-		<qandaentry>
-		  <question>
-			<para>What is the length in kilometers of "Douglas St" in
-			Victoria?</para>
-		  </question>
-		  <answer>
-  sum(ST_Length(r.the_geom))/1000 AS kilometers
-FROM
-  bc_roads r,
-  bc_municipality m
-WHERE
-	r.name = 'Douglas St'
-	AND m.name = 'VICTORIA'
-	AND ST_Intersects(m.the_geom, r.the_geom);
-kilometers
-4.89151904172838
-		  </answer>
-		</qandaentry>
-		<qandaentry>
-		  <question>
-			<para>What is the largest municipality polygon that has a
-			hole?</para>
-		  </question>
-		  <answer>
-			<programlisting>SELECT gid, name, ST_Area(the_geom) AS area
-WHERE ST_NRings(the_geom) > 1
-ORDER BY area DESC LIMIT 1;
-gid  | name         | area
-12   | SPALLUMCHEEN | 257374619.430216
-		  </answer>
-		</qandaentry>
-	  </qandaset>
-	</sect3>
-  </sect2>
 </sect1>
diff --git a/doc/using_postgis_query.xml b/doc/using_postgis_query.xml
new file mode 100644
index 0000000..5776211
--- /dev/null
+++ b/doc/using_postgis_query.xml
@@ -0,0 +1,689 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<sect1 id="using_postgis_query">
+  <title>Spatial Queries</title>
+	<para>The <emphasis>raison d'etre</emphasis> of spatial database
+	functionality is performing queries inside the database which would
+	ordinarily require desktop GIS functionality. Using PostGIS effectively
+	requires knowing what spatial functions are available,
+    how to use them in queries, and ensuring that
+	appropriate indexes are in place to provide good performance.
+    </para>
+      <sect2 id="eval_spatial_rel">
+        <title>Determining Spatial Relationships</title>
+        <para>
+        The OGC SFS defines a set of <emphasis>named spatial relationship predicates</emphasis> to evaluate the
+        spatial relationship between pairs of geometries.
+        PostGIS provides these as the functions
+            <xref linkend="ST_Contains" />,
+            <xref linkend="ST_Crosses" />, <xref linkend="ST_Disjoint" />, <xref linkend="ST_Equals" />,
+            <xref linkend="ST_Intersects" />, <xref linkend="ST_Overlaps" />,
+            <xref linkend="ST_Touches" />, <xref linkend="ST_Within" />.
+        It also defines the non-standard relationship predicates
+            <xref linkend="ST_Covers" />, <xref linkend="ST_CoveredBy" />,
+            and <xref linkend="ST_ContainsProperly" />.
+        </para>
+        <para>In some cases the named spatial relationships
+        are insufficient to  provide a desired spatial filter.
+        </para>
+        <informaltable frame="none" border="0">
+          <tgroup cols="1">
+            <tbody>
+              <row>
+                <entry><para><informalfigure float="1" floatstyle="left">
+                    <graphic align="left" fileref="images/de9im01.png" />
+                  </informalfigure></para><para>For example, consider a linear
+                dataset representing a road network. It may be required
+                to identify all road segments that cross
+                each other, not at a point, but in a line (perhaps to validate some business rule).
+                In this case <xref linkend="ST_Crosses" /> does not
+                provide the necessary spatial filter, since for
+                linear features it returns <varname>true</varname> only where they cross at a point.
