[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-11-g8d88f6a
git at osgeo.org
git at osgeo.org
Wed Dec 16 22:40:22 PST 2020
the project "PostGIS".
via 8d88f6a4ed077d5e80d2cf89aff60e964de9dcd9 (commit)
from 5e759ede6dd94e5000e69c12a93e6da29959fa55 (commit)
revisions in full, below.
commit 8d88f6a4ed077d5e80d2cf89aff60e964de9dcd9
Author: Martin Davis <mtnclimb at gmail.com>
Date: Wed Dec 16 22:40:12 2020 -0800
Improve doc SRS section
diff --git a/doc/reference_srs.xml b/doc/reference_srs.xml
index 91b0dec..51f2035 100644
--- a/doc/reference_srs.xml
+++ b/doc/reference_srs.xml
@@ -2,7 +2,8 @@
<sect1 id="SRS_Functions">
<sect1info>
<abstract>
- <para>These functions work with the Spatial Reference System of geometries.</para>
+ <para>These functions work with the Spatial Reference System of geometries
+ as defined in the <varname>spatial_ref_sys</varname> table.</para>
</abstract>
</sect1info>
@@ -12,8 +13,7 @@
<refnamediv>
<refname>ST_SetSRID</refname>
- <refpurpose>Set the SRID on a geometry to a particular integer
- value.</refpurpose>
+ <refpurpose>Set the SRID on a geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -63,7 +63,7 @@ SRID=3785;POINT(-13732990.8753491 6178458.96425423)
<refsection>
<title>See Also</title>
- <para><xref linkend="spatial_ref_sys" />, <xref linkend="ST_AsEWKT"/>, <xref linkend="ST_SRID"/>, <xref linkend="ST_Transform"/>, <xref linkend="UpdateGeometrySRID"/></para>
+ <para><xref linkend="spatial_ref_sys" />, <xref linkend="ST_SRID"/>, <xref linkend="ST_Transform"/>, <xref linkend="UpdateGeometrySRID"/></para>
</refsection>
</refentry>
@@ -71,7 +71,7 @@ SRID=3785;POINT(-13732990.8753491 6178458.96425423)
<refentry id="ST_SRID">
<refnamediv>
<refname>ST_SRID</refname>
- <refpurpose>Returns the spatial reference identifier for the ST_Geometry as defined in spatial_ref_sys table.</refpurpose>
+ <refpurpose>Returns the spatial reference identifier for a geometry.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -107,7 +107,7 @@ SRID=3785;POINT(-13732990.8753491 6178458.96425423)
<refsection>
- <para><xref linkend="spatial_ref_sys" />, <xref linkend="ST_GeomFromText" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_Transform" /></para>
+ <para><xref linkend="spatial_ref_sys" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_Transform" /></para>
</refsection>
</refentry>
@@ -115,7 +115,7 @@ SRID=3785;POINT(-13732990.8753491 6178458.96425423)
<refnamediv>
<refname>ST_Transform</refname>
- <refpurpose>Return a new geometry with its coordinates transformed to
+ <refpurpose>Return a new geometry with coordinates transformed to
a different spatial reference system.</refpurpose>
</refnamediv>
@@ -270,7 +270,7 @@ CREATE INDEX idx_the_geom_26986_parcels
<refsection>
- <para><xref linkend="PostGIS_Full_Version" />, <xref linkend="ST_AsText" />, <xref linkend="ST_SetSRID" />, <xref linkend="UpdateGeometrySRID"/></para>
+ <para><xref linkend="spatial_ref_sys" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_SRID" />, <xref linkend="UpdateGeometrySRID"/></para>
</refsection>
</refentry>
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 9965756..b06a188 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -534,47 +534,18 @@ The GEOMETRY type calculates a meaningless cartesian distance between Reykjavik
<para>There are two OpenGIS meta-data tables:
<varname>SPATIAL_REF_SYS</varname> and
- <varname>GEOMETRY_COLUMNS</varname>. The
- <varname>SPATIAL_REF_SYS</varname> table holds the numeric IDs and textual
- descriptions of coordinate systems used in the spatial database.</para>
+ <varname>GEOMETRY_COLUMNS</varname>.
