[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-7-g5916f6e
git at osgeo.org
git at osgeo.org
Wed Dec 16 15:42:24 PST 2020
the project "PostGIS".
via 5916f6eb00544138601c804cb7c72061dd8110bc (commit)
from 5e1060473f79e97fa5333e83ca053c1f31500cec (commit)
revisions in full, below.
commit 5916f6eb00544138601c804cb7c72061dd8110bc
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Dec 16 15:42:43 2020 -0800
Add doc section ids, improve Tuning Index section
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index caadd8f..9965756 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -1230,7 +1230,7 @@ gisdb=# SELECT
PostGIS/PostgreSQL database: using formatted SQL statements or using the
Shapefile loader.</para>
- <sect3>
+ <sect3 id="load-data-sql">
<title>Using SQL to Load Data</title>
<para>If spatial data can be converted to a text representation (as either WKT or WKB), then using
@@ -1532,7 +1532,7 @@ AVERYLONGCOLUMNNAME DBFFIELD2</programlisting>
the functions available to do comparisons and queries on spatial tables.
</para>
- <sect3>
+ <sect3 id="extract-data-sql">
<title>Using SQL to Extract Data</title>
<para>The most straightforward way of extracting spatial data out of the
@@ -1988,17 +1988,17 @@ CREATE INDEX [indexname] ON [tablename]
</itemizedlist>
<para>There is no support for kNN searches at the moment.</para>
</sect3>
- <sect3>
- <title>Using Indexes</title>
+ <sect3 id="tuning-index-usage">
+ <title>Tuning Index Usage</title>
- <para>Ordinarily, indexes invisibly speed up data access: once the index
- is built, the PostgreSQL query planner automatically decides when to use index
- information to speed up a query plan. Unfortunately, the
- query planner sometimes does not optimize the use of GiST indexes,
+ <para>Ordinarily, indexes invisibly speed up data access: once an index
+ is built, the PostgreSQL query planner automatically decides when to use it
+ to improve query performance. But there are some situations
+ where the planner does not choose to use existing indexes,
so queries end up using slow sequential scans instead of a spatial index.</para>
<para>If you find your spatial indexes are not being used,
- there are a couple things you can do:</para>
+ there are a few things you can do:</para>
<itemizedlist>
<listitem>
@@ -2014,34 +2014,35 @@ CREATE INDEX [indexname] ON [tablename]
with better information to make decisions around index usage.
<command>VACUUM ANALYZE</command> will compute both.</para>
- <para>You should regularly vacuum your databases anyways - many PostgreSQL DBAs have
- <command>VACUUM</command> run as an off-peak cron job on a regular basis.</para>
+ <para>You should regularly vacuum your databases anyways. Many PostgreSQL DBAs run
+ <command>VACUUM</command> as an off-peak cron job on a regular basis.</para>
</listitem>
<listitem>
- <para>If vacuuming does not help, you can temporarily force the planner to use
- the index information by using the <command>set enable_seqscan to off;</command>
- command. This way you can check whether planner is at all capable to generate
- an index accelerated query plan for your query.
- You should only use this command only for debug: generally
- speaking, the planner knows better than you do about when to use
- indexes. Once you have run your query, do not forget to set
- <varname>ENABLE_SEQSCAN</varname> back on, so that other queries will utilize
- the planner as normal.</para>
+ <para>If vacuuming does not help, you can temporarily force the planner to use
+ the index information by using the command <command>SET ENABLE_SEQSCAN TO OFF;</command>.
+ This way you can check whether the planner is at all able to generate
+ an index-accelerated query plan for your query.
+ You should only use this command for debugging; generally
+ speaking, the planner knows better than you do about when to use
+ indexes. Once you have run your query, do not forget to run
+ <command>SET ENABLE_SEQSCAN TO ON;</command> so that the planner
+ will operate normally for other queries.</para>
</listitem>
<listitem>
- <para>If <command>set enable_seqscan to off;</command> helps your query to run,
- your Postgres is likely not tuned for your hardware.
- If you find the planner wrong about the cost of sequential vs
- index scans try reducing the value of <varname>random_page_cost</varname> in
- postgresql.conf or using <command>set random_page_cost to 1.1;</command>. Default value for
- the parameter is 4, try setting it to 1 (on SSD) or 2 (on fast magnetic disks).
- Decreasing the value makes the planner more inclined of using Index scans.</para>
+ <para>If <command>SET ENABLE_SEQSCAN TO OFF;</command> helps your query to run faster,
+ your Postgres is likely not tuned for your hardware.
+ If you find the planner wrong about the cost of sequential versus
+ index scans try reducing the value of <varname>RANDOM_PAGE_COST</varname> in
+ <code>postgresql.conf</code>, or use <command>SET RANDOM_PAGE_COST TO 1.1;</command>.
+ The default value for <varname>RANDOM_PAGE_COST</varname> is 4.0.
+ Try setting it to 1.1 (for SSD) or 2.0 (for fast magnetic disks).
+ Decreasing the value makes the planner more likely to use index scans.</para>
</listitem>
<listitem>
- <para>If <command>set enable_seqscan to off;</command> does not help your query,
+ <para>If <command>SET ENABLE_SEQSCAN TO OFF;</command> does not help your query,
the query may be using a SQL construct that the Postgres planner is not yet able to optimize.
It may be possible to rewrite the query in a way that the planner is able to handle.
For example, a subquery with an inline SELECT may not produce an efficient plan,
@@ -2049,6 +2050,9 @@ CREATE INDEX [indexname] ON [tablename]
</listitem>
</itemizedlist>
+ For more information see the Postgres manual section on
+ <ulink url="https://www.postgresql.org/docs/current/runtime-config-query.html">Query Planning</ulink>.
</sect3>
</sect2>
diff --git a/doc/using_postgis_query.xml b/doc/using_postgis_query.xml
index b140e13..378ae43 100644
--- a/doc/using_postgis_query.xml
+++ b/doc/using_postgis_query.xml
@@ -17,7 +17,7 @@
They are a fundamental capability for querying geometry.
</para>
- <sect3>
+ <sect3 id="DE-9IM">
<title>Dimensionally Extended 9-Intersection Model</title>
<para>According to the <ulink
@@ -288,7 +288,7 @@
</sect3>
- <sect3>
+ <sect3 id="named-spatial-rel">
<title>Named Spatial Relationships</title>
<para>To make it easy to determine common spatial relationships,
@@ -318,7 +318,7 @@ FROM city JOIN state ON ST_Intersects(city.geom, state.geom);
</sect3>
- <sect3>
+ <sect3 id="general-spatial-rel">
<title>General Spatial Relationships</title>
<para>In some cases the named spatial relationships
Summary of changes:
doc/using_postgis_dataman.xml | 60 +++++++++++++++++++++++--------------------
doc/using_postgis_query.xml | 6 ++---
2 files changed, 35 insertions(+), 31 deletions(-)
hooks/post-receive