+                </para>
+                <para>A two-step solution
+                would be to first compute the actual intersection
+                (<xref linkend="ST_Intersection" />) of pairs of road lines that spatially
+                intersect (<xref linkend="ST_Intersects" />), and then check if the intersection's
+                <xref linkend="ST_GeometryType" /> is '<varname>LINESTRING</varname>' (properly
+                dealing with cases that return
+                <varname>GEOMETRYCOLLECTION</varname>s of
+                <varname>[MULTI]POINT</varname>s,
+                <varname>[MULTI]LINESTRING</varname>s, etc.).</para>
+                <para>Clearly, a simpler and faster solution is desirable.</para></entry>
+              </row>
+            </tbody>
+          </tgroup>
+        </informaltable>
+          <tgroup cols="1">
+            <tbody>
+              <row>
+                <entry><para> <informalfigure float="1" floatstyle="right">
+                    <graphic align="right" fileref="images/de9im02.png" />
+                  </informalfigure></para> <para>A second
+                example is locating
+                wharves that intersect a lake's boundary on a line and
+                where one end of the wharf is up on shore. In other
+                words, where a wharf is within but not completely contained by a
+                lake, intersects the boundary of a lake on a line, and where
+                exactly one of the wharf's endpoints is within or on the
+                boundary of the lake. It is possible to use a
+                combination of spatial predicates to find the required
+                features:</para> <itemizedlist>
+                    <listitem>
+                      <para><xref linkend="ST_Contains" />(lake, wharf) = TRUE</para>
+                    </listitem>
+                    <listitem>
+                      <para><xref linkend="ST_ContainsProperly" />(lake, wharf) = FALSE</para>
+                    </listitem>
+                    <listitem>
+                      <para><xref linkend="ST_GeometryType" />(<xref linkend="ST_Intersection" />(wharf, lake)) =
+                      'LINESTRING'</para>
+                    </listitem>
+                    <listitem>
+                      <para><xref linkend="ST_NumGeometries" />(<xref linkend="ST_Multi" />(<xref linkend="ST_Intersection" />(<xref linkend="ST_Boundary" />(wharf),
+                      <xref linkend="ST_Boundary" />(lake)))) = 1</para>
+                      <para>... but needless to say, this is quite complicated.</para>
+                    </listitem>
+                  </itemizedlist></entry>
+              </row>
+            </tbody>
+          </tgroup>
+        </informaltable>
+        <para>These requirements can be met by using the
+        Dimensionally Extended 9-Intersection Model (DE-9IM for short).</para>
+        <sect3>
+          <title>Dimensionally Extended 9-Intersection Model</title>
+          <para>According to the <ulink
+          url="http://www.opengeospatial.org/standards/sfs">OpenGIS Simple
+          Features Implementation Specification for SQL</ulink>, "the basic
+          approach to comparing two geometries is to make pair-wise tests of
+          the intersections between the Interiors, Boundaries and Exteriors of
+          the two geometries and to classify the relationship between the two
+          geometries based on the entries in the resulting 'intersection'
+          matrix."</para>
+        <para>In the theory of point-set topology,
+        the points in a geometry embedded in 2-dimensional space
+        can be categorized into the following sets:
+        </para>
+          <glosslist>
+            <glossentry>
+              <glossterm>Boundary</glossterm>
+              <glossdef>
+                <para>The boundary of a geometry is the set of geometries of
+                the next lower dimension. For <varname>POINT</varname>s, which
+                have a dimension of 0, the boundary is the empty set. The
+                boundary of a <varname>LINESTRING</varname> is the two
+                endpoints. For <varname>POLYGON</varname>s, the boundary is
+                the linework of the exterior and interior
+                rings.</para>
+              </glossdef>
+            </glossentry>
+            <glossentry>
+              <glossterm>Interior</glossterm>
+              <glossdef>
+                <para>The interior of a geometry are those points of a
+                geometry that are not in the boundary. For
+                <varname>POINT</varname>s, the interior is the
+                point itself. The interior of a
+                <varname>LINESTRING</varname> is the set of points
+                between the endpoints. For <varname>POLYGON</varname>s, the
+                interior is the areal surface inside the polygon.</para>
+              </glossdef>
+            </glossentry>
+            <glossentry>
+              <glossterm>Exterior</glossterm>
+              <glossdef>
+                <para>The exterior of a geometry is the rest of the space
+                in which the geometry is embedded;
+                in other words, all points not in the interior or on the boundary of the geometry.
+                It is a 2-dimensional non-closed surface.
+                </para>
+              </glossdef>
+            </glossentry>
+          </glosslist>
+        <para>The <ulink url="http://en.wikipedia.org/wiki/DE-9IM">Dimensionally Extended 9-Intersection Model</ulink>
+        (DE-9IM) describes the spatial relationship between two geometries
+        by specifying the dimensions of the 9 intersections between the above sets for each geometry.
+        The intersection dimensions can be formally represented
+        in a 3x3 <emphasis role="bold">intersection matrix</emphasis>.
