[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-12-g861ae87
Thu Dec 17 08:55:07 PST 2020
the project "PostGIS".
       via  861ae877cbc989a65533d2f9e3d65e2d09cce680 (commit)
      from  8d88f6a4ed077d5e80d2cf89aff60e964de9dcd9 (commit)
revisions in full, below.
commit 861ae877cbc989a65533d2f9e3d65e2d09cce680
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Dec 17 08:54:51 2020 -0800
    Fix doc DTD compliance
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index b06a188..4d72d77 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -649,13 +649,16 @@ The GEOMETRY type calculates a meaningless cartesian distance between Reykjavik
     PostGIS uses fhe following strategy:
     </para>
 	<itemizedlist>
-		<listitem>If <varname>AUTH_NAME</varname> and <varname>AUTH_SRID</varname>
+		<listitem><para>If <varname>AUTH_NAME</varname> and <varname>AUTH_SRID</varname>
             are present (non-NULL)
-            use the PROJ SRS based on those entries (if one exists).</listitem>
-		<listitem>If <varname>SRTEXT</varname> is present
-            create a SRS using it, if possible.</listitem>
-		<listitem>If <varname>PROJ4TEXT</varname> is present
+            use the PROJ SRS based on those entries (if one exists).
+            </para></listitem>
+		<listitem><para>If <varname>SRTEXT</varname> is present
+            create a SRS using it, if possible.
+		<listitem><para>If <varname>PROJ4TEXT</varname> is present
 	</itemizedlist>
     <para>The PostGIS <varname>SPATIAL_REF_SYS</varname> table contains over 3000 of
Summary of changes:
 doc/using_postgis_dataman.xml | 15 +++++++++------
 1 file changed, 9 insertions(+), 6 deletions(-)
hooks/post-receive
