[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-8-g16da653
git at osgeo.org
git at osgeo.org
Wed Dec 16 16:00:39 PST 2020
the project "PostGIS".
via 16da653cbf29c4a1d6915462723948b6804b5f14 (commit)
from 5916f6eb00544138601c804cb7c72061dd8110bc (commit)
revisions in full, below.
commit 16da653cbf29c4a1d6915462723948b6804b5f14
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Dec 16 16:00:35 2020 -0800
Fix doc ST_Square typo
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 176a3ac..d231952 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -896,6 +896,52 @@ WHERE
</refsection>
</refentry>
+ <refentry id="ST_Hexagon">
+ <refnamediv>
+ <refname>ST_Hexagon</refname>
+ <refpurpose>Returns a single hexagon, using the provided edge size and
+ cell coordinate within the hexagon grid space.</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>geometry <function>ST_Hexagon</function></funcdef>
+ <paramdef><type>float8</type> <parameter>size</parameter></paramdef>
+ <paramdef><type>integer</type> <parameter>cell_i</parameter></paramdef>
+ <paramdef><type>integer</type> <parameter>cell_j</parameter></paramdef>
+ <paramdef choice="opt"><type>geometry</type> <parameter>origin</parameter></paramdef>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Uses the same hexagon tiling concept as <xref linkend="ST_HexagonGrid" />, but generates just one hexagon at the desired cell coordinate. Optionally,
+ can adjust origin coordinate of the tiling, the default origin is at 0,0.
+ </para>
+ <para>Hexagons are generated with no SRID set, so use <xref linkend="ST_SetSRID" /> to set the SRID to the one you expect.</para>
+ <para>Availability: 3.1.0</para>
+ </refsection>
+ <refsection>
+ <title>Example: Creating a hexagon at the origin</title>
+ <programlisting>SELECT ST_AsText(ST_SetSRID(ST_Hexagon(1.0, 0, 0), 3857));
+POLYGON((-1 0,-0.5
+ -0.866025403784439,0.5
+ -0.866025403784439,1
+ 0,0.5
+ 0.866025403784439,-0.5
+ 0.866025403784439,-1 0)) </programlisting>
+ </refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="ST_TileEnvelope" />, <xref linkend="ST_HexagonGrid" />, <xref linkend="ST_Square" /></para>
+ </refsection>
+ </refentry>
<refentry id="ST_SquareGrid">
<refnamediv>
@@ -970,58 +1016,11 @@ WHERE
</refsection>
</refentry>
- <refentry id="ST_Hexagon">
- <refnamediv>
- <refname>ST_Hexagon</refname>
- <refpurpose>Returns a single hexagon, using the provided edge size and
- cell coordinate within the hexagon grid space.</refpurpose>
- </refnamediv>
- <refsynopsisdiv>
- <funcsynopsis>
- <funcprototype>
- <funcdef>geometry <function>ST_Hexagon</function></funcdef>
- <paramdef><type>float8</type> <parameter>size</parameter></paramdef>
- <paramdef><type>integer</type> <parameter>cell_i</parameter></paramdef>
- <paramdef><type>integer</type> <parameter>cell_j</parameter></paramdef>
- <paramdef choice="opt"><type>geometry</type> <parameter>origin</parameter></paramdef>
- </funcprototype>
- </funcsynopsis>
- </refsynopsisdiv>
- <refsection>
- <title>Description</title>
- <para>Uses the same hexagon tiling concept as <xref linkend="ST_HexagonGrid" />, but generates just one hexagon at the desired cell coordinate. Optionally,
- can adjust origin coordinate of the tiling, the default origin is at 0,0.
- </para>
- <para>Hexagons are generated with no SRID set, so use <xref linkend="ST_SetSRID" /> to set the SRID to the one you expect.</para>
- <para>Availability: 3.1.0</para>
- </refsection>
- <refsection>
- <title>Example: Creating a hexagon at the origin</title>
- <programlisting>SELECT ST_AsText(ST_SetSRID(ST_Hexagon(1.0, 0, 0), 3857));
-POLYGON((-1 0,-0.5
- -0.866025403784439,0.5
- -0.866025403784439,1
- 0,0.5
- 0.866025403784439,-0.5
- 0.866025403784439,-1 0)) </programlisting>
- </refsection>
- <refsection>
- <title>See Also</title>
- <para><xref linkend="ST_TileEnvelope" />, <xref linkend="ST_HexagonGrid" />, <xref linkend="ST_Square" /></para>
- </refsection>
- </refentry>
<refentry id="ST_Square">
<refnamediv>
<refname>ST_Square</refname>
<refpurpose>Returns a single square, using the provided edge size and
+ cell coordinate within the square grid space.</refpurpose>
</refnamediv>
<refsynopsisdiv>
Summary of changes:
doc/reference_constructor.xml | 95 +++++++++++++++++++++----------------------
1 file changed, 47 insertions(+), 48 deletions(-)
hooks/post-receive