+        </para>
+        <para>For a geometry <emphasis>g</emphasis>
+            the <emphasis>Interior</emphasis>, <emphasis>Boundary</emphasis>, and <emphasis>Exterior</emphasis>
+            are denoted using the notation
+          <emphasis>I(g)</emphasis>, <emphasis>B(g)</emphasis>, and
+          <emphasis>E(g)</emphasis>.
+          Also, <emphasis>dim(g)</emphasis> denotes the dimension of
+          <emphasis>g</emphasis> with the domain of
+          <literal>{0,1,2,F}</literal>
+          (as computed by <xref linkend="ST_Dimension" />)
+        </para>
+        <itemizedlist spacing="compact">
+        <listitem>
+            <para><literal>0</literal> => point</para>
+        </listitem>
+        <listitem>
+            <para><literal>1</literal> => line</para>
+        </listitem>
+        <listitem>
+            <para><literal>2</literal> => area</para>
+        </listitem>
+        <listitem>
+            <para><literal>F</literal> => empty set</para>
+        </listitem>
+        </itemizedlist>
+        <para>
+          Using this notation, the intersection matrix
+          for two geometries <emphasis>a</emphasis> and <emphasis>b</emphasis> is:</para>
+          <informaltable tabstyle="styledtable">
+            <tgroup align="center" cols="4">
+              <thead>
+                <row>
+                  <entry></entry>
+                  <entry><emphasis role="bold">Interior</emphasis></entry>
+                  <entry><emphasis role="bold">Boundary</emphasis></entry>
+                  <entry><emphasis role="bold">Exterior</emphasis></entry>
+                </row>
+              </thead>
+              <tbody>
+                <row>
+                  <entry><emphasis>dim( I(a) ∩ I(b) )</emphasis></entry>
+                  <entry><emphasis>dim( I(a) ∩ B(b) )</emphasis></entry>
+                  <entry><emphasis>dim( I(a) ∩ E(b) )</emphasis></entry>
+                </row>
+                <row>
+                  <entry><emphasis>dim( B(a) ∩ I(b) )</emphasis></entry>
+                  <entry><emphasis>dim( B(a) ∩ B(b) )</emphasis></entry>
+                  <entry><emphasis>dim( B(a) ∩ E(b) )</emphasis></entry>
+                </row>
+                <row>
+                  <entry><emphasis>dim( E(a) ∩ I(b) )</emphasis></entry>
+                  <entry><emphasis>dim( E(a) ∩ B(b) )</emphasis></entry>
+                  <entry><emphasis>dim( E(a) ∩ E(b) )</emphasis></entry>
+                </row>
+              </tbody>
+            </tgroup>
+          </informaltable>
+         <para>Visually, for two overlapping polygonal geometries, this looks like:</para>
+            <tgroup cols="2">
+              <colspec colwidth="80pt" />
+              <tbody>
+                <row>
+                  <entry></entry>
+                  <entry align="center"><para><informalfigure>
+                      <graphic align="center" fileref="images/de9im04.png"
+                               valign="middle" />
+                    </informalfigure></para></entry>
+                </row>
+                <row>
+                  <entry align="center" valign="middle"><para><informalfigure>
+                      <graphic align="center" fileref="images/de9im03.png"
+                  <entry><para> <informaltable tabstyle="styledtable">
+                        <thead valign="middle">
+                          <row>
+                            <entry></entry>
+                            <entry><emphasis
+                            role="bold">Interior</emphasis></entry>
+                            <entry><emphasis
+                            role="bold">Boundary</emphasis></entry>
+                            <entry><emphasis
+                            role="bold">Exterior</emphasis></entry>
+                          </row>
+                        </thead>
+                        <tbody valign="middle">
+                          <row>
+                            <entry spanname="de9im_a" style=""><emphasis
+                            <entry><para><informalfigure>
+                                <graphic fileref="images/de9im05.png" />
+                              </informalfigure></para><para><emphasis>dim( I(a) ∩ I(b) ) =
+                            </emphasis><emphasis
+                            role="bold">2</emphasis></para></entry>