+ </para>
<sect3 id="spatial_ref_sys">
<title>The SPATIAL_REF_SYS Table and Spatial Reference Systems</title>
<para>The <varname>SPATIAL_REF_SYS</varname> table used by PostGIS
- is an OGC-compliant database table that lists over 3000
- known <ulink url="https://en.wikipedia.org/wiki/Spatial_reference_system">spatial reference systems</ulink>
- and details needed to transform (reproject) between them.</para>
- <para>The PostGIS <varname>SPATIAL_REF_SYS</varname> table contains over 3000 of
- the most common spatial reference system definitions that are handled by the
- <ulink url="https://proj.org">PROJ</ulink> projection library.
- But there are many coordinate systems that it does not contain.
- You can define your own custom spatial reference system if you are familiar with PROJ constructs.
- Keep in mind that most spatial reference systems are regional
- and have no meaning when used outside of the bounds they were intended for.</para>
- <para>A resource for finding spatial reference systems not defined in the core set is <ulink url="http://spatialreference.org/">http://spatialreference.org/</ulink></para>
- <para>Some commonly used spatial reference systems are:
- <ulink url="http://spatialreference.org/ref/epsg/4326/">4326 - WGS 84 Long Lat</ulink>,
- <ulink url="http://spatialreference.org/ref/epsg/4269/">4269 - NAD 83 Long Lat</ulink>,
- <ulink url="http://spatialreference.org/ref/epsg/3395/">3395 - WGS 84 World Mercator</ulink>,
- <ulink url="http://spatialreference.org/ref/epsg/2163/">2163 - US National Atlas Equal Area</ulink>,
- and the 60 WGS84 UTM zones.
- UTM zones are one of the most ideal for measurement, but only cover 6-degree regions.
- (To determine which UTM zone to use for your area of interest, see the <ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiplpgsqlfunctionsDistance">utmzone PostGIS plpgsql helper function</ulink>.)
- </para>
- <para>
- US states use State Plane spatial reference systems (meter or feet based) - usually one or 2 exists per state.
- Most of the meter-based ones are in the core set, but many of the
- feet-based ones or ESRI created ones will need to be copied from <ulink url="http://spatialreference.org">spatialreference.org</ulink>.
- </para>
- <para>You can even define non-Earth-based coordinate systems,
- such as <ulink url="http://spatialreference.org/ref/iau2000/mars-2000/">Mars 2000</ulink>
- This Mars coordinate system is non-planar (it's in degrees spheroidal),
- but you can use it with the <varname>geography</varname> type to obtain length and proximity measurements in meters instead of degrees.</para>
+ is an OGC-compliant database table that defines the available
+ <ulink url="https://en.wikipedia.org/wiki/Spatial_reference_system">spatial reference systems</ulink>.
+ It holds the numeric IDs and textual descriptions of the coordinate systems,
+ to support transformation (reprojection) between them using <xref linkend="ST_Transform" />.
+ </para>
<para>The <varname>SPATIAL_REF_SYS</varname> table definition is:</para>
@@ -660,19 +631,74 @@ The GEOMETRY type calculates a meaningless cartesian distance between Reykjavik
<listitem>
<para>PostGIS uses the PROJ library to provide coordinate
transformation capabilities. The <varname>PROJ4TEXT</varname>
- column contains the Proj4 coordinate definition string for a
+ column contains the PROJ coordinate definition string for a
particular SRID. For example:</para>
<programlisting>+proj=utm +zone=10 +ellps=clrk66 +datum=NAD27 +units=m</programlisting>
<para>For more information see the
- <ulink url="https://proj.org/">Proj4 web site</ulink>.
+ <ulink url="https://proj.org/">PROJ web site</ulink>.
