[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0beta1-10-ga7053ec
Fri Dec 11 02:03:05 PST 2020
the project "PostGIS".
       via  a7053ec1333935d0afcf78d7f56eb197b8ff3db5 (commit)
      from  2b8b57d1141e502a3c167337543b306adc75fb74 (commit)
revisions in full, below.
commit a7053ec1333935d0afcf78d7f56eb197b8ff3db5
Author: Sandro Santilli <strk at kbt.io>
Date:   Tue Dec 8 22:57:20 2020 +0100
    Have ST_MakeValid remove coordinates with NaN values
    Closes #4813
diff --git a/NEWS b/NEWS
index 9ca3cf3..03c674c 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,7 @@ Only tickets not included in 3.1.0beta1
            to GEOS (Sandro Santilli)
   - #4815, Fix GEOS conversion of POINT EMPTY to retain type
            (Sandro Santilli)
+  - #4813, ST_MakeValid removing NaN coordinates (Sandro Santilli)
 PostGIS 3.1.0beta1
 2020/12/09
@@ -31,6 +32,7 @@ Only tickets not included in 3.1.0alpha3
   - Fix axis order issue with urn:ogc:def:crs:EPSG in ST_GeomFromGML()
            (Even Roualt)
 PostGIS 3.1.0alpha3
 2020/11/19
 Only tickets not included in 3.1.0alpha2
diff --git a/doc/reference_validation.xml b/doc/reference_validation.xml
index adc0d40..56461a1 100644
--- a/doc/reference_validation.xml
+++ b/doc/reference_validation.xml
@@ -320,6 +320,7 @@ SELECT ST_IsValidReason('LINESTRING(220227 150406,2220227 150407,222020 150410)'
     <para>Availability: 2.0.0</para>
     <para>Enhanced: 2.0.1, speed improvements</para>
     <para>Enhanced: 2.1.0, added support for GEOMETRYCOLLECTION and MULTIPOINT.</para>
+    <para>Enhanced: 3.1.0, added removal of Coordinates with NaN values.</para>
     <para>&Z_support;</para>
diff --git a/liblwgeom/lwgeom_geos_clean.c b/liblwgeom/lwgeom_geos_clean.c
index 9ef3108..3714e63 100644
--- a/liblwgeom/lwgeom_geos_clean.c
+++ b/liblwgeom/lwgeom_geos_clean.c
@@ -22,6 +22,9 @@
+#include "../postgis_config.h"
+/*#define POSTGIS_DEBUG_LEVEL 4*/
 #include "liblwgeom.h"
 #include "lwgeom_geos.h"
 #include "liblwgeom_internal.h"
@@ -31,7 +34,6 @@
 #include <stdlib.h>
 #include <assert.h>
-/* #define POSTGIS_DEBUG_LEVEL 4 */
 /* #define PARANOIA_LEVEL 2 */
 #undef LWGEOM_PROFILE_MAKEVALID
@@ -116,6 +118,36 @@ LWGEOM* lwline_make_geos_friendly(LWLINE* line);
 LWGEOM* lwpoly_make_geos_friendly(LWPOLY* poly);
 POINTARRAY* ring_make_geos_friendly(POINTARRAY* ring);
+static void
+ptarray_strip_nan_coords_in_place(POINTARRAY *pa)
+	uint32_t i, j = 0;
+	POINT4D *p, *np;
+	int ndims = FLAGS_NDIMS(pa->flags);
+	for ( i = 0; i < pa->npoints; i++ )
+		int isnan = 0;
+		p = (POINT4D *)(getPoint_internal(pa, i));
+		if ( isnan(p->x) || isnan(p->y) ) isnan = 1;
+		else if (ndims > 2 && isnan(p->z) ) isnan = 1;
+		else if (ndims > 3 && isnan(p->m) ) isnan = 1;
+		if ( isnan ) continue;
+		np = (POINT4D *)(getPoint_internal(pa, j++));
+		if ( np != p ) {
+			np->x = p->x;
+			np->y = p->y;
+			if (ndims > 2)
+				np->z = p->z;
+			if (ndims > 3)
+				np->m = p->m;
+	pa->npoints = j;
  * Ensure the geometry is "structurally" valid
  * (enough for GEOS to accept it)
@@ -129,10 +161,8 @@ lwgeom_make_geos_friendly(LWGEOM* geom)
 	switch (geom->type)
 	case POINTTYPE:
-	case MULTIPOINTTYPE:
-		/* a point is always valid */
+		ptarray_strip_nan_coords_in_place(((LWPOINT*)geom)->point);
 		return geom;
-		break;
 	case LINETYPE:
 		/* lines need at least 2 points */
@@ -147,6 +177,7 @@ lwgeom_make_geos_friendly(LWGEOM* geom)
 	case MULTILINETYPE:
 	case MULTIPOLYGONTYPE:
 	case COLLECTIONTYPE:
+	case MULTIPOINTTYPE:
 		return lwcollection_make_geos_friendly((LWCOLLECTION*)geom);
 		break;
@@ -170,8 +201,7 @@ lwgeom_make_geos_friendly(LWGEOM* geom)
  * constructed POINTARRAY.