+                                <graphic fileref="images/de9im06.png" />
+                              </informalfigure></para><para><emphasis>dim( I(a) ∩ B(b)  =
+                            role="bold">1</emphasis></para></entry>
+                                <graphic fileref="images/de9im07.png" />
+                              </informalfigure></para><para><emphasis>dim( I(a) ∩ E(b) ) =
+                          </row>
+                          <row>
+                            <entry><emphasis
+                                <graphic fileref="images/de9im08.png" />
+                              </informalfigure></para><para><emphasis>dim( B(a) ∩ I(b) ) =
+                                <graphic fileref="images/de9im09.png" />
+                              </informalfigure></para><para><emphasis>dim( B(a) ∩ B(b) ) =
+                            role="bold">0</emphasis></para></entry>
+                                <graphic fileref="images/de9im10.png" />
+                              </informalfigure></para><para><emphasis>dim( B(a) ∩ E(b) ) =
+                          </row>
+                          <row>
+                            <entry><emphasis
+                                <graphic fileref="images/de9im11.png" />
+                              </informalfigure></para><para><emphasis>dim( E(a) ∩ I(b) ) =
+                                <graphic fileref="images/de9im12.png" />
+                              </informalfigure></para><para><emphasis>dim( E(a) ∩ B(b) ) =
+                                <graphic fileref="images/de9im13.png" />
+                              </informalfigure></para><para><emphasis>dim( E(a) ∩ E(b)  =
+                          </row>
+                        </tbody>
+                      </tgroup>
+                    </informaltable></para></entry>
+                </row>
+              </tbody>
+            </tgroup>
+          </informaltable>
+          <para>Reading from left to right and top to bottom, the intersection matrix is
+          represented as the text string '<emphasis role="bold">212101212</emphasis>'.</para>
+          <para>
+          PostGIS provides the <xref linkend="ST_Relate" /> function
+          to compute the intersection matrix:
+          </para>
+          <programlisting>
+SELECT ST_Relate( 'LINESTRING (1 1, 5 5)',
+                  'POLYGON ((3 3, 3 7, 7 7, 7 3, 3 3))' );
+st_relate
+1010F0212
+</programlisting>
+          <para>
+          To specify fully general spatial relationships,
+          an <emphasis role="bold">intersection matrix pattern</emphasis> is used.
+          This is a matrix representation augmented with the additional symbols
+          <literal>{T,*}</literal>:
+            </para>
+            <listitem>
+              <para><literal>T</literal> =>
+              intersection dimension is non-empty; i.e. is in <literal>{0,1,2}</literal></para>
+            </listitem>
+            <listitem>
+              <para><literal>*</literal> => don't care</para>
+            </listitem>
+          </itemizedlist>
+          <para>Using intersection matrix patterns,
+          specific spatial relationships can be evaluated in a more succinct way.
+          The <xref linkend="ST_Relate" /> and the <xref linkend="ST_RelateMatch" />
+          functions can be used to test intersection matrix patterns.
+          For the first example above, the intersection matrix pattern specifying
+          two lines intersecting in a line is
+          '<emphasis role="bold">1*1***1**</emphasis>':</para>
+          <programlisting>-- Find road segments that intersect in a line
+SELECT a.id
+FROM roads a, roads b
+WHERE a.id != b.id
+      AND a.geom && b.geom
+      AND ST_Relate(a.geom, b.geom, '1*1***1**');</programlisting>
+          <para>For the second example, the intersection matrix pattern
+          specifying a line partly inside and partly outside a polygon is
+          '<emphasis role="bold">102101FF2</emphasis>':</para>
+          <programlisting>-- Find wharves partly on a lake's shoreline
+SELECT a.lake_id, b.wharf_id
+FROM lakes a, wharfs b
+WHERE a.geom && b.geom
+      AND ST_Relate(a.geom, b.geom, '102101FF2');</programlisting>
+          <para>For more information, refer to:</para>
+            <listitem>