The <filename>spatial_ref_sys.sql</filename> file contains both
<varname>SRTEXT</varname> and <varname>PROJ4TEXT</varname>
definitions for all EPSG projections.</para>
</listitem>
</varlistentry>
</variablelist>
+ <para>When retrieving spatial reference system definitions for use in transformations,
+ PostGIS uses fhe following strategy:
+ </para>
+ <itemizedlist>
+ <listitem>If <varname>AUTH_NAME</varname> and <varname>AUTH_SRID</varname>
+ are present (non-NULL)
+ use the PROJ SRS based on those entries (if one exists).</listitem>
+ <listitem>If <varname>SRTEXT</varname> is present
+ create a SRS using it, if possible.</listitem>
+ <listitem>If <varname>PROJ4TEXT</varname> is present
+ </itemizedlist>
+ <para>The PostGIS <varname>SPATIAL_REF_SYS</varname> table contains over 3000 of
+ the most common spatial reference system definitions that are handled by the
+ <ulink url="https://proj.org">PROJ</ulink> projection library.
+ But there are many coordinate systems that it does not contain.
+ You can define your own custom spatial reference system if you are familiar with PROJ constructs.
+ Keep in mind that most spatial reference systems are regional
+ and have no meaning when used outside of the bounds they were intended for.</para>
+ <para>A resource for finding spatial reference systems not defined in the core set is <ulink url="http://spatialreference.org/">http://spatialreference.org/</ulink></para>
+ <para>Some commonly used spatial reference systems are:
+ <ulink url="http://spatialreference.org/ref/epsg/4326/">4326 - WGS 84 Long Lat</ulink>,
+ <ulink url="http://spatialreference.org/ref/epsg/4269/">4269 - NAD 83 Long Lat</ulink>,
+ <ulink url="http://spatialreference.org/ref/epsg/3395/">3395 - WGS 84 World Mercator</ulink>,
+ <ulink url="http://spatialreference.org/ref/epsg/2163/">2163 - US National Atlas Equal Area</ulink>,
+ and the 60 WGS84 UTM zones.
+ UTM zones are one of the most ideal for measurement, but only cover 6-degree regions.
+ (To determine which UTM zone to use for your area of interest, see the <ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiplpgsqlfunctionsDistance">utmzone PostGIS plpgsql helper function</ulink>.)
+ </para>
+ <para>
+ US states use State Plane spatial reference systems (meter or feet based) - usually one or 2 exists per state.
+ Most of the meter-based ones are in the core set, but many of the
+ feet-based ones or ESRI created ones will need to be copied from <ulink url="http://spatialreference.org">spatialreference.org</ulink>.
+ </para>
+ <para>You can even define non-Earth-based coordinate systems,
+ such as <ulink url="http://spatialreference.org/ref/iau2000/mars-2000/">Mars 2000</ulink>
+ This Mars coordinate system is non-planar (it's in degrees spheroidal),
+ but you can use it with the <varname>geography</varname> type
+ to obtain length and proximity measurements in meters instead of degrees.</para>
+ <para>Here is an example of loading a custom coordinate system using
+ an unassigned SRID and the PROJ definition for a US-centric Lambert Conformal projection:</para>
+<programlisting>
+INSERT INTO spatial_ref_sys (srid, proj4text)
+VALUES ( 990000,
+ '+proj=lcc +lon_0=-95 +lat_0=25 +lat_1=25 +lat_2=25 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs'
+</programlisting>
</sect3>
<sect3 id="geometry_columns">
@@ -702,8 +728,8 @@ The GEOMETRY type calculates a meaningless cartesian distance between Reykjavik
<listitem>
<para>The fully qualified name of the feature table containing the
geometry column. Note that the terms "catalog" and "schema" are
- Oracle-ish. There is not PostgreSQL analogue of "catalog" so that
- column is left blank -- for "schema" the PostgreSQL schema name is
+ Oracle-ish. There is no PostgreSQL analogue of "catalog" so that
+ column is left blank . For "schema" the PostgreSQL schema name is
used (<varname>public</varname> is the default).</para>
</listitem>
</varlistentry>
Summary of changes:
doc/reference_srs.xml | 16 +++----
doc/using_postgis_dataman.xml | 106 ++++++++++++++++++++++++++----------------
2 files changed, 74 insertions(+), 48 deletions(-)
hooks/post-receive