  * TODO: move in ptarray.c
-POINTARRAY* ptarray_close2d(POINTARRAY* ring);
-POINTARRAY*
+static POINTARRAY*
 	POINTARRAY* newring;
@@ -193,6 +223,8 @@ ring_make_geos_friendly(POINTARRAY* ring)
 	POINTARRAY* closedring;
 	POINTARRAY* ring_in = ring;
+	ptarray_strip_nan_coords_in_place(ring_in);
 	/* close the ring if not already closed (2d only) */
 	closedring = ptarray_close2d(ring);
 	if (closedring != ring) ring = closedring;
@@ -259,6 +291,8 @@ lwline_make_geos_friendly(LWLINE* line)
 	LWGEOM* ret;
+	ptarray_strip_nan_coords_in_place(line->points);
 	if (line->points->npoints == 1) /* 0 is fine, 2 is fine */
 #if 1
@@ -858,6 +892,8 @@ lwgeom_make_valid(LWGEOM* lwgeom_in)
 	GEOSGeometry* geosout;
 	LWGEOM* lwgeom_out;
+	LWDEBUG(1, "lwgeom_make_valid enter");
 	is3d = FLAGS_GET_Z(lwgeom_in->flags);
@@ -867,7 +903,9 @@ lwgeom_make_valid(LWGEOM* lwgeom_in)
 	initGEOS(lwgeom_geos_error, lwgeom_geos_error);
-	lwgeom_out = lwgeom_in;
+	lwgeom_out = lwgeom_make_geos_friendly(lwgeom_in);
+	if (!lwgeom_out) lwerror("Could not make a geos friendly geometry out of input");
 	geosgeom = LWGEOM2GEOS(lwgeom_out, 1);
 	if (!geosgeom)
@@ -876,8 +914,6 @@ lwgeom_make_valid(LWGEOM* lwgeom_in)
 			 " - will try cleaning that up first",
 			 lwgeom_geos_errmsg);
-		lwgeom_out = lwgeom_make_geos_friendly(lwgeom_out);
-		if (!lwgeom_out) lwerror("Could not make a valid geometry out of input");
 		/* try again as we did cleanup now */
 		/* TODO: invoke LWGEOM2GEOS directly with autoclean ? */
diff --git a/postgis/lwgeom_geos_clean.c b/postgis/lwgeom_geos_clean.c
index 12ce779..36228e6 100644
--- a/postgis/lwgeom_geos_clean.c
+++ b/postgis/lwgeom_geos_clean.c
@@ -27,7 +27,10 @@
 #include "fmgr.h"
 #include "funcapi.h"
 #include "lwgeom_pg.h"
@@ -35,8 +38,6 @@
 #include <string.h>
 #include <assert.h>
 Datum ST_MakeValid(PG_FUNCTION_ARGS);
 PG_FUNCTION_INFO_V1(ST_MakeValid);
@@ -47,6 +48,8 @@ Datum ST_MakeValid(PG_FUNCTION_ARGS)
 	in = PG_GETARG_GSERIALIZED_P(0);
 	lwgeom_in = lwgeom_from_gserialized(in);
+	POSTGIS_DEBUG(1, "ST_MakeValid enter");
 	switch ( lwgeom_in->type )
 	case POINTTYPE:
diff --git a/regress/core/clean.sql b/regress/core/clean.sql
index d641075..cc3460a 100644
--- a/regress/core/clean.sql
+++ b/regress/core/clean.sql
@@ -49,4 +49,46 @@ SELECT '#1719.1', ST_AsEWKT(ST_MakeValid('POINT(0 0)'));