+              <para><ulink url="http://www.opengeospatial.org/standards/sfs">OpenGIS Simple
+          Features Implementation Specification for SQL</ulink> (version 1.1, section 2.1.13.2)</para>
+            </listitem>
+            <listitem>
+                <para><ulink url="https://en.wikipedia.org/wiki/DE-9IM">Dimensionally
+              Extended Nine-Intersection Model (DE-9IM)</ulink></para>
+            </listitem>
+            <listitem>
+              <para><ulink url="http://docs.geotools.org/latest/userguide/library/jts/dim9.html">GeoTools: Point Set Theory and the DE-9IM Matrix</ulink></para>
+            </listitem>
+          </itemizedlist>
+        </sect3>
+    </sect2>
+	<sect2>
+	  <title>Taking Advantage of Indexes</title>
+	  <para>When constructing a query it is important to remember that only
+	  the bounding-box-based operators such as && can take advantage
+	  of the GiST spatial index. Functions such as
+	  <varname>ST_Distance()</varname> cannot use the index to optimize their
+	  operation. For example, the following query would be quite slow on a
+	  large table:</para>
+	  <programlisting>SELECT the_geom
+FROM geom_table
+WHERE ST_Distance(the_geom, 'SRID=312;POINT(100000 200000)') < 100</programlisting>
+	  <para>This query is selecting all the geometries in geom_table which are
+	  within 100 units of the point (100000, 200000). It will be slow because
+	  it is calculating the distance between each point in the table and our
+	  specified point, ie. one <varname>ST_Distance()</varname> calculation
+	  for each row in the table. We can avoid this by using the single step
+		index accelerated function ST_DWithin to reduce the number of distance
+		calculations required:</para>
+FROM geom_table
+WHERE ST_DWithin(the_geom, 'SRID=312;POINT(100000 200000)', 100)
+</programlisting>
+	  <para>This query selects the same geometries, but it does it in a more
+	  efficient way. Assuming there is a GiST index on the_geom, the query
+	  planner will recognize that it can use the index to reduce the number of
+	  rows before calculating the result of the <varname>ST_Distance()</varname>
+	  function. Notice that the <varname>ST_MakeEnvelope</varname> geometry which is
+	  used in the && operation is a 200 unit square box centered on
+	  the original point - this is our "query box". The && operator
+	  uses the index to quickly reduce the result set down to only those
+	  geometries which have bounding boxes that overlap the "query box".
+	  Assuming that our query box is much smaller than the extents of the
+	  entire geometry table, this will drastically reduce the number of
+	  distance calculations that need to be done.</para>
+	</sect2>
+	<sect2 id="examples_spatial_sql">
+	  <title>Examples of Spatial SQL</title>
+	  <para>The examples in this section will make use of two tables, a table
+	  of linear roads, and a table of polygonal municipality boundaries. The
+	  table definitions for the <varname>bc_roads</varname> table is:</para>
+	  <programlisting>Column      | Type              | Description
+gid         | integer           | Unique ID
+name        | character varying | Road Name
+the_geom    | geometry          | Location Geometry (Linestring)</programlisting>
+	  <para>The table definition for the <varname>bc_municipality</varname>
+	  table is:</para>
+code       | integer           | Unique ID
+name       | character varying | City / Town Name
+the_geom   | geometry          | Location Geometry (Polygon)</programlisting>
+	  <qandaset>
+		<qandaentry id="qa_total_length_roads">
+		  <question>
+			<para>What is the total length of all roads, expressed in
+			kilometers?</para>
+		  </question>
+		  <answer>
+			<para>You can answer this question with a very simple piece of
+			SQL:</para>
+			<programlisting>SELECT sum(ST_Length(the_geom))/1000 AS km_roads FROM bc_roads;
+km_roads
+70842.1243039643
+(1 row)</programlisting>
+		  </answer>
+		</qandaentry>
+		<qandaentry>
+		  <question>
+			<para>How large is the city of Prince George, in hectares?</para>
+		  </question>
+		  <answer>
+			<para>This query combines an attribute condition (on the
+			municipality name) with a spatial calculation (of the
+			area):</para>
+  ST_Area(the_geom)/10000 AS hectares
+FROM bc_municipality
+WHERE name = 'PRINCE GEORGE';
+hectares
+32657.9103824927
