[postgis-tickets] [PostGIS] #4816: Dronie docker images need to use geos-3.6.5 to avoid crashes
trac at osgeo.org
Fri Dec 11 06:45:07 PST 2020
Reporter: strk | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.1.0
Component: buildbots | Version: 2.5.x
Keywords: |
geos-3.6.2, currently used by Dronie CI bot, suffers a crash which was
fixed in version 3.6.5. The docker images should be updated to use that
version of GEOS.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4816>