 SELECT '#1719.2', ST_AsEWKT(ST_Normalize(ST_MakeValid('GEOMETRYCOLLECTION(POINT(0 0),MULTIPOINT(3 4,5 2),LINESTRING(4 4, 4 4),POLYGON((0 0,10 10,0 10,10 0,0 0)))')));
 SELECT '#1719.3', ST_AsEWKT(ST_MakeValid('MULTIPOINT(3 4,5 2)'));
+SELECT '#4813.0', ST_AsEWKT(ST_MakeValid(ST_SetSRID(ST_MakePoint('NaN', 'NaN'), 4326)));
+SELECT '#4813.1', ST_AsEWKT(ST_MakeValid(ST_SetSRID(ST_Collect(p), 4326))) FROM (
+		SELECT ST_MakePoint('NaN', 'NaN') as p UNION ALL
+		SELECT ST_MakePoint(1, 0) as p UNION ALL
+		SELECT ST_MakePoint('NaN', 'NaN') UNION ALL
+		SELECT ST_MakePoint(10, 10) UNION ALL
+) foo;
+SELECT '#4813.10', ST_AsEWKT(ST_MakeValid(ST_SetSRID(ST_MakeLine(p), 4326))) FROM (
+) foo;
+SELECT '#4813.11', ST_AsEWKT(ST_MakeValid(ST_SetSRID(ST_MakeLine(p), 4326))) FROM (
+) foo;
+SELECT '#4813.12', ST_AsEWKT(ST_MakeValid(ST_SetSRID(ST_MakeLine(p), 4326))) FROM (
+	SELECT ST_MakePoint(2, 0)
+) foo;
+SELECT '#4813.13', ST_AsEWKT(ST_MakeValid(ST_SetSRID(ST_MakeLine(p), 4326))) FROM (
+	SELECT ST_MakePoint(2, 0) UNION ALL
+) foo;
+SELECT '#4813.20', ST_AsEWKT(ST_MakeValid(ST_SetSRID(ST_MakePolygon(r), 4326))) FROM (
+	SELECT ST_MakeLine(p) as r FROM (
+			SELECT ST_MakePoint(10, 0) UNION ALL
+			SELECT ST_MakePoint(0, 10) UNION ALL
+	) foo
+) bar;
 DROP TABLE clean_cases;
diff --git a/regress/core/clean_expected b/regress/core/clean_expected
index 307d75b..396dd5d 100644
--- a/regress/core/clean_expected
+++ b/regress/core/clean_expected
@@ -29,3 +29,10 @@ RT|17.1|t|t|f
 #1719.1|POINT(0 0)
 #1719.2|GEOMETRYCOLLECTION(MULTIPOLYGON(((0 10,10 10,5 5,0 10)),((0 0,5 5,10 0,0 0))),MULTIPOINT(5 2,3 4),POINT(4 4),POINT(0 0))
 #1719.3|MULTIPOINT(3 4,5 2)
+#4813.0|SRID=4326;POINT EMPTY
+#4813.1|SRID=4326;MULTIPOINT(EMPTY,1 0,EMPTY,10 10,EMPTY,EMPTY,EMPTY)
+#4813.10|SRID=4326;LINESTRING EMPTY
+#4813.11|SRID=4326;POINT(1 0)
+#4813.12|SRID=4326;LINESTRING(1 0,2 0)
+#4813.13|SRID=4326;LINESTRING(1 0,2 0)
+#4813.20|SRID=4326;POLYGON((1 0,10 0,10 10,0 10,1 0))
Summary of changes:
 NEWS                          |  2 ++
 doc/reference_validation.xml  |  1 +
 liblwgeom/lwgeom_geos_clean.c | 54 +++++++++++++++++++++++++++++++++++--------
 postgis/lwgeom_geos_clean.c   |  7 ++++--
 regress/core/clean.sql        | 42 +++++++++++++++++++++++++++++++++
 regress/core/clean_expected   |  7 ++++++
 6 files changed, 102 insertions(+), 11 deletions(-)
hooks/post-receive
