[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-9-g000728d
git at osgeo.org
git at osgeo.org
Wed Dec 16 16:59:37 PST 2020
the project "PostGIS".
via 000728dfda4b2b57eda4f809b029d19e68d95001 (commit)
from 16da653cbf29c4a1d6915462723948b6804b5f14 (commit)
revisions in full, below.
commit 000728dfda4b2b57eda4f809b029d19e68d95001
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Dec 16 16:59:33 2020 -0800
Improve doc for ST_MultiPolygon
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index d231952..079a5b8 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -578,54 +578,58 @@ SELECT ST_MakePolygon( ST_ExteriorRing( ST_Buffer(ring.line,10)),
FROM (SELECT ST_ExteriorRing(
ST_Buffer(ST_MakePoint(10,10),10,10)) AS line ) AS ring;
</programlisting>
- <para>Create a set of province boundaries with holes
- representing lakes. The input is a table of
- province Polygons/MultiPolygons and a table of water linestrings.
- Using a LEFT JOIN ensures all provinces are included even if they have no lakes.
- </para>
- <note><para>The CASE construct is used because passing a null array into
- ST_MakePolygon results in a NULL return value.</para></note>
+ <para>Create a set of province boundaries with holes
+ representing lakes. The input is a table of
+ province Polygons/MultiPolygons and a table of water linestrings.
+ Lines forming lakes are determined by using <xref linkend="ST_IsClosed" />.
+ The province linework is extracted by using
+ <xref linkend="ST_Boundary" />.
+ As required by <code>ST_MakePolygon</code>,
+ the boundary is forced to be a single LineString by using <xref linkend="ST_LineMerge" />.
+ (However, note that if a province has more than one region or has islands
+ this will produce an invallid polygon.)
+ Using a LEFT JOIN ensures all provinces are included even if they have no lakes.
+ </para>
+ <note><para>The CASE construct is used because passing a null array into
+ ST_MakePolygon results in a NULL return value.</para></note>
<programlisting>
- SELECT p.gid, p.province_name,
- CASE WHEN array_agg(w.the_geom) IS NULL
- THEN p.the_geom
- ELSE ST_MakePolygon( ST_LineMerge(ST_Boundary(p.the_geom)), array_agg(w.the_geom)) END
- FROM
- provinces p LEFT JOIN waterlines w
- ON (ST_Within(w.the_geom, p.the_geom) AND ST_IsClosed(w.the_geom))
- GROUP BY p.gid, p.province_name, p.the_geom;
+SELECT p.gid, p.province_name,
+ CASE WHEN array_agg(w.geom) IS NULL
+ THEN p.geom
+ ELSE ST_MakePolygon( ST_LineMerge(ST_Boundary(p.geom)),
+ array_agg(w.geom)) END
+FROM
+ provinces p LEFT JOIN waterlines w
+ ON (ST_Within(w.geom, p.geom) AND ST_IsClosed(w.geom))
+GROUP BY p.gid, p.province_name, p.geom;
</programlisting>
<para>Another technique is to utilize a correlated subquery
and the ARRAY() constructor that converts a row set to an array.</para>
<programlisting>
- CASE WHEN EXISTS( SELECT w.the_geom
- FROM waterlines w
- WHERE ST_Within(w.the_geom, p.the_geom)
- AND ST_IsClosed(w.the_geom))
- THEN ST_MakePolygon(
- ST_LineMerge(ST_Boundary(p.the_geom)),
- ARRAY( SELECT w.the_geom
- FROM waterlines w
- AND ST_IsClosed(w.the_geom)))
- ELSE p.the_geom
- END AS the_geom
- FROM provinces p;
+ CASE WHEN EXISTS( SELECT w.geom
+ FROM waterlines w
+ WHERE ST_Within(w.geom, p.geom)
+ AND ST_IsClosed(w.geom))
+ THEN ST_MakePolygon(
+ ST_LineMerge(ST_Boundary(p.geom)),
+ ARRAY( SELECT w.geom
+ FROM waterlines w
+ AND ST_IsClosed(w.geom)))
+ ELSE p.geom
+ END AS geom
+FROM provinces p;
</programlisting>
</refsection>
<refsection>
<title>See Also</title>
<para>
- <xref linkend="ST_Boundary" />,
- <xref linkend="ST_AddPoint" />,
- <xref linkend="ST_IsClosed" />,
- <xref linkend="ST_LineMerge" />,
- <xref linkend="ST_StartPoint" />,
<xref linkend="ST_BuildArea" />
+ <xref linkend="ST_Polygon" />
</para>
</refsection>
</refentry>
Summary of changes:
doc/reference_constructor.xml | 74 +++++++++++++++++++++++--------------------
1 file changed, 39 insertions(+), 35 deletions(-)
hooks/post-receive
