[postgis-tickets] [PostGIS] #4817: ST_Transform fails when both +geoidgrids and +nadgrids are present
trac at osgeo.org
Sat Dec 12 06:09:24 PST 2020
Reporter: aberenyi | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Keywords: |
The following works just fine using `cs2cs`.
`$ echo 16.582941335 47.710445103 291.7692| cs2cs -f "%.3f"
+init=epsg:4326 +to +proj=somerc +lat_0=47.14439372222222
+lon_0=19.04857177777778 +k_0=0.99993 +x_0=650000 +y_0=200000 +ellps=GRS67
+nadgrids=etrs2eov_notowgs.gsb +geoidgrids=geoid_eht2014.gtx +units=m
+no_defs`
However, the same transformation fails in PostGIS.
`$ psql -d db -c "SELECT
ST_AsEWKT(ST_Transform(ST_GeomFromText('POINT(16.582941335 47.710445103
291.7692)', 4326), '+proj=somerc +lat_0=47.14439372222222
+no_defs'))"`
`ERROR: proj_crs_is_swapped: proj_crs_get_coordinate_system returned NULL
CONTEXT: SQL function "st_transform" statement 1`
Interestingly, if I omit either `+geoidgrids` or `+nadgrids`
`ST_Transform` doesn't throw an error, but the coordinates are off.
+geoidgrids=geoid_eht2014.gtx +units=m +no_defs'))"`
`POINT(465007.88411299663 265848.07307208166 246.45166349798842)`
(formatting omitted for brewity)
+nadgrids=etrs2eov_notowgs.gsb +units=m +no_defs'))"`
`POINT(465092.51654231607 265877.1140839074 291.7692)`
This suggests that I can work around the problem by using a 2-step
approach, but I'd like to aviod that if possible.
What am I doing wrong?
Env:
- I'm using the PostGIS docker conainter
https://hub.docker.com/r/postgis/postgis
`$ psql -d db -c "SELECT PostGIS_Full_Version();"`
`POSTGIS="3.1.0dev 50b1e70" [EXTENSION] PGSQL="120" GEOS="3.9.0dev-
CAPI-1.14.0" PROJ="7.2.0" LIBXML="2.9.4" LIBJSON="0.12.1"
LIBPROTOBUF="1.3.1" WAGYU="0.5.0 (Internal)"`
- The geiod model and the grid is available here:
https://github.com/OSGeoLabBp/eov2etrs
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4817>
