[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-10-g5e759ed
    git at osgeo.org
    git at osgeo.org
    Wed Dec 16 19:40:45 PST 2020
the project "PostGIS".
       via  5e759ede6dd94e5000e69c12a93e6da29959fa55 (commit)
      from  000728dfda4b2b57eda4f809b029d19e68d95001 (commit)
revisions in full, below.
commit 5e759ede6dd94e5000e69c12a93e6da29959fa55
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Wed Dec 16 19:40:39 2020 -0800
    Improve doc ST_StartPoint, ST_EndPoint
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index cd3a070..17e92bb 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -722,43 +722,58 @@ SELECT ST_AsEWKT(geom) As the_geom, path
 	  <refsection>
 		<title>Description</title>
-		<para>Returns the last point of a LINESTRING
-		as a POINT.  Returns <varname>NULL</varname> if the input
-		is not a LINESTRING.</para>
+	  <para>Returns the last point of a <varname>LINESTRING</varname>
+      or <varname>CIRCULARLINESTRING</varname> geometry
+	  as a <varname>POINT</varname>.
+      Returns <varname>NULL</varname> if the input
+	  is not a <varname>LINESTRING</varname> or <varname>CIRCULARLINESTRING</varname>.</para>
 		<para>&sqlmm_compliant; SQL-MM 3: 7.1.4</para>
 		<para>&Z_support;</para>
-		<!-- Optionally mention Circular String Support -->
 	  <para>&curve_support;</para>
-		<note><para>Changed: 2.0.0 no longer works with single geometry multilinestrings.  In older
-	  versions of PostGIS -- a single line multilinestring would work happily with this
-	  function and return the start point.  In 2.0.0 it just returns NULL like any other multilinestring.
-	  The older behavior was an undocumented feature, but people who assumed they had their data stored as LINESTRING
-	  may experience these returning NULL in 2.0 now.</para></note>
+		<note><para>Changed: 2.0.0 no longer works with single geometry MultiLineStrings.  In older
+	  versions of PostGIS a single-line MultiLineString would work with this
+	  function and return the end point.  In 2.0.0 it returns NULL like any other MultiLineString.
+	  The old behavior was an undocumented feature, but people who assumed they had their data stored as LINESTRING
+	  may experience these returning NULL in 2.0.0.</para></note>
 	  </refsection>
 	  <refsection>
 		<title>Examples</title>
+<para>End point of a LineString</para>
 		<programlisting>postgis=# SELECT ST_AsText(ST_EndPoint('LINESTRING(1 1, 2 2, 3 3)'::geometry));
  st_astext
  POINT(3 3)
-(1 row)
+</programlisting>
-postgis=# SELECT ST_EndPoint('POINT(1 1)'::geometry) IS NULL AS is_null;
+<para>End point of a non-LineString is NULL</para>
+<programlisting>
+SELECT ST_EndPoint('POINT(1 1)'::geometry) IS NULL AS is_null;
   is_null
  t
-(1 row)
+</programlisting>
+<para>End point of a 3D LineString</para>
+<programlisting>
 --3d endpoint
 SELECT ST_AsEWKT(ST_EndPoint('LINESTRING(1 1 2, 1 2 3, 0 0 5)'));
   st_asewkt
  POINT(0 0 5)
-(1 row)</programlisting>
+</programlisting>
+<para>End point of a CircularString</para>
+<programlisting>
+SELECT ST_AsText(ST_EndPoint('CIRCULARSTRING(5 2,-3 1.999999, -2 1, -4 2, 6 3)'::geometry));
+ st_astext
+ POINT(6 3)
+</programlisting>
 	  </refsection>
 	  <refsection>
@@ -2554,46 +2569,52 @@ MULTIPOINT Z (30 10 4,10 30 5,40 40 6, 30 10 4)
 	<refsection>
-	  <para>Returns the first point of a <varname>LINESTRING</varname> or <varname>CIRCULARLINESTRING</varname> geometry
-	  as a <varname>POINT</varname> or <varname>NULL</varname> if the input
-	  parameter is not a <varname>LINESTRING</varname> or <varname>CIRCULARLINESTRING</varname>.</para>
+	  <para>Returns the first point of a <varname>LINESTRING</varname>
 	  <para>&sqlmm_compliant; SQL-MM 3: 7.1.3</para>
+	  versions of PostGIS a single-line MultiLineString would work happily with this
+	  function and return the start point.  In 2.0.0 it just returns NULL like any other MultiLineString.
 	</refsection>
 	<refsection>
+<para>Start point of a LineString</para>
 	  <programlisting>SELECT ST_AsText(ST_StartPoint('LINESTRING(0 1, 0 2)'::geometry));
  st_astext
  POINT(0 1)
-(1 row)
+</programlisting>
+<para>Start point of a non-LineString is NULL</para>
+<programlisting>
 SELECT ST_StartPoint('POINT(0 1)'::geometry) IS NULL AS is_null;
   is_null
  t
-(1 row)
+</programlisting>
---3d line
+<para>Start point of a 3D LineString</para>
+<programlisting>
 SELECT ST_AsEWKT(ST_StartPoint('LINESTRING(0 1 1, 0 2 2)'::geometry));
  st_asewkt
  POINT(0 1 1)
-(1 row)
+</programlisting>
--- circular linestring --
-SELECT ST_AsText(ST_StartPoint('CIRCULARSTRING(5 2,-3 1.999999, -2 1, -4 2, 5 2)'::geometry));
+<para>Start point of a CircularString</para>
+<programlisting>
+SELECT ST_AsText(ST_StartPoint('CIRCULARSTRING(5 2,-3 1.999999, -2 1, -4 2, 6 3)'::geometry));
  st_astext
  POINT(5 2)
Summary of changes:
 doc/reference_accessor.xml | 79 +++++++++++++++++++++++++++++-----------------
 1 file changed, 50 insertions(+), 29 deletions(-)
hooks/post-receive