+		  </answer>
+		</qandaentry>
+		<qandaentry>
+		  <question>
+			<para>What is the largest municipality in the province, by
+			area?</para>
+		  </question>
+		  <answer>
+			<para>This query brings a spatial measurement into the query
+			condition. There are several ways of approaching this problem, but
+			the most efficient is below:</para>
+  name,
+FROM
+  bc_municipality
+ORDER BY hectares DESC
+LIMIT 1;
+name           | hectares
+TUMBLER RIDGE  | 155020.02556131
+			<para>Note that in order to answer this query we have to calculate
+			the area of every polygon. If we were doing this a lot it would
+			make sense to add an area column to the table that we could
+			separately index for performance. By ordering the results in a
+			descending direction, and them using the PostgreSQL "LIMIT"
+			command we can easily pick off the largest value without using an
+			aggregate function like max().</para>
+		  </answer>
+		</qandaentry>
+		<qandaentry>
+		  <question>
+			<para>What is the length of roads fully contained within each
+			municipality?</para>
+		  </question>
+		  <answer>
+			<para>This is an example of a "spatial join", because we are
+			bringing together data from two tables (doing a join) but using a
+			spatial interaction condition ("contained") as the join condition
+			rather than the usual relational approach of joining on a common
+			key:</para>
+  m.name,
+  sum(ST_Length(r.the_geom))/1000 as roads_km
+FROM
+  bc_roads AS r,
+  bc_municipality AS m
+WHERE
+  ST_Contains(m.the_geom, r.the_geom)
+GROUP BY m.name
+ORDER BY roads_km;
+name                        | roads_km
+SURREY                      | 1539.47553551242
+VANCOUVER                   | 1450.33093486576
+LANGLEY DISTRICT            | 833.793392535662
+BURNABY                     | 773.769091404338
+PRINCE GEORGE               | 694.37554369147
+...</programlisting>
+			<para>This query takes a while, because every road in the table is
+			summarized into the final result (about 250K roads for our
+			particular example table). For smaller overlays (several thousand
+			records on several hundred) the response can be very fast.</para>
+		  </answer>
+		</qandaentry>
+		<qandaentry>
+		  <question>
+			<para>Create a new table with all the roads within the city of
+			Prince George.</para>
+		  </question>
+		  <answer>
+			<para>This is an example of an "overlay", which takes in two
+			tables and outputs a new table that consists of spatially clipped
+			or cut resultants. Unlike the "spatial join" demonstrated above,
+			this query actually creates new geometries. An overlay is like a
+			turbo-charged spatial join, and is useful for more exact analysis
+			work:</para>
+			<programlisting>CREATE TABLE pg_roads as
+SELECT
+  ST_Intersection(r.the_geom, m.the_geom) AS intersection_geom,
+  ST_Length(r.the_geom) AS rd_orig_length,
+  r.*
+FROM
+  bc_roads AS r,
+WHERE
+  m.name = 'PRINCE GEORGE'
+	AND ST_Intersects(r.the_geom, m.the_geom);</programlisting>
+		  </answer>
+		</qandaentry>
+		<qandaentry>
+		  <question>
+			<para>What is the length in kilometers of "Douglas St" in
+			Victoria?</para>
+		  </question>
+		  <answer>
+  sum(ST_Length(r.the_geom))/1000 AS kilometers
+FROM
+  bc_roads r,
+  bc_municipality m
+WHERE
+	r.name = 'Douglas St'
+	AND m.name = 'VICTORIA'
+	AND ST_Intersects(m.the_geom, r.the_geom);
+kilometers
+4.89151904172838
+		  </answer>
+		</qandaentry>
+		<qandaentry>
+		  <question>
+			<para>What is the largest municipality polygon that has a
+			hole?</para>
+		  </question>
+		  <answer>
+			<programlisting>SELECT gid, name, ST_Area(the_geom) AS area
+WHERE ST_NRings(the_geom) > 1
+ORDER BY area DESC LIMIT 1;
+gid  | name         | area
+12   | SPALLUMCHEEN | 257374619.430216
+		  </answer>
+		</qandaentry>
+	  </qandaset>
+  </sect2>
+</sect1>
Summary of changes:
 doc/.tx/config                 |   6 +-
 doc/Makefile.in                |   1 +
 doc/postgis.xml                |   1 +
 doc/reference_relationship.xml |   8 +-
 doc/usage.xml                  |   1 +
 doc/using_postgis_dataman.xml  | 689 +----------------------------------------
 doc/using_postgis_query.xml    | 689 +++++++++++++++++++++++++++++++++++++++++
 7 files changed, 702 insertions(+), 693 deletions(-)
 create mode 100644 doc/using_postgis_query.xml
hooks/post-receive
